    Translators
    57 Posts 6 Posters 7.1k Views 6 Watching
      Edge style = "Style d'Arêtes" in French version of SU 😉
      Display edges = "Affichages des arêtes"
      Profil = "Arêtes profilées"
      Depthcue = "Arêtes avec effet de profondeur"
      Extention = "Arêtes prolongées"
      French is some prolix 😆
      • Dan RathbunD
        Dan Rathbun
        Entity info = "Infos sur l'entité" ("s" is always written even when only one thing is selected 😄
        ..., I see that English gives never s to "Info"
        because it's the noun that is pluralized:
        "Entity" (singular)
        "Entities" (plural)
        "Info" is a short slang for "Information"
        "Information" is not pluralized, just as "Data" is not.
        I'm not here much anymore.
          Entity info = "Infos sur l'entité" ("s" is always writed even only one thing is selected 😄
          French is prudent, I see that English gives never s to "Info" English is foolhardy 💚
          "Arête" again when one edge is selected 😉
          "2 Arêtes" when you select 2 edges 😄
            This explain that 😉
            • Dan RathbunD
              Dan Rathbun
              @thomthom said:
              And what does the Entity Info window say when you select an Edge?
              I think TT wants to know what the object title says in French.
              (The dialog title is always the same.)
              If a single edge is selected, it says "Edge" (in English.)
              But when many objects are selected, the object title says (in English.): "n Entities" where n is the number selected.
              Pilou already said ...
              "Arête" [] when one edge is selected
              "2 Arêtes" when you select 2 edges [etc]
              Sp a Sketchup Edge is an 'Arête' in French, although a direct translation might give us 'Bord'... but it's not used in SUp...
              • Dan RathbunD
                Dan Rathbun
                This is an example of non-direct translation.
                Info de l'entité = Entity Info
                Infos sur l'entité = About the entity
                (If you capitalize the 'e' in entité, the Google translator gives "Entity Info" in English, for both phrases.)
                Propriétés de l'Entité = Entity Properties
                  Yes it's the fix's title on the French SU Window info box !
                  In SU English Title is also fixed!
                  Ps Entities is very elaborate, elements is more curent 😄
                  • Dan RathbunD
                    Dan Rathbun
                    Yes it's the fixed title on the French SU Window info box !
                    elaborate = formal?
                    We cannot call them element because the Ruby classname is Entity, and the Ruby collection of them is named Entities.
                    So we must be formal.
                      elaborate = literary 😄
                        Here's an example of a Norwegian translation problem:
                        Face = Overflate
                        Overflate is directly translated as Surface - as direct translation of Face doesn't sound good.
                        But, in SU there is a distinction between Face and Surface. If you click on a Face where the adjacent faces are separated by a soft edge, Entity Info then displays Surface.
                        That leads to a problem when translating to Norwegian, as one need to find a way to distinguish between Face and Surface., despite that both words really would have been translated as Overflate.
                        Using the MS search tool is of no futher help, as it only lists Overflate as translation for Face.
                          In English you can Inflate, Deflate, Reflate, Under-inflate and Over-inflate but not Overflate [though 'overflated' is sometimes used incorrectly to mean 'overinflated'] !
                          These are all generally to do with increasing or reducing something - like 'economic inflation, or to inflate a car-tyre' 😒
                          • Dan RathbunD
                            Dan Rathbun
                            Face = Overflate
                            In English the dimunitive of Face is Facet (considering 'Face' to be normative,) and the superlative is Surface. Athough SU doesn't seem to use all 3 heirarchal terms, you might use the dimunitive Fasett in Norwegian for Face, and the superlative Overflate for Surface, (if you don't think Flate sounds good for Face.)
                              hm... interesting.
                              Though Fasett is not something that I'd immediately accommodate with a geometric Face.
                              Flate is a nice short word. At first I wasn't really sure - thinking it had too much of the meaning of Overflate. But giving it a second thought - I like it.
                              Edge = Linje
                              Face = Flate
                              Surface = Overflate
                              Would be interesting to see if I can find some 3D software in Norwegian that uses similar terms.
                              Well Dan - you make a better judge of Norwegian than I. 😄
                                a quasi miracle 💚
                                English : French
                                face : face
                                facet : facette
                                surface : surface
                                • Dan RathbunD
                                  Dan Rathbun
                                  Naw... I'm just playing with the Google Translator:
                                  http://translate.google.com/?hl=en&tab=wT#en|no|
                                    Says something about my own grasp of my own language... 😳
                                    • Dan RathbunD
                                      Dan Rathbun
                                      a quasi miracle 💚
                                      English : French
                                      face : face
                                      facet : facette
                                      surface : surface
                                      Not really a miracle, Pilou.
                                      All 3 words came into English, from the French (probably after the Norman conquest,) and originally came into French from Latin.
                                        Advantage of the invasions 😉
                                          The English are [or were?] great with coping with invaders - they'd come here and within a couple of generations we would have absorbed them and pinched their best ideas, food and words and made them ours.
                                          The invaders end up becoming English - look at the Vikings - they took over great swathes of Britain but within generations has become very localised and left few words except in place-names - perhaps it was something in the Scandinavian psyche - the Norsemen who invaded northern France became the Normans, and spoke in French within a few years... Then they invade England and within a few generations everyone is speaking an updated form of English with lots of borrowed French words, rather than French with a few old English words left in !
                                          Most other countries usually get invaded and the original inhabitants change to become very like the invaders.
                                          Like when we invaded other countries we didn't absorb many of their ways [I know curry is our favourite food though and we did borrow words from everywhere... the walking-aid 'zimmer-frame' isn't German as it sounds but Mongolian !] - generally we converted the 'aborigines' [=those there from the beginning] to be more like us !
                                          The upshot is the English language will many many more words than any other - mainly because we borrowed words to make new ones, with nuances [itself a borrowed word !] rather than using just adjectives and so on... It makes translation difficult - as Thomthom says - 'face' and 'surface' are different things but would probably be translated as the same word in Norwegian - the NO translation has to 'force' the use of an alternative word that wouldn't perhaps be used in daily speech...
                                            While I lived in England there was a couple of Norwegian words where I found English lacked the nuances. But it was rare.
                                            One example would be
                                            Jeg liker deg = I like you
                                            Jeg er glad i deg = ??
                                            Jeg elsker deg = I love you
                                            In English love is ambiguous - or so my impression is. The word is used in a great number of context.
                                            While in Norwegian, elsker (love) is used much more sparsely - and we use glad i which signifies great affection, more than just liking, but less than love.
                                            • 2 / 3
