    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
    • majidM Offline
      majid
      Persian translation:
      http://forums.sketchucation.com/viewtopic.php?f=320&t=28179
      thanx to tak2hata
      • mariochaM Offline
        mariocha
        Great stuff !
        Is there a way the dialog can remember it's position on the screen?
        I always expect it to reopen where I put it the previous time. πŸ˜„
        %(#008000)[Mario C.
          tak2hata
          Hi,All.
          I update fur plugin to verion1.3j.
          Increased translatable words for local language file.
          Franch translation by Daredevil.
          Persian translation by Majid.
          Spanish translation by Oxer.
          Thanks you very mush.
          @mariocha said:
          Great stuff !
          I want it ,too.
          I will probe to record the temporary position of dialog.
          Thanks.
          by TAK2HATA
            DIEGO-RODRIGUEZ
            Hi tak
            tanks for the update.
            only litle problem with translation.
            does not recognize the accents "Γ³" and the symbols "nΒΊ".
            by doing this?
            http://img638.imageshack.us/img638/1807/73807524.png
              It's best to avoid accented letters in web-dialogs and input boxes, as you have found they often won't work - use the equivalent unaccented letter, or try the html code sequence for the accented letter instead...
                tak2hata
                Hi,Diego,TIG,Oxer.
                Thanks for your helps.
                by TAK2HATA
                • Didier BurD Offline
                  Didier Bur
                  I can't get version 1.3j to work at all, even with units set to inches, feet, or whatever. 😲
                  Nothing starts, no console error message, no component created, no nothing...
                  @tak2hata: it would be nice if you gather the various translation files and deliver the plugin as a Zip, but most of all, is it possible that you handle the translation of the dialog boxes labels, lists, options, buttons, etc within the code ?
                  About UTF-8: Web dialogs and input boxes work well with special letters, just use a UTF-8 text editor (like Notepad++ for instance).
                  DB
                    This is a matter of character encoding.
                    SU uses UTF-8 encoding, which for letters outside ASCII comes out as multi-byte characters.
                    Ruby 1.8 doesn't care about encoding and treats a character as 1byte. Which means one has to be careful about manipulating strings.
                    But there is no problem displaying UTF-8 in webdialogs, one just has to ensure that you add a meta tag to the HTML header declaring you are using UTF-8 encoding.
                    If one where to not use accented letters when we would not be able to translate plugins.
                    As long as one stick with UTF-8 (which means your editor needs to be set to UTF-8 when you save your files and ensure to label your HTML markup then you are good to go. Oh year, of course be careful when manipulating strings.)
                      tak2hata
                      @didier bur said:
                      Hi,Didier.
                      Parameter value in dialog box,
                      if "Legnth" and "Rootwidth" are 0, then this plugin not work.
                      But there is an unsolved another problem in this state, too.
                      I tried saving file to UTF-8(without BOM) by using Notepad++.
                      Reopen the saved file,that format is displayed ANSI.
                      Using other editor makes same result.
                      I added letters with Japanese character ,and save UTF-8(without BOM).
                      That file format displayed ANSI as UTF-8.
                      fur_en v1.3j with UTF8(zipped)
                      Thanks.
                      by TAK2HATA
                        You have "Encode in UTF-8" selected under the Encoding menu?
                          Also, you need this within your HTML header:
                          <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
                            lapx
                            What's the diference between Fur plugin and Component instancing plugin, they seem very similar:?
                              First "Convert" to UTF-8 (without BOM) and then save it. If you set the "Encode" only, that's just for "viewing" the file in UTF-8 (at least that's how my Notepad++ seems to work).
                              And yes, you need to declare this encoding in the header.
                                DIEGO-RODRIGUEZ
                                gracias Oxer.
                                ahora funciona bien.
                                en cuanto a las unidades. lo probe en metro y centimetro, y aparentemente funciona bien.
                                yo uso windows xp sp3 en espaΓ±ol
                                saludos
                                • FletchF Offline
                                  Fletch
                                  First, thanks so much for sharing this GREAT plugin! It is very cool. πŸ˜„
                                  @lapx
                                  Component spray gives you much control over many things in spraying components... unfortunately, I've just discovered a few minutes ago... you can NOT use Component Spray tool on Vertical surfaces (someone please correct me if I'm wrong!)
                                  But I can NOT get an Ivy leaf I created to scatter using Component Spray tool on a vertical wall. πŸ˜•
                                  So I turned to the fur plugin... but... I have some questions...
                                  How do I get it to place the Ivy Leaf Components as shown in the image below "Ivy-Real" ❓
                                  There's no control that I can find to STOP the components from rotating randomly... can anyone correct me? I want all my Ivy leaves to basically be oriented the same way... only rotate slightly one direction or the other, like actual ivy leaves. I can not get Fur plugin to behave this way.
                                  Also, I can NOT get the components to be created with Fur Plugin so that they are oriented correctly... they "stand up" perpendicular to the surface, no matter what I seem to do in the fur settings. EDIT... modifying original component axis "fixes" this "stand up" issue. The Green and Red Positive axes are very important to the Fur Plugin.
                                  Also, I wish I could 'spray' like the Spray tool onto a vertical wall surface... I like the finite control and ability to add multiple leaf types into the Spray Tool... this functionality does not seem present yet in the Fur Plugin.
                                  Also, I wish I could define the physical distance of allowable 'overlap' between 2 similar components, sometimes you can end up with multiple instances basically on top of one another, while other areas of the canvas seem empty... I wish I could get the distribution more 'even'... one can spend hours deleting the overlapping components. πŸ˜•
                                  Fletch
                                    tak2hata
                                    Hi,Thomas and Gaieus.
                                    I will try it.
                                    Thank you.
                                    This plugin not good for something like Ivy real.
                                    Instead,How about doing like this in the case of wall faces.
                                    Ivy component like this
                                    Ivy Faced to World X axis.
                                    the leaf hung down.
                                    DirectionZ to large
                                    directionZ value in dialog increase large.
                                    and create.
                                    Thanks.
                                    by TAK2HATA
                                    • E Offline
                                      Eon79
                                      Hi there, this is an amazing plug-in, that will help immensely with my field of work, which is primarily landscapes.
                                      One query/question though, I'm having some bother with rendering a sample of grass (or any other type of shape I'm creating with the plug-in), the grass keeps to the boundary of the square in the Sketchup window, but seems to escape when I try to render it in V-ray (1.05.30), changing the default settings to anything else in v-ray doesn't seem to help or change the matter.
                                      Any help in finding a solution would be fantastic! Or any pointers on how you guys get such fantastic renders! Cheers!
                                        Does it still render like that if you reload the model?
                                        Can you post the model?
                                          arklandesign
                                          Gotta agree, and I'm sure Iam wanting it to do, more than it really can :O)
                                          Neither can I and I would love the pluginPlanting test #2.skp to be able to do this!!!.... Can it ?
                                          Ive been trying for the past day to populate a simple layout with equally spaced sprays of slightly rotated, evenly spaced plantings.... no luck so far (see attached file)....but luck, I'm sure, has little to do with it :O)
                                          • FletchF Offline
                                            Fletch
                                            tak2hata,
                                            Thank you! πŸ‘
                                            Once I installed the latest version, it worked perfectly.
                                            Renders well with Twilight Render... 3mins. πŸ˜„
                                            (I used 3 different Ivy leaves each placed once with fur plugin 800 components at a time.)
                                            Controlling the axis for the component is the hard part.
                                            Fletch
                                            • 11
                                            • 12
                                            • 13
                                            • 32
                                            • 33
                                            • 11 / 33
