    [Plugin] [CityGen] - Street Generator [WIP] (0.5.2a)
    124 Posts 37 Posters 137.8k Views 37 Watching
      j40
      @thomthom said:
      Follow the link under Requirements
      Now it works πŸ˜„
      Top3D Studio
      • P
        Pherim
        Can't believe that I dindn't find this earlier. This is exactly what I need, thank you!
        • Chris FullmerC
          Don't thank anyone til you try it πŸ˜„ It was a project that was started, and got alomst no-where. Thom got some of his parts working with the street generator, but that is about the only thing that works I think.
          Post questions or comments here though. This is a project we are all keen on getting started again.
          • P
            Pherim
            I tried it and it works perfectly fine for my purposes. I don't know about the other parts that were planned for this project but the Street Generator does exactly what I want it to do, so thank you again. πŸ˜„
            • C
              caleidos4d
              Street Generator is FANTASTIC!!!! πŸ‘ Thanks!!
              http://www.caleidos4d.it
              • H
                haynesc
                I dont know why but I have installed the files but i get
                "The CityGen's core files is not laoded. ensure you installed this plugin correctly"
                I opened up the zips to both the core and streetgen and copied into Plugins
                why is it not working ?
                  Because StreetGen goes into a subfolder of CityGen. The description has detailed info.
                  • iichiversiiI
                    iichiversii
                    Is there any clips on the net that show this working???
                    Bring on the Rain...
                    • H
                      haynesc
                      Ok iv moved the files into the correct location, boot sketchup and I get no error message, now how do i use the plugin ?
                      • brookefoxB
                        brookefox
                        Apparently I'm being quite thick about this install. I've read the Requirements and notes several times and tried it several ways, each resulting in errors and failed loads.
                        The 'module' subfolder is an actual folder into which street gen and other such modules are placed or just a stand-in name for street gen and such?
                        city_gen_loader.rb goes under tools or plugins?
                        My current:
                        C:\Program Files (x86)\Google\Google SketchUp 8\Tools\city_gen_loader.rb
                        and also since nothing works (is this duplication a problem, for the moment?)
                        C:\Program Files (x86)\Google\Google SketchUp 8\Plugins\city_gen_loader.rb
                        C:\Program Files (x86)\Google\Google SketchUp 8\Plugins\city_gen.rb
                        C:\Program Files (x86)\Google\Google SketchUp 8\Plugins\citygen\street_gen.rb
                        I have another instance of SU running, but that shouldn't interfere should it if I shut this one down to make install changes?
                        Readme.txt from citygen modules subfolder:
                        This is the module and support folder for CityGen.
                        All .rb files in this folder is loaded by city_gen.rb.
                        Make a new folder for eah module, and place a loading .rb here.
                        Example:
                        Plugins\city_gen.rb <- Core CityGen file
                        Plugins\Gity_Gen\street_gen.rb <- Core Street Generator module file - loaded by city_gen.rb
                        Plugins\City_Gen\Street_Gen\ <- Street Generator's support folder
                        Tips appreciated.
                        http://img109.imageshack.us/img109/3946/citygenstreetgenloaderr.jpg
                        ~ Brooke
                        • brookefoxB
                          brookefox
                          Parameters accept but do not generate 'feet', as far as I can tell. It would be nice if the model units were enforced, if they cannot be specified otherwise, and that settings could be remembered. Sorry if that is too obvious and has been said before.
                          Any tips for this minor error in the street generated? I made sure the centerlines intersected. Green is the 60' ROW; gray is the 24' road itself, both generated from the blue centerline.
                          http://img27.imageshack.us/img27/6039/citygenstreetgenerrors3.jpg
                          ~ Brooke
                          • brookefoxB
                            brookefox
                            By somewhat selectively scattering and deleting, I got it to load.... Pretty unsavory process, and though I'll hang my hat on the opinion that the install instructions ain't much clearer than mud, most folks don't seem to have a problem so my problem may indeed be me.
                            Make a new folder for eah module, and place a loading .rb here. (Here where?)
                            Example:
                            It loads and the parameters can be set but but it does not work... generate does not generate, except on the parameters screen.
                            Looks like I set params that were not workable. When I reopened TT's street model and used the default settings, streets were generated. When I tried the same on my curves the ruby console said generating but none were evident. I need to play with the params; too many segments probably that need to be dealt with by the plugin. I'll try to set to a large angle or no rounding, maybe weld the segments. Oops... it was working: I just had to click away. This was because the streets are created on layer '0' and I was on layer 'street centerlines' with other layers hidden when group editing. Perfectly reasonable.
                            http://img19.imageshack.us/img19/8131/citygenstreetgenerrors1.jpg
                            Ruby console:
                            Error: #<NoMethodError: private method split' called for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/citygen/modules/street_gen.rb:536:in string_to_hash'
                            C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/citygen/modules/street_gen.rb:118
                            ~ Brooke
                              The project was made quite some time ago. I, we, where rather newish to SketchUp plugins. The project was in early stages - still is because we've not had time to work on it. Information is not the best, as it was intended more for developers than users.
                              The CityGen thread points to where the modules should be installed:
                              Core and Installation Check
                              This is the main file that centralise information and load the other modules.
                              Modules are located in Plugins\CityGen\modules.
                              So the Streetgen modules should go into that folder.
                              I've been wishing to update this project, but it's been too far down on my priority list. 😞
                              • brookefoxB
                                brookefox
                                Literally, like: Plugins\CityGen\modules\street_gen
                                or like: Plugins\CityGen\street_gen\
                                I tried both and am not sure why it is now working... I surely have it mucked up a bit with unnecessary dupes but it is working well enough, and understandably no one has the time to help figure it out.
                                Thanks for checking in and replying and for sharing the thing in the first place.
                                Oh, I see over at the City Gen thread you already clarified:
                                You're missing the full path. Observe: Plugins\CityGen*modules*\
                                ~ Brooke
                                  Yes, the instructions are a bit confusing - I know. we where changing many things very quickly when we where actively developing. That's why some notes might be somewhat inconsistent.
                                  hmm... Maybe it'd be worth re-packaging as RBZ...
                                  • brookefoxB
                                    brookefox
                                    Well, I'm all for it. I find the parameter setting applet to be clear and concise and quite elegant. An irrelevant benefit to running the routine is that errant entities are made obvious owning to how they generate more obvious 'errants'.
                                    ~ Brooke
                                    • brookefoxB
                                      brookefox
                                      I used it to draw braided streams for planning purposes. Perhaps the street gen focus is limiting it's real applicability. (I seemed to be getting erroneous non-co-planar error msgs in the ruby console, but enough of that.) These were no done carefully and have not been cleaned up, either.
                                      http://img201.imageshack.us/img201/4680/streetgenstream1.jpg
                                      http://img718.imageshack.us/img718/5568/streetgenstream2.jpg
                                      ~ Brooke
                                        What is you don't do corner rounding?
                                        • brookefoxB
                                          brookefox
                                          Sorry I missed your post. I was working with curves, so there were no corners to be rounded.
                                          ~ Brooke
                                            Doesn't matter - it doesn't see Curves. So when you set the rounding to 360 you will get odd results. It wasn't meant to accept such value. Just hasn't been implemented a limit check.
                                            • 5 / 7
