    Translators
    57 Posts 6 Posters 7.1k Views 6 Watching
    • Chris FullmerC
      But on a co-planar surface, it could be an edge between materials. So in that sense, even on a co-planar surface, it could still be an edge to something 😄
        Not necessarily, could be separating two co-planar faces of the same material...
          To most users an 'edge' borders a 'face', and a 'line' is an 'edge' without a 'face'.
          But then in SUp a curve is a polyline and isn't necessarily curved at all !
          It's all very confusing...
          Being picky my ExtrudeEdgesByRails should be called say ExtrudeCurveProfilesByCurveRails or ExtrudePolylineProfilesByPolylineRails ? BUT 'curves' are made of 'edges', as 'lines' are 'edges' too in SUp-speak 😒
          • Dan RathbunD
            Dan Rathbun
            We might introduce the term "seam" as this special case of edge.
            thots?
            I'm not here much anymore.
              I wasn't thinking that we change the existing terms in SU. Plugins should use the terms used by Sketchup for consistency. But it was more of a reflection on how computer terms are used. And when translating, when one feel that the word is lacking in the target language, then basing it on the original might not be the best. As in the case of an Edge - it's not always representing the edge of something. So when transfering that to a new language, one might want to think twice.
              Back to the case of French, and the term Edge - isn't there an French version of SU? What does it use?
                And what does the Entity Info window say when you select an Edge?
                  Edge style = "Style d'ArĂȘtes" in French version of SU 😉
                  Display edges = "Affichages des arĂȘtes"
                  Profil = "ArĂȘtes profilĂ©es"
                  Depthcue = "ArĂȘtes avec effet de profondeur"
                  Extention = "ArĂȘtes prolongĂ©es"
                  French is some prolix 😆
                  • Dan RathbunD
                    Dan Rathbun
                    Entity info = "Infos sur l'entitĂ©" ("s" is always written even when only one thing is selected 😄
                    ..., I see that English gives never s to "Info"
                    because it's the noun that is pluralized:
                    "Entity" (singular)
                    "Entities" (plural)
                    "Info" is a short slang for "Information"
                    "Information" is not pluralized, just as "Data" is not.
                      Entity info = "Infos sur l'entitĂ©" ("s" is always writed even only one thing is selected 😄
                      French is prudent, I see that English gives never s to "Info" English is foolhardy 💚
                      "ArĂȘte" again when one edge is selected 😉
                      "2 ArĂȘtes" when you select 2 edges 😄
                        This explain that 😉
                        • Dan RathbunD
                          Dan Rathbun
                          I think TT wants to know what the object title says in French.
                          (The dialog title is always the same.)
                          If a single edge is selected, it says "Edge" (in English.)
                          But when many objects are selected, the object title says (in English.): "n Entities" where n is the number selected.
                          Pilou already said ...
                          "ArĂȘte" [] when one edge is selected
                          "2 ArĂȘtes" when you select 2 edges [etc]
                          Sp a Sketchup Edge is an 'ArĂȘte' in French, although a direct translation might give us 'Bord'... but it's not used in SUp...
                          • Dan RathbunD
                            Dan Rathbun
                            Entity info = "Infos sur l'entité"
                            This is an example of non-direct translation.
                            Info de l'entité = Entity Info
                            Infos sur l'entité = About the entity
                            (If you capitalize the 'e' in entité, the Google translator gives "Entity Info" in English, for both phrases.)
                            Propriétés de l'Entité = Entity Properties
                              Yes it's the fix's title on the French SU Window info box !
                              In SU English Title is also fixed!
                              Ps Entities is very elaborate, elements is more curent 😄
                              • Dan RathbunD
                                Dan Rathbun
                                Yes it's the fixed title on the French SU Window info box !
                                elaborate = formal?
                                We cannot call them element because the Ruby classname is Entity, and the Ruby collection of them is named Entities.
                                So we must be formal.
                                  elaborate = literary 😄
                                    Here's an example of a Norwegian translation problem:
                                    Face = Overflate
                                    Overflate is directly translated as Surface - as direct translation of Face doesn't sound good.
                                    But, in SU there is a distinction between Face and Surface. If you click on a Face where the adjacent faces are separated by a soft edge, Entity Info then displays Surface.
                                    That leads to a problem when translating to Norwegian, as one need to find a way to distinguish between Face and Surface., despite that both words really would have been translated as Overflate.
                                    Using the MS search tool is of no futher help, as it only lists Overflate as translation for Face.
                                      In English you can Inflate, Deflate, Reflate, Under-inflate and Over-inflate but not Overflate [though 'overflated' is sometimes used incorrectly to mean 'overinflated'] !
                                      These are all generally to do with increasing or reducing something - like 'economic inflation, or to inflate a car-tyre' 😒
                                      • Dan RathbunD
                                        Dan Rathbun
                                        Face = Overflate
                                        In English the dimunitive of Face is Facet (considering 'Face' to be normative,) and the superlative is Surface. Athough SU doesn't seem to use all 3 heirarchal terms, you might use the dimunitive Fasett in Norwegian for Face, and the superlative Overflate for Surface, (if you don't think Flate sounds good for Face.)
                                          hm... interesting.
                                          Though Fasett is not something that I'd immediately accommodate with a geometric Face.
                                          Flate is a nice short word. At first I wasn't really sure - thinking it had too much of the meaning of Overflate. But giving it a second thought - I like it.
                                          Edge = Linje
                                          Face = Flate
                                          Surface = Overflate
                                          Would be interesting to see if I can find some 3D software in Norwegian that uses similar terms.
                                          Well Dan - you make a better judge of Norwegian than I. 😄
                                            a quasi miracle 💚
                                            English : French
                                            face : face
                                            facet : facette
                                            surface : surface
                                            • 2 / 3
