    [Plugin] [CityGen] - Street Generator [WIP] (0.5.2a)
    124 Posts 37 Posters 137.8k Views 37 Watching
    • Chris FullmerC
      The angles that are labeled don't correspond to the sidewalk that will or won't be curved. I was thinking the angle threshold would correspond to the angles I am pointing at in the picture. I'm sure I'm just misunderstanding how the script is supposed to work.
        I see.
        The reason the angles differ, is because I based it off the centre line. You see the Red and Green arc? That's the angles I measure.
        I was thinking of the angles as in how much it rotated away from the centre line - like if you'd be driving down the street; how many degrees you'd have to turn.
        That's why the red and green radius is located by the centre line instead of the street edge. The colour coding was meant to illustrate which edge corner the angle related to.
        Interesting how you had a different approach to it. That's what I was curious of. It'd be good if more people could let me know how they'd expect it to work. What feels more intuitive.
        • soloS
          Not sure where to post this or even if it's relevent, if anyone wants to be part of this city gen app follow link: http://www.fileplanet.com/promotions/cities-xl/?_cmpid=fp161
          • JClementsJ
            JClements
            @chris fullmer said:
            @thomthom said:
            Yea, I was thinking of maybe adding a brush painting tool. Where you can sweep. Or maybe have a large hit-radius.
            I think that would be a welcome addition to the plugin. I was having frustration issues when I tried to paint lines earlier for my demo too.... They are tricky little things to pin down with the bulky paintbucket.
            This is my first look at this forum.
            Painting edges; that was what initiated the request I posted a day or so ago here:
            http://forums.sketchucation.com/viewtopic.php?f=180&t=21125
              Been a long break from this project. Other things has taken priority. Just wanted to upload the latest version I had on disk.
              • T
                tug
                Hi Thom.-
                here is me again, now back in Spain. I'd tested city generator and found some bugs in the use. I don't Know if it's due to the configuration (as I told you before) or is a real bug in the programming.
                I'm using Skechup 7.1 with many plugins instaled and here the main bug I found:
                I can't modify the parameters on "define streets", can't create news types or change the predef-values
                best regards
                jann
                  The define streets dialogue isn't finished yet. I meant to disable it before I uploaded, but forgot.
                  • T
                    tug
                    okis.. then
                    I'll wait for news...
                    best regards
                      j40
                      Hi Thom,
                      First, thank you for your work on this plugin.
                      Unfortunately I can't make it load in SU
                      Error
                      Top3D Studio
                        Follow the link under Requirements
                          j40
                          Now it works πŸ˜„
                          Top3D Studio
                          • P
                            Pherim
                            Can't believe that I dindn't find this earlier. This is exactly what I need, thank you!
                            • Chris FullmerC
                              Don't thank anyone til you try it πŸ˜„ It was a project that was started, and got alomst no-where. Thom got some of his parts working with the street generator, but that is about the only thing that works I think.
                              Post questions or comments here though. This is a project we are all keen on getting started again.
                              • P
                                Pherim
                                I tried it and it works perfectly fine for my purposes. I don't know about the other parts that were planned for this project but the Street Generator does exactly what I want it to do, so thank you again. πŸ˜„
                                • C
                                  caleidos4d
                                  Street Generator is FANTASTIC!!!! πŸ‘ Thanks!!
                                  http://www.caleidos4d.it
                                  • H
                                    haynesc
                                    I dont know why but I have installed the files but i get
                                    "The CityGen's core files is not laoded. ensure you installed this plugin correctly"
                                    I opened up the zips to both the core and streetgen and copied into Plugins
                                    why is it not working ?
                                      Because StreetGen goes into a subfolder of CityGen. The description has detailed info.
                                      • iichiversiiI
                                        iichiversii
                                        Is there any clips on the net that show this working???
                                        Bring on the Rain...
                                        • H
                                          haynesc
                                          Ok iv moved the files into the correct location, boot sketchup and I get no error message, now how do i use the plugin ?
                                          • brookefoxB
                                            brookefox
                                            Apparently I'm being quite thick about this install. I've read the Requirements and notes several times and tried it several ways, each resulting in errors and failed loads.
                                            The 'module' subfolder is an actual folder into which street gen and other such modules are placed or just a stand-in name for street gen and such?
                                            city_gen_loader.rb goes under tools or plugins?
                                            My current:
                                            C:\Program Files (x86)\Google\Google SketchUp 8\Tools\city_gen_loader.rb
                                            and also since nothing works (is this duplication a problem, for the moment?)
                                            C:\Program Files (x86)\Google\Google SketchUp 8\Plugins\city_gen_loader.rb
                                            C:\Program Files (x86)\Google\Google SketchUp 8\Plugins\city_gen.rb
                                            C:\Program Files (x86)\Google\Google SketchUp 8\Plugins\citygen\street_gen.rb
                                            I have another instance of SU running, but that shouldn't interfere should it if I shut this one down to make install changes?
                                            Readme.txt from citygen modules subfolder:
                                            This is the module and support folder for CityGen.
                                            All .rb files in this folder is loaded by city_gen.rb.
                                            Make a new folder for eah module, and place a loading .rb here.
                                            Example:
                                            Plugins\city_gen.rb <- Core CityGen file
                                            Plugins\Gity_Gen\street_gen.rb <- Core Street Generator module file - loaded by city_gen.rb
                                            Plugins\City_Gen\Street_Gen\ <- Street Generator's support folder
                                            Tips appreciated.
                                            http://img109.imageshack.us/img109/3946/citygenstreetgenloaderr.jpg
                                            ~ Brooke
                                            • 4 / 7
