    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    [Obsolete] TT_Lib (1.2.0) โ€” 31 August 2010
    30 Posts 10 Posters 42.2k Views 10 Watching
      DIEGO-RODRIGUEZ
      thomthom, excuse my ignorance.
      As I run this tool.
      not find a shortcut
        As I run this tool.
        not find a shortcut
        Please read the description at the top.
          No rapport with your ttmenu but I have this message error โ“
            [attachment=0:3824u1wp]<!-- ia0 -->tterror.jpg<!-- ia0 -->[/attachment:3824u1wp]
            TT_PLuginmanager was the old name of TT_Lib, which an old version of Selection Toys used. Download an updated version of both.
            Why did you suddenly get that error now?
              Because I have this message for many months but not taken the time to managed it ๐Ÿ˜ณ
              Works fine now except the Window UI that I can't scroll inside!
              As don't possible scrolling I can't have all lines show even in resize the window ๐Ÿ˜‰
              You have a lot things inside ! I can Open Close some item like Tools Menu, Context Menu ๐Ÿ’š
              So I can see 22 vertical icones
                What IE version do you have installed?
                  Can't you resize the window by dragging the bottom edge down ?
                    Yes I have not IE7 ๐Ÿ˜’
                    Normally no need ๐Ÿ˜‰
                    about the "what page" ๐Ÿ˜‰
                    page = screen ๐Ÿ˜ณ
                    I you can place your "TT plugs" on the end of the top heros Script (as like in a sea port) ๐Ÿ’š
                    that will be terrific โ˜€
                    Now you are on the end of the second page (screen) ๐Ÿ’š
                    As SU has not "page down" just the black triangle pressed, that is very painful! ๐Ÿ˜ฎttt.jpg
                      That you see is my full screen on my 17 inch !
                      So don't resize more! ๐Ÿ˜‰
                        I mean resize the dialog's window ! ๐Ÿ˜’
                          You still have IE6?
                          And a million web-developers cried out in pain!
                          Update your IE to IE8. Even if you don't use IE as your browser - there are many applications that use the IE platform, such as SU with it's webdialogs.
                          As for the position of the menu item - .rb files are loaded in order of their file names. rename tt_0000_menu.rb to something like 0000_tt_menu.rb and I think you're good to go.
                            Yes it's the disavantages of the monopoly system if you don't want use it! ๐Ÿ˜„
                            That is the first time that I am blocked ๐Ÿ˜‰
                            I will try your 000 number but for respect of your previous friends I will give a more hight number! ๐Ÿ˜„
                            Sea spirit ๐Ÿ˜‰
                            http://www.comhonfleur.com/images/vieux_greements-_1.jpg
                              If you sort the files in the Plugins folder by name you can see the load order. Name the file to whatever you want to control where it appears on the menu, just make sure it loads before the rest of the tt_*.rb files.
                                Thx for the precision! ๐Ÿ˜Ž
                                  Starting a file name with # loads before any numbers/letter start...
                                    arjunmax09
                                    how can i use this plugin to manage my plugins?? ๐Ÿ˜’ I have no idea how to use this plugin...plz help
                                    when you fail at something....you haven't really failed...you've found one way the thing will not work out
                                      You don't - it a shared library that some of my plugins use.
                                        arqalexanderog
                                        I get this error apology
                                        Error loading file config.rb
                                        No such file to load - TT_Lib / loading file json.rbError config_ini.rb
                                        No such file to load - TT_Lib / loading file core.rbError inputbox.rb
                                        No such file to load - TT_Lib / loading file gui.rbError tt_selection_toys.rb
                                        No such file to load - TT_Lib / loading file core.rbError ui_manager.rb
                                        No such file to load - TT_Lib / loading file core.rbError window.rb
                                        I was not missing,
                                        I cooperation could you please remove me from this little problem
                                          How did you install it?
                                          You should have a TT_Lib file in your Plugins folder, and all those files you mention in that error you got should be inside that.
                                            arjunmax09
                                            I was advised by KXI that this plugin was formerly known as plugin manager and could be used to manage junk plugins. How can I do this?
