    Multi Copy Along a Path?
    15 Posts 5 Posters 13.4k Views 5 Watching
    • JoelM3DMJ Offline
      JoelM3DM
      Ok, ten points to whoever can answer this question ...
      I need to copy a component along a path. This path is an un-uniform curve, not a circle or straight line. The instances need to be exactly 4" apart on a path that's 20 feet long.
      How? Is there a plugin for this?
          -- Joel
      || Joel Metzger 3D Modeling
      || story-shorts.net - Animation with SU
      • massimoM Offline
        massimo Moderator
        Maybe path copy could do the job?
          mac1
          Can you post "the path" as skp. What one does maybe a function of how you created it. IE if it is a crazy Bezier or??
          • massimoM Offline
            massimo Moderator
            Joel it's something like the picture below that you're looking for? I've made it like this:
            1. Select all your curve and then weld it;
            2. Go to the "copy along path" plugin and choose "copy to path nodes";
            3. Select your welded path and then the component.
              That's all. Sadly you can't control the rotation of the component I believe.
              I've attached the SKP too. πŸ˜„
            INNER ARM-1.skp
            • JoelM3DMJ Offline
              JoelM3DM
              Here is my path and the component to copy. The curved path is broken up into short segments. Forget what I wrote about every 4".
              This cube needs to repeated at every endpoint (about 120), with the x on the bottom of the cube centered on that endpoint. (And parallel to the line but I assume they'll have to be rotated manually.) I tried the Copy Along Path rb, but Copy to Path Nodes is not working for me. I got only 2 copies.
                   -- Joel
              ARM & COMPONENT
              • JoelM3DMJ Offline
                JoelM3DM
                Yes, something like that - but I need each cube centered exactly on an endpoint.
                • massimoM Offline
                  massimo Moderator
                  And actually they are if I'm not wrong...Only rotated on the "original" xy axes.
                  • JoelM3DMJ Offline
                    JoelM3DM
                    This is good ... Thanks!
                      j40
                      Is there an option to enter length value? for instance: I want the distance between the components to be 200cm.
                      I can see that in the right lower corner in SU appears "distance between: 305cm" but I'm unable to type my value.
                      Top3D Studio
                      • massimoM Offline
                        massimo Moderator
                        Sure, just use the "copy to spacing" option of the plugin: plugins-->copy along path-->copy to spacing-->input the desired distance-->select your path-->select your component. πŸ˜„
                          j40
                          Thanks massimo,
                          But now I see new problem, the components located just at the vertexes/endpoints of the welded path and not at 200 cm distance.
                          Any idea why is this happening?
                          Top3D Studio
                            j40
                            Ah.. My bad. I used the "copy to path nodes" instead of the "copy to spacing".
                            Thanks a lot massimo for the quick response and the help.
                            Top3D Studio
                            • massimoM Offline
                              massimo Moderator
                              No problem, glad that helped. πŸ˜„
                              • simon le bonS Offline
                                simon le bon
                                Hi Guys,
                                If I may say: - excuse me Rick πŸ˜• - PathCopy is outdated to do that sort of job.
                                You may use now and very easily
                                [Plugin] Component Stringer UPDATED Nov. 16, 2009 by Chris Fullmer see some studies I'd made
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_024th.jpg
                                in conjunction with the absolutely not outdated - thank you so much Rick πŸ‘ πŸ˜‰ - Weld v.3.000 by Rick Wilson in order to weld segments in one curve
                                and in conjuction with [Plugin] BezierSpline v1.3b - 31 Jan 10 by Fredo6 You will find in the context menu the possibility to translate curves in regularly segmented polylines πŸ‘ πŸ‘ πŸ˜‰ πŸ˜‰
                                And Oh! JoΓ«l I had loved your movies πŸ˜‰
                                ++simonlebon
                                • massimoM Offline
                                  massimo Moderator
                                  Sorry, but I don't understand your problem. The plugin has two options to choose from:
                                  • "copy to path nodes" will place your components on every node of your path indipendently from the distance;
                                  • "copy to spacing" will place your components each other at the input distance indipendently from the nodes.
