    HELP! Problems with SketchUp + V-Ray textures
    renderpluginsextensions
    12 Posts 2 Posters 2.6k Views 2 Watching
      First of all: What version of VfSU do you use?
      These gaps between that faces you displace, are they connected?
      Are they facing the same direction?
      Have you ensured the Keep Continuity checkbox under the Displacement in the material?
      Do you have a small sample?
        RandG_LT
        V-Ray 7
        that faces are in component. On the 1-2nd images faces are only grouped. On the 3'rd image, only one way to activate displacement was: to make group for every face.
        Yes, when I enable that view with faces dirrection, all faces are white.
        I don't know exactly, I dont think so.. How to do this?
        Sample of what?
        Thanks for Your time πŸ˜‰
          @randg_lt said:
          V-Ray 7
          This is not a VFSU version number.
          The very first VfSU had no version number visible in the UI.
          VfSU SR1.0 and SR1.5 had the version number in the About section of the Option window - should say something like; 1.00.74 or 1.05.30
          The latest VfSU has the version number visible in Window -> Preferences -> Extensions -> V-Ray for Sketchup, something like 1.48.66
          @randg_lt said:
          that faces are in component. On the 3'rd image only one way to activate displacement was: to make group for every face.
          If you have multiple faces of the same displaced material you don't need to group each face. You only need to separate faces of different materials.
          @randg_lt said:
          Sample of what?
          A sample model, part of the model, where the problem occurs.
            RandG_LT
            My version is 01.05.30
            I't still doesnt work.. keep continuety is marked..
            Error 404 (Not Found)!!1
            (sketchup.google.com)
              I had a look at your sample.
              There are several issues:
              1. You have not isolated materials with the same material. There was faces connected with different materials. (top left comment in my attachemtn)
              2. Some faces had a displaced texture one the front, but another on its backside. (See the Entity Info window)
              3. Textures needs to line up properly between faces to avoid gaps. (See the circled corner, the map is aligned differently.) Note that you won't be able to merge between different materials.
              4. Your brick texture is very inefficient. It is a low res texture scaled up 2 or three times. You could see the supersized pixels in Photoshop. Which is why it appears blurred.
                RandG_LT
                So how I understood, that, theese gaps will be at that places where diferent textures connects?
                And how to remove texture from its backside?it puts automatically
                  And where the UV mapping does not line up. If you have two faces connected, with the same material, but on one face the texture is rotated differently you can get gaps.
                  Like you do with the front side. Paint the backside with default, or select the faces and use the Entity Info window.
                  Note that you can often get away by just using a bump map instead of displacement. Saves you the trouble of gaps. And saves rendering time.
                    RandG_LT
                    Finaly I managed to deal with fence textures..
                    Finaly the fence
                    Also, i would like to ask how to make smoth column? when I modelled, it somehow made itself to be with corners.
                    column with corners
                      Another bug in 1.05.30 - when there is material applied to outside a group/component, the smooth faces inside will not render smooth.
                      Solution: Only apply material to faces directly, not on any group/component.
                      With 1.05.30 it is always best to apply materials directly to faces, as applying materials to groups/components slows down the parsing immensely.
                        RandG_LT
                        And I think the last question πŸ˜„
                        How to make my windows reflect hdri?I made GI from bitmap, but when put same bitmap on "background" (which is down to GI) nothing happens to my render
                        Problems with HDRI background
                          You most probably have to increase the mulitplier. Normally I find that a value between 20-30 is ok. Maybe higher.
                          Taht is - when you are using the physical camera.
