    [Plugin] [CityGen] - Street Generator [WIP] (0.5.2a)
    124 Posts 37 Posters 137.8k Views 37 Watching
    • Chris FullmerC
      My understanding from the text is that any angle less than 30deg will not be rounded. But the image looks like its showing something different because the green 90deg is rounded, but the red 125deg angle is not. Neither is the white 145deg angle.
      So I think I am mis-reading something.
        Which angles are these? The illustration shows one 90 degrees and one 55. ❓
        The idea was to illustrate how it determines what's rounded; with a starting point in the white line with the arrow - coming in from the bottom. The Right edge (Red) breaks of in a 55 degree angle from the white - with a threshold of 60 degrees that means this corner won't be rounded. The left edge (Green) breaks off in a 90 degree angle - above the theshold; so it is rounded.
        How can this be better described / illustrated?
        • Chris FullmerC
          The angles that are labeled don't correspond to the sidewalk that will or won't be curved. I was thinking the angle threshold would correspond to the angles I am pointing at in the picture. I'm sure I'm just misunderstanding how the script is supposed to work.
            I see.
            The reason the angles differ, is because I based it off the centre line. You see the Red and Green arc? That's the angles I measure.
            I was thinking of the angles as in how much it rotated away from the centre line - like if you'd be driving down the street; how many degrees you'd have to turn.
            That's why the red and green radius is located by the centre line instead of the street edge. The colour coding was meant to illustrate which edge corner the angle related to.
            Interesting how you had a different approach to it. That's what I was curious of. It'd be good if more people could let me know how they'd expect it to work. What feels more intuitive.
            • soloS
              Not sure where to post this or even if it's relevent, if anyone wants to be part of this city gen app follow link: http://www.fileplanet.com/promotions/cities-xl/?_cmpid=fp161
              • JClementsJ
                JClements
                @thomthom said:
                Yea, I was thinking of maybe adding a brush painting tool. Where you can sweep. Or maybe have a large hit-radius.
                I think that would be a welcome addition to the plugin. I was having frustration issues when I tried to paint lines earlier for my demo too.... They are tricky little things to pin down with the bulky paintbucket.
                This is my first look at this forum.
                Painting edges; that was what initiated the request I posted a day or so ago here:
                http://forums.sketchucation.com/viewtopic.php?f=180&t=21125
                  Been a long break from this project. Other things has taken priority. Just wanted to upload the latest version I had on disk.
                  • T
                    tug
                    Hi Thom.-
                    here is me again, now back in Spain. I'd tested city generator and found some bugs in the use. I don't Know if it's due to the configuration (as I told you before) or is a real bug in the programming.
                    I'm using Skechup 7.1 with many plugins instaled and here the main bug I found:
                    I can't modify the parameters on "define streets", can't create news types or change the predef-values
                    best regards
                    jann
                      The define streets dialogue isn't finished yet. I meant to disable it before I uploaded, but forgot.
                      • T
                        tug
                        okis.. then
                        I'll wait for news...
                        best regards
                          j40
                          Hi Thom,
                          First, thank you for your work on this plugin.
                          Unfortunately I can't make it load in SU
                          Error
                          Top3D Studio
                            Follow the link under Requirements
                              j40
                              Now it works πŸ˜„
                              Top3D Studio
                              • P
                                Pherim
                                Can't believe that I dindn't find this earlier. This is exactly what I need, thank you!
                                • Chris FullmerC
                                  Don't thank anyone til you try it πŸ˜„ It was a project that was started, and got alomst no-where. Thom got some of his parts working with the street generator, but that is about the only thing that works I think.
                                  Post questions or comments here though. This is a project we are all keen on getting started again.
                                  • P
                                    Pherim
                                    I tried it and it works perfectly fine for my purposes. I don't know about the other parts that were planned for this project but the Street Generator does exactly what I want it to do, so thank you again. πŸ˜„
                                    • C
                                      caleidos4d
                                      Street Generator is FANTASTIC!!!! πŸ‘ Thanks!!
                                      http://www.caleidos4d.it
                                      • H
                                        haynesc
                                        I dont know why but I have installed the files but i get
                                        "The CityGen's core files is not laoded. ensure you installed this plugin correctly"
                                        I opened up the zips to both the core and streetgen and copied into Plugins
                                        why is it not working ?
                                          Because StreetGen goes into a subfolder of CityGen. The description has detailed info.
                                          • iichiversiiI
                                            iichiversii
                                            Is there any clips on the net that show this working???
                                            Bring on the Rain...
