    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.2m Views 254 Watching
      rlsb2006
      @paulower said:
      @thomthom said:
      paulower: that's a nice setup. Thanks for sharing.
      That's it thomthom. We are here also for these share.
      Is a tip for the staff, if possible to share their techniques and components (maps, textures) of grass and others.
      @tak2hata said:
      Hi,All.
      I update fur plugin to verion1.3j.
      Increased translatable words for local language file.
      Franch translation by Daredevil.
      Persian translation by Majid.
      Spanish translation by Oxer.
      Thanks you very mush.
      Thanks.
      This is the translation of Make Fur to languaje Portuguese-BR (Brazil) by me.
      Tak2hata would be possible in the next version, you increase the size of the buttons "Assign Material to" and "Get Stuff From." Is that in Portuguese, we have more characters in the translation and some letters may not appear on the icon (button).
      You can see who is running smoothly letters with accents and numerical symbols.
      http://i910.photobucket.com/albums/ac301/bausketchup/FUR.png
      [attachment=1:13bk7rro]<!-- ia1 -->fur_lang_pt 1.4a.rar<!-- ia1 -->[/attachment:13bk7rro]
        cihooi
        keren brur...
        • leedeeteeL Offline
          leedeetee
          This is a great plugin, as another poster has said, it's great for landscaping.
          Just have a quick question though....
          How can I get a component to 'reproduce' at roughly the same size as the original component? Everytime I try, no matter what I fiddle with, the instances become helluva lot bigger than oringal and I have to scale them down everytime.
          Thanks in advance, sorry for the (probable) stupid question. 😄
            butiongrichard
            [quote="tak2hata"]Hi,
            Thank you for using this plugin.
            hey nice plugin i want to try it also coz i think its cool..
              tak2hata
              I updated fur_en.version 1.5a.
              Added Preview mode.
              Preview only points of density.
              Thanks.
              by TAK2HATA
              • W Offline
                wyatt
                I love the fur plugin! Thank you for this update; a preview is such a great idea. Is it possible to simplify the toolbar/menu options to eliminate the PC or Mac buttons (depending on what system you're running)? I'm on a PC and I have tried deleting all reference to the Input Box at the end of the script, but I get this error:
                Error Loading File fur_en.rb
                C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/fur_en.rb:2083: syntax error, unexpected '}', expecting kEND.
                Obviously there is something else calling on the Input Box references.
                  saturne45
                  Thank you Mister Tak2hata, for your fantastic plugin...MAKE FUR IN THE SKY.png
                    manamana
                    I love this plugin. Can't believe how fast it is.
                    But I'm having trouble nailing down settings for a particular type of grass - anyone want to take a stab at it?
                    North Carolina tidal grass, 6+ feet tall:
                    http://i54.tinypic.com/2m82zwo.jpg
                    http://i51.tinypic.com/rcschj.jpg
                    I think it's all green in the early summer, but I'm having trouble finding photos.
                    • OxerO Offline
                      Oxer
                      @diego-rodriguez said:
                      Hi tak
                      tanks for the update.
                      only litle problem with translation.
                      does not recognize the accents "ó" and the symbols "nº".
                      by doing this?
                      Hola Diego!
                      He sido yo el que ha traducido el plugin a Español, el problema con los caracteres acentuados es la codificación del texto, para que se reconozcan correctamente el archivo .txt debe guardarse con codificación Unicode (UTF-8), yo lo tengo así y me aparecen correctamente. Prueba a abrir el archivo .txt con un editor de texto y guardarlo con esta codificación que te indico, verás como se soluciona el problema. De todas formas te pongo el archivo en Unicode para que te lo descargues y me contestas si te funciona.
                      Por cierto, no se si a ti te pasará, cuando las unidades son metros, el plugin no funciona, las demás unidades va todo correcto.
                      Un Saludo!
                      Fur v1.5a Spanish Language
                        paulower
                        Hi friends. This is the translation of Make Fur to languaje Portuguese-BR (Brasil) by me.
                        Whenever possible, I will update the new versions in the same post.
                        fur_lang_pt (Brazil) Em português do Brasil - v1.5b (de 28/10/2010)
                        Outras versões (Other versions):
                        fur_lang_pt (Brazil) Em português do Brasil - v1.4a
                        fur_lang_pt (Brazil) Em português do Brasil - v1.4b
                        @tak2hata said:
                        Hi,All.
                        Thanks.
                        Baú SketchUp
                        Visite nosso blog.. Visit our blog Baú SketchUp
                          paulower
                          Hello everyone. I really enjoyed this new feature. I also updated the language to Portuguese-pt-BR this new version: (v1.5a)
                          Whenever possible, I will update the translation of new versions on same post:
                          http://forums.sketchucation.com/viewtopic.php?f=323&t=28092&p=249923#p249923
                          Hug!
                          Baú SketchUp
                          • 3 Offline
                            3D Sloth
                            Exellent wor Tak2hata, congrats! I just downloaded this at work... can't wait to try it out at home, since in my company I only do interior... wait a minute, what about a nice carpet, yeeees that's it! 👍
                              Thanks tak2hata for this new version - the preview is indeed useful (no need to experiment till I get what I need!) 😍
                                goWentgone
                                I've got SketchUP 8 pro, although it seems really easy to use this plugin, I don't get any fur...
                                I know which settings I should have, but when I click on assign to material, nothing happens... 😞
                                any step by step explanation would be great!
                                thanks in advance.
                                • N Offline
                                  nektares
                                  Thanks! since i saw this one it instantly became one of my top plugins!
                                  • fuzzionF Offline
                                    fuzzion
                                    Fur used to work for me. I didnt use fur for a while.Since then, i installed various plugins including the tgi3d amorph plugin.
                                    Now it does not work.
                                    It installed fine.
                                    It shows up in my tool bar
                                    I select face and click make fur with default settings but nothing happens. Even preview doesn't work.
                                    I tried it on SU8 where i have only installed the TGi3d plugin, and it does not work.
                                    This is an important plugin so any help is greatly appreciated 😄
                                    PS. Every other plugin works fine. ❓
                                    "Only the dead have seen the end of war" - Plato
                                      cupko
                                      In rollout menu Make by Component select No instead fur_instance.
                                      • fuzzionF Offline
                                        fuzzion
                                        I tried that on both SU8 and 7.1 but it still does not work. I can click the 'make fur' button
                                        a million times but nothing happens 😞
                                          tak2hata
                                          Hi fuzzion.
                                          now ,I couldn't find the solution for this problem.
                                          I want to see the dialog of the "fur" on your computer.
                                          and show "ruby console" before clicking the "make fur" button.
                                          (showing "ruby console" is in "windows" in the menubar)
                                          if it shows some error message when clicking make fur button,
                                          I want to see it.
                                          Thanks.
                                          by TAK2HATA
                                            gr8fzy1
                                            I had an older version that was working for me in SketchUp 7, can't remember what version it was, but I recently downloaded the newest version for my SketchUp 8 Pro (fur_en_15, I think it was called) and it's not functioning right. I get green dots instead of grass or fur. I'll post some screenshots for you.
                                            Older fur maker in SKUP 7:
                                            http://i44.photobucket.com/albums/f42/gr8fzy1/FurInSKUP7.png
                                            Fur_en_15 in SKUP 8 Pro:
                                            http://i44.photobucket.com/albums/f42/gr8fzy1/FurProblemsSKUP8.png
                                            In the meantime, I've copy/pasted the older furmaker into SKUP 8 and THAT is working, it's just growing the grass upside down.
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 32
                                            • 33
                                            • 18 / 33
