    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
      Some other plugin can still add to that - so it would not be an idication of FredoLib is the cause. To determine that one must disabled FredoLib and see if you still get an increase - if so, then there's another plugin doing this.
        I get 332 before AND 332 afterwards... πŸ˜„
        How about making an observer script that watches the number of commands a la code snippet, and when it approaches /reaches 1000 it pops up a dialog warning you that you have too many commands loaded and might like to sort out your plugins or suffer 'grayed' context-menu items...
        It would be nice it it could purge unused commands... but how ? ObjectSpace.garbage_collect ?
        • fredo6F Offline
          The normal behavior should be that Commands objects are released as any othe Ruby object (This is what I thought by the way). From what jhauswirth reported, it seems that each UI::Command creates an underlying Windows static object which might itself not be released, even if the UI::Command object would be garbaged out by Ruby.
            rv1974
            This gray fade was extremely annoying. What a relief
              prismcnd
              ran said script with LibFredo.rb disabled, returned a value of 293. ran said script with LibFredo6 enabled and returned said value of 428. Right-click menu is greyed out right from the start with Libfredo.rb enabled. As in before I've had a chance to create anything. Ken reports the same result from this post ( http://forums.sketchucation.com/viewtopic.php?f=323&t=11212&start=285 )
              For the record I would like to say I really appreciate you guys looking into this. I used fredo's/your tools all the time and am really having a hard time remembering a workflow before I had these wonderful tools at my disposal.
              here is the full report from the ruby console after i reenabled the script and ran the command in the ruby console
              complete ruby console readout
              β€œWhatever the mind of man can conceive and believe, it can achieve.” -W.Clement Stone (American best selling Author and Founder of Combined Insurance Co (now a part of Aon Corp.), 1902-2002)
                Have you tried removing LibFredo before installing this new version? To ensure all files are updated?
                  Sir
                  just upgraded to the latest toolset, on loading skp this error came up
                  Error Loading File ZLoader__FredoScale.rb
                  uninitialized constant LibFredo6::Traductor
                    Did you get the latest version of the Lib and software rubies and keep them in their respective folders as you extracted them from their zip files...
                      Sir
                      ok, now it seems none of the toolbars are loading but no error messages popup
                      interestingly in the preferences > extensions absolutly nothing is showing
                        Sounds like you have some files in the wrong places - is this on PC or Mac ?
                        Copy/Paste this line into the Ruby Console + <enter>
                        Sketchup.find_support_file("Plugins")
                        It returns the path that all of the .rb files OR sub-folders should go into - they should be in the same relationship as they are in the zip file - i.e. usually a 'loader' .rb and then a related sub-folder full of other files - that folder goes into Plugins with its contents unchanged.
                          Sir
                          yeah its mac, and they're in the correct place. i guess ill wipe the folder and reinstall them all.
                            rogueparker
                            Im getting the same error message as above, but on a vista pc, I've tried the install 3 times. any ideas?
                              Are the files installed as described in the first post?
                                prismcnd
                                Well I would really like to thank you Tom and Tig, after a couple of days i found the culprit, apparently i had a couple of older versions of the LibFredo6 filefolder in my plugins directory and after removing them everything is back to normal. Stupid mistake and thank you for your help.
                                  thmnka84
                                  Could someone please give me more detailed info about how to install lebfredo6 34 c?
                                  Can get it running...
                                  all the best
                                  AA
                                    all the best
                                    AA
                                    Did you look at the screenshot of the first post? Are your files located like that?
                                      chouaibcl65
                                      thank youu
                                        thebestvip84
                                        thks alot ,u r my hero πŸ˜„
                                        • W Offline
                                          wyatt
                                          I figured out what was happening regarding the errors I was getting last week. The problem was organizer.rb. For the LibFredo6 plugins to work, both LIBFREDO6_Dir_34 and FREDOSCALE_Dir_20 must be added to the SmustardOrganizerExcludeFolders.txt file. As far as I can tell that does not effect the functionality of Fredo's scripts. Not sure if anyone else uses Organizer, but now you know.
                                          Wyatt
                                            bobbybobbob
                                            @exodiaangel said:
                                            do i need to be a special type of member or something to download the roundcorners thing? coz i am SO confused πŸ˜• ❓
                                            HELP PLEASE!!
                                            its not you, its this site... if there was just a "DOWNLOADS" section....
                                            I'm trying as well. still haven't found it....i registered, but now the spot that previously said that files are only for members is nowhere to be found.
                                            also confusing which topic is the "top" topic. fear not, just keep searching this site, and hopefully i'll find it before i loose interest in rounding my corners...funny thing is, i had this plugin last year, but lost it some how...so i guess i went through all this before! sheesh.
                                            but at least i'm begininning to see that Fredo6 is "the one".
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 109
                                            • 110
                                            • 29 / 110
