    Translators
    57 Posts 6 Posters 6.2k Views 6 Watching
      @tig said:
      Damn ! 😳
      French v Spanish 😒
      That's why we need translators... 😉
      Of course in English we have 'border' = the edge of something [page/country/etc] - which is not applicable as a 'line' or 'edge' in our contexts...
      We also have 'arête/arete' = a geographical feature, a sharp sloping ridge found between two glaciers, glaciated valleys or tarns - which I think is from 'knife-edge' ?
      Is Edge really the best term? Just thinking, since and Edge can appear on a co-planar surface. Not really and "edge" then?
      Doesn't geometry books talk about Lines (infinite) and Line Segments (finite)? Of couse "Line Segment" is more awkward to juggle around in the UI. But it's this kind of things one need to think about when translating, does the word in the original language fit? Getting caught up too much in the terms of the source language is not a good thing.
      • Chris FullmerC Offline
        But on a co-planar surface, it could be an edge between materials. So in that sense, even on a co-planar surface, it could still be an edge to something 😄
          Not necessarily, could be separating two co-planar faces of the same material...
          • TIGT Online
            To most users an 'edge' borders a 'face', and a 'line' is an 'edge' without a 'face'.
            But then in SUp a curve is a polyline and isn't necessarily curved at all !
            It's all very confusing...
            Being picky my ExtrudeEdgesByRails should be called say ExtrudeCurveProfilesByCurveRails or ExtrudePolylineProfilesByPolylineRails ? BUT 'curves' are made of 'edges', as 'lines' are 'edges' too in SUp-speak 😒
            • Dan RathbunD Offline
              Dan Rathbun
              We might introduce the term "seam" as this special case of edge.
              thots?
              I'm not here much anymore.
                I wasn't thinking that we change the existing terms in SU. Plugins should use the terms used by Sketchup for consistency. But it was more of a reflection on how computer terms are used. And when translating, when one feel that the word is lacking in the target language, then basing it on the original might not be the best. As in the case of an Edge - it's not always representing the edge of something. So when transfering that to a new language, one might want to think twice.
                Back to the case of French, and the term Edge - isn't there an French version of SU? What does it use?
                  And what does the Entity Info window say when you select an Edge?
                    Edge style = "Style d'Arêtes" in French version of SU 😉
                    Display edges = "Affichages des arêtes"
                    Profil = "Arêtes profilées"
                    Depthcue = "Arêtes avec effet de profondeur"
                    Extention = "Arêtes prolongées"
                    French is some prolix 😆
                      Dan Rathbun
                      Entity info = "Infos sur l'entité" ("s" is always written even when only one thing is selected 😄
                      ..., I see that English gives never s to "Info"
                      because it's the noun that is pluralized:
                      "Entity" (singular)
                      "Entities" (plural)
                      "Info" is a short slang for "Information"
                      "Information" is not pluralized, just as "Data" is not.
                        Entity info = "Infos sur l'entité" ("s" is always writed even only one thing is selected 😄
                        French is prudent, I see that English gives never s to "Info" English is foolhardy 💚
                        "Arête" again when one edge is selected 😉
                        "2 Arêtes" when you select 2 edges 😄
                          This explain that 😉
                            Dan Rathbun
                            I think TT wants to know what the object title says in French.
                            (The dialog title is always the same.)
                            If a single edge is selected, it says "Edge" (in English.)
                            But when many objects are selected, the object title says (in English.): "n Entities" where n is the number selected.
                            Pilou already said ...
                            "Arête" [] when one edge is selected
                            "2 Arêtes" when you select 2 edges [etc]
                            Sp a Sketchup Edge is an 'Arête' in French, although a direct translation might give us 'Bord'... but it's not used in SUp...
                              Dan Rathbun
                              This is an example of non-direct translation.
                              Info de l'entité = Entity Info
                              Infos sur l'entité = About the entity
                              (If you capitalize the 'e' in entité, the Google translator gives "Entity Info" in English, for both phrases.)
                              Propriétés de l'Entité = Entity Properties
                                Yes it's the fix's title on the French SU Window info box !
                                In SU English Title is also fixed!
                                Ps Entities is very elaborate, elements is more curent 😄
                                  Dan Rathbun
                                  Yes it's the fixed title on the French SU Window info box !
                                  elaborate = formal?
                                  We cannot call them element because the Ruby classname is Entity, and the Ruby collection of them is named Entities.
                                  So we must be formal.
                                    elaborate = literary 😄
                                      Here's an example of a Norwegian translation problem:
                                      Face = Overflate
                                      Overflate is directly translated as Surface - as direct translation of Face doesn't sound good.
                                      But, in SU there is a distinction between Face and Surface. If you click on a Face where the adjacent faces are separated by a soft edge, Entity Info then displays Surface.
                                      That leads to a problem when translating to Norwegian, as one need to find a way to distinguish between Face and Surface., despite that both words really would have been translated as Overflate.
                                      Using the MS search tool is of no futher help, as it only lists Overflate as translation for Face.
                                      • TIGT Online
                                        In English you can Inflate, Deflate, Reflate, Under-inflate and Over-inflate but not Overflate [though 'overflated' is sometimes used incorrectly to mean 'overinflated'] !
                                        These are all generally to do with increasing or reducing something - like 'economic inflation, or to inflate a car-tyre' 😒
                                          Dan Rathbun
                                          Face = Overflate
                                          In English the dimunitive of Face is Facet (considering 'Face' to be normative,) and the superlative is Surface. Athough SU doesn't seem to use all 3 heirarchal terms, you might use the dimunitive Fasett in Norwegian for Face, and the superlative Overflate for Surface, (if you don't think Flate sounds good for Face.)
                                            hm... interesting.
                                            Though Fasett is not something that I'd immediately accommodate with a geometric Face.
                                            Flate is a nice short word. At first I wasn't really sure - thinking it had too much of the meaning of Overflate. But giving it a second thought - I like it.
                                            Edge = Linje
                                            Face = Flate
                                            Surface = Overflate
                                            Would be interesting to see if I can find some 3D software in Norwegian that uses similar terms.
                                            Well Dan - you make a better judge of Norwegian than I. 😄
                                            • 2 / 3
