    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
    • T
      tak2hata
      @mariocha said:
      @frv said:
      ....., I love the idea of the crowedmaker.
      But under OSX it does not work, the dialog panel is empty for the crowed option.
      Francois
      Yep, same here. No dialog under MacOX (10.6.3) πŸ˜•
      Hi,Francois and Mario.
      It is very regrettable.
      I will examine way for working on mac.
      @masoncrowell said:
      can someone tell me how i do this on a mac?
      i downloaded the file and updated my version of sketchup. the file only shows up in my downloads and i can't open it with sketchup. i also enabled my plugins menu on sketchup and the only option that shows up is a "cost" option. How do i do this? πŸ˜•
      This file is compressed by zip.
      First, You should extract this file with folder.
      It includes
      --fur_en.rb
      --fur_en(folder include icon images)
      and copy created files to plugins folder.
      Read here.
      http://sketchup.google.com/intl/en/download/rubyscripts.html
      Thanks.
      by TAK2HATA
      • K
        ktslambieng
        this is this is a new : vietnam translation for fur1.4b
        Thanks you for all !
        http://farm2.static.flickr.com/1273/4676700265_23fc0faee3_b.jpg
        fur_lang_vn14b.txt
        • F
          frv
          TX Tak,
          hope you find the time to look into the blanc dialog for crowds.
          I love your idea to specialise the furmaker for crowds
          Francois
            That is due to some oddness in Geom::Transformation.scaling which I mentioned earlier.
            http://forums.sketchucation.com/viewtopic.php?f=323&t=28092&p=248300#p248300
            But tak2hata said later he's swapped to use .scaling(a,a,a) isntead of .scaling(a) - so that should have taken care of it. Unless there is something else that also creates this scenario.
            Oli: are you using the latest version?
              ❓ what happened to Oli's post..?
                michaelhsu
                amazing, thanks.
                • W
                  wanchoke
                  I use this plugin to my model, It's help to improve atmosphere a lot.
                  Thank you very much. πŸ‘ πŸ‘
                  http://lh6.ggpht.com/_xQzZkoFEzSQ/TBLHIaL6eII/AAAAAAAACV8/QfktBGuUv2U/s912/House on Haunted Hill 2.jpg
                  <model link>
                  http://sketchup.google.com/3dwarehouse/details?mid=5e3202cae2da28223fc4dc5809e00c5c&prevstart=0
                  • GaieusG
                    You do not really need to open it just drop into the plugins folder in your SU application.
                    Otherwise rb files are text files and should be opened with some simple text editor (never with some word processor!).
                    • McGyverM
                      McGyver
                      I just tried this out on my G5(Power PC) Mac using SU 6 free version... it works like a charm! I look forward to experimenting with this! Awesome job! Thank you!!!
                      Just a quick test I did... rendered in Kerkythea.
                      Visit My ShareCG Freebie Gallery
                      • N
                        Ninjamaster1470
                        I know this will sound really dumb, but it appears that i set the plugin RB (whatever) file to google sketchup program so that when ever i click it, it opens on sketchup instead on.........um.....what it's supposed to open on--btw, what is the program its on?
                        Help! do u know how to fix?
                        Update: I moved it but its still a SU app instead of the supposed text doc.
                          angor2005
                          Please Russian translation.
                          Many Thanks to you all !
                            aiwkha
                            So nice plugins.
                            • B
                              blajnov
                              fur_lang_ru.txt
                              • GaieusG
                                πŸ‘
                                • McGyverM
                                  McGyver
                                  Hi. I've been playing around with this and have found some good uses for this plugin. The one thing I'm not getting is, which setting (if any) controls the number of (leafs, blades of grass, etc.) that are generated... I've been trying to get smaller number of "blades per inch" but I'm not really noticing much of a difference. I figured it would be Density(Num/m2) and or MaxNumber(/face)... I went as low as 10 on a 4 ft x 4 ft square and I really can't tell the difference between these set at 200... πŸ˜•
                                  Any suggestions or help in this matter is greatly appreciated.
                                  EDIT- Never mind, I figured it out... I was using sandbox and the faces(grids) were too small... works fine otherwise.
                                  • T
                                    tak2hata
                                    Hi all.
                                    I update makefur to version1.4c(webdialog test for mac)
                                    fixing webdialog problem on mac os.
                                    (referred to forum "[Web dialog] switch snippet for pc / mac" and jim's "protrude.rb")
                                    I wish this working on mac!
                                    4 ft x 4ft = 16 ft.sq
                                    16 * 10(num/m2) = 160.
                                    16 * 200(num/m2) = 3200.
                                    If you keeping MaxNumber(/face) as 200,then It makes 200 fur on each faces.
                                    16 x200 = 3200 changes to 200.
                                    So you should glow MaxNumber(/face) like 4000.
                                    Thanks.
                                    by TAK2HATA
                                    • mariochaM
                                      mariocha
                                      I'm so sorry to have to report the web dialogs still do not work on Mac here. Empty.
                                      I have other plugins that use them, and they work just fine.
                                      Web dialog, Fur 1.4c
                                      %(#008000)[Mario C.
                                        jeabdc
                                        I don't understand about "assign_material"&"get_from_material".
                                        Thank Jeab from Thailand πŸ˜„
                                        • OxerO
                                          Oxer
                                          Hello mariocha,
                                          I work on Mac too, and the web dialogs don't appear but i find a solution for resolve this problem, edit "fur_en.rb" (with TextWrangler for example) and delete this sign "#" in the lines 638 and 1609, now the web dialogs will work.
                                          There is a problem yet, all performances of Crowd work but when you select a component for crowd the plugin create a noname group on surface but isn't a group with your component selected, it's a group of triangles, i don't know why.
                                          I hope that tak2hata help us for resolve this problem.
                                          Bye!
                                          • T
                                            tak2hata
                                            Thanks Mario and Oxer. πŸ˜†
                                            I change "#" in line(638 and 1309).
                                            now, version is 1.4d.
                                            I wish this work on mac very well.
                                            Bye!
                                            I will examine the part again.
                                            Please wait.(few days)
                                            Thanks a lot.
                                            by TAK2HATA
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 32
                                            • 33
                                            • 16 / 33
