    [Obsolete] TT_Lib (1.2.0) โ€” 31 August 2010
    30 Posts 10 Posters 41.9k Views 10 Watching
      [mod=Obsolete:6avlxrgm]This library is no longer used by any of my plugins.[/mod:6avlxrgm]
      This is not a standalone plugin!
      You only need to download this package if a plugin states it requires TT_Lib (Previously Plugin Manager).
      Overview
      This is a library of reusable code to better organize and manage plugins that implement's its features. This first release only have a UI Manager. More feature will come later. (With no promises to what or when.)
      Features
      UI Manager (1.0.0)
      Provides a UI to add and remove menu and toolbar items.
      Cheat Sheet (1.1.0)
      Creates a list of commands and the keyboard commands assigned.
      Common Code Snippets
      Includes some commonly used methods.
      Documentation
      SDK is being written. Coming soon to a forum near you! (Sorry - heavy changes has postponed this.)
      Installation
      You can remove the old TT_Plugin_Manager folder.
      Extract the TT_Lib folder inside the .zip file into your Sketchup Plugins folder.
      "Same procedure as last yea'!"
      Version 1.2.0
        Hi Thom,
        Is this tool for those developing scripts or for users to manage plugins that incorporate this tool?
        Sorry for the dumbass question? But Ruby and me are like peanuts and chewing gum. We don't mix!
          Both.
          I found the need to make a UI manager for my Selection Toys plugin. And I figured I might want to do the same for other plugins. So I made this single library which multiple plugins can use without having to rewrite the same code.
          It also means that any plugin that implements the UI Manager in this package will allow the users to add/remove items from the menus and toolbars. Note, it#s only add and remove, not move things freely around.
          Not much for end users here unless a plugin told them to download this package.
            DIEGO-RODRIGUEZ
            thomthom, excuse my ignorance.
            As I run this tool.
            not find a shortcut
              As I run this tool.
              not find a shortcut
              Please read the description at the top.
                No rapport with your ttmenu but I have this message error โ“
                  [attachment=0:3824u1wp]<!-- ia0 -->tterror.jpg<!-- ia0 -->[/attachment:3824u1wp]
                  TT_PLuginmanager was the old name of TT_Lib, which an old version of Selection Toys used. Download an updated version of both.
                  Why did you suddenly get that error now?
                    Because I have this message for many months but not taken the time to managed it ๐Ÿ˜ณ
                    Works fine now except the Window UI that I can't scroll inside!
                    As don't possible scrolling I can't have all lines show even in resize the window ๐Ÿ˜‰
                    You have a lot things inside ! I can Open Close some item like Tools Menu, Context Menu ๐Ÿ’š
                    So I can see 22 vertical icones
                      What IE version do you have installed?
                        Can't you resize the window by dragging the bottom edge down ?
                          Yes I have not IE7 ๐Ÿ˜’
                          Normally no need ๐Ÿ˜‰
                          about the "what page" ๐Ÿ˜‰
                          page = screen ๐Ÿ˜ณ
                          I you can place your "TT plugs" on the end of the top heros Script (as like in a sea port) ๐Ÿ’š
                          that will be terrific โ˜€
                          Now you are on the end of the second page (screen) ๐Ÿ’š
                          As SU has not "page down" just the black triangle pressed, that is very painful! ๐Ÿ˜ฎttt.jpg
                            That you see is my full screen on my 17 inch !
                            So don't resize more! ๐Ÿ˜‰
                              I mean resize the dialog's window ! ๐Ÿ˜’
                                You still have IE6?
                                And a million web-developers cried out in pain!
                                Update your IE to IE8. Even if you don't use IE as your browser - there are many applications that use the IE platform, such as SU with it's webdialogs.
                                As for the position of the menu item - .rb files are loaded in order of their file names. rename tt_0000_menu.rb to something like 0000_tt_menu.rb and I think you're good to go.
                                  Yes it's the disavantages of the monopoly system if you don't want use it! ๐Ÿ˜„
                                  That is the first time that I am blocked ๐Ÿ˜‰
                                  I will try your 000 number but for respect of your previous friends I will give a more hight number! ๐Ÿ˜„
                                  Sea spirit ๐Ÿ˜‰
                                  http://www.comhonfleur.com/images/vieux_greements-_1.jpg
                                    If you sort the files in the Plugins folder by name you can see the load order. Name the file to whatever you want to control where it appears on the menu, just make sure it loads before the rest of the tt_*.rb files.
                                      Thx for the precision! ๐Ÿ˜Ž
                                        Starting a file name with # loads before any numbers/letter start...
                                          arjunmax09
                                          how can i use this plugin to manage my plugins?? ๐Ÿ˜’ I have no idea how to use this plugin...plz help
                                          when you fail at something....you haven't really failed...you've found one way the thing will not work out
                                            You don't - it a shared library that some of my plugins use.
