    [Plugin] [CityGen] - Street Generator [WIP] (0.5.2a)
    124 Posts 37 Posters 135.4k Views 37 Watching
    • JClementsJ
      JClements
      @chris fullmer said:
      @thomthom said:
      Yea, I was thinking of maybe adding a brush painting tool. Where you can sweep. Or maybe have a large hit-radius.
      I think that would be a welcome addition to the plugin. I was having frustration issues when I tried to paint lines earlier for my demo too.... They are tricky little things to pin down with the bulky paintbucket.
      This is my first look at this forum.
      Painting edges; that was what initiated the request I posted a day or so ago here:
      http://forums.sketchucation.com/viewtopic.php?f=180&t=21125
        Been a long break from this project. Other things has taken priority. Just wanted to upload the latest version I had on disk.
        • T
          tug
          Hi Thom.-
          here is me again, now back in Spain. I'd tested city generator and found some bugs in the use. I don't Know if it's due to the configuration (as I told you before) or is a real bug in the programming.
          I'm using Skechup 7.1 with many plugins instaled and here the main bug I found:
          I can't modify the parameters on "define streets", can't create news types or change the predef-values
          best regards
          jann
            The define streets dialogue isn't finished yet. I meant to disable it before I uploaded, but forgot.
            • T
              tug
              okis.. then
              I'll wait for news...
              best regards
                j40
                Hi Thom,
                First, thank you for your work on this plugin.
                Unfortunately I can't make it load in SU
                Error
                Top3D Studio
                  Follow the link under Requirements
                    j40
                    Now it works πŸ˜„
                    Top3D Studio
                    • P
                      Pherim
                      Can't believe that I dindn't find this earlier. This is exactly what I need, thank you!
                      • Chris FullmerC
                        Don't thank anyone til you try it πŸ˜„ It was a project that was started, and got alomst no-where. Thom got some of his parts working with the street generator, but that is about the only thing that works I think.
                        Post questions or comments here though. This is a project we are all keen on getting started again.
                        • P
                          Pherim
                          I tried it and it works perfectly fine for my purposes. I don't know about the other parts that were planned for this project but the Street Generator does exactly what I want it to do, so thank you again. πŸ˜„
                          • C
                            caleidos4d
                            Street Generator is FANTASTIC!!!! πŸ‘ Thanks!!
                            http://www.caleidos4d.it
                            • H
                              haynesc
                              I dont know why but I have installed the files but i get
                              "The CityGen's core files is not laoded. ensure you installed this plugin correctly"
                              I opened up the zips to both the core and streetgen and copied into Plugins
                              why is it not working ?
                                Because StreetGen goes into a subfolder of CityGen. The description has detailed info.
                                • iichiversiiI
                                  iichiversii
                                  Is there any clips on the net that show this working???
                                  Bring on the Rain...
                                  • H
                                    haynesc
                                    Ok iv moved the files into the correct location, boot sketchup and I get no error message, now how do i use the plugin ?
                                    • brookefoxB
                                      brookefox
                                      Apparently I'm being quite thick about this install. I've read the Requirements and notes several times and tried it several ways, each resulting in errors and failed loads.
                                      The 'module' subfolder is an actual folder into which street gen and other such modules are placed or just a stand-in name for street gen and such?
                                      city_gen_loader.rb goes under tools or plugins?
                                      My current:
                                      C:\Program Files (x86)\Google\Google SketchUp 8\Tools\city_gen_loader.rb
                                      and also since nothing works (is this duplication a problem, for the moment?)
                                      C:\Program Files (x86)\Google\Google SketchUp 8\Plugins\city_gen_loader.rb
                                      C:\Program Files (x86)\Google\Google SketchUp 8\Plugins\city_gen.rb
                                      C:\Program Files (x86)\Google\Google SketchUp 8\Plugins\citygen\street_gen.rb
                                      I have another instance of SU running, but that shouldn't interfere should it if I shut this one down to make install changes?
                                      Readme.txt from citygen modules subfolder:
                                      This is the module and support folder for CityGen.
                                      All .rb files in this folder is loaded by city_gen.rb.
                                      Make a new folder for eah module, and place a loading .rb here.
                                      Example:
                                      Plugins\city_gen.rb <- Core CityGen file
                                      Plugins\Gity_Gen\street_gen.rb <- Core Street Generator module file - loaded by city_gen.rb
                                      Plugins\City_Gen\Street_Gen\ <- Street Generator's support folder
                                      Tips appreciated.
                                      http://img109.imageshack.us/img109/3946/citygenstreetgenloaderr.jpg
                                      ~ Brooke
                                      • brookefoxB
                                        brookefox
                                        Parameters accept but do not generate 'feet', as far as I can tell. It would be nice if the model units were enforced, if they cannot be specified otherwise, and that settings could be remembered. Sorry if that is too obvious and has been said before.
                                        Any tips for this minor error in the street generated? I made sure the centerlines intersected. Green is the 60' ROW; gray is the 24' road itself, both generated from the blue centerline.
                                        http://img27.imageshack.us/img27/6039/citygenstreetgenerrors3.jpg
                                        ~ Brooke
                                        • brookefoxB
                                          brookefox
                                          By somewhat selectively scattering and deleting, I got it to load.... Pretty unsavory process, and though I'll hang my hat on the opinion that the install instructions ain't much clearer than mud, most folks don't seem to have a problem so my problem may indeed be me.
                                          Make a new folder for eah module, and place a loading .rb here. (Here where?)
                                          Example:
                                          It loads and the parameters can be set but but it does not work... generate does not generate, except on the parameters screen.
                                          Looks like I set params that were not workable. When I reopened TT's street model and used the default settings, streets were generated. When I tried the same on my curves the ruby console said generating but none were evident. I need to play with the params; too many segments probably that need to be dealt with by the plugin. I'll try to set to a large angle or no rounding, maybe weld the segments. Oops... it was working: I just had to click away. This was because the streets are created on layer '0' and I was on layer 'street centerlines' with other layers hidden when group editing. Perfectly reasonable.
                                          http://img19.imageshack.us/img19/8131/citygenstreetgenerrors1.jpg
                                          Ruby console:
                                          Error: #<NoMethodError: private method split' called for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/citygen/modules/street_gen.rb:536:in string_to_hash'
                                          C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/citygen/modules/street_gen.rb:118
                                          ~ Brooke
                                            The project was made quite some time ago. I, we, where rather newish to SketchUp plugins. The project was in early stages - still is because we've not had time to work on it. Information is not the best, as it was intended more for developers than users.
                                            The CityGen thread points to where the modules should be installed:
                                            Core and Installation Check
                                            This is the main file that centralise information and load the other modules.
                                            Modules are located in Plugins\CityGen\modules.
                                            So the Streetgen modules should go into that folder.
                                            I've been wishing to update this project, but it's been too far down on my priority list. 😞
                                            • 4 / 7
