    SCF slow?
    64 Posts 12 Posters 6.2k Views 12 Watching
      d12dozr
      firefox 3.6.3 as well
      http://goo.gl/f7ooYh
      • X Offline
        xrok1
        @xrok1 said:
        anyone who's having trouble try this. click whatever link (reply, new posts...) then hit your browsers stop loading then click the link again. seems to work for me. ??!!! ๐Ÿ˜• very strange.
        i was wrong, i don't think this actually works. ๐Ÿ˜ข
        โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
          bonzai3d support
          I does work -- but only sometimes. If it takes more than 5 seconds, ESC and F5...
          Explore * Design * Deliver
          http://www.bonzai3d.com
          Version 2.5 Now Available!
            hm... maybe a traceroute might give some hints?
            http://network-tools.com/default.asp?prog=trace&host=www.sketchucation.com
            Note that a traceroute takes much longer than a normal request, but maybe there are some big spikes that can give a hint.
            C;\Users\Thomas>ping www.sketchucation.com
            Pinging www.sketchucation.com [93.186.178.42] with 32 bytes of data;
            Reply from 93.186.178.42; bytes=32 time=58ms TTL=52
            Reply from 93.186.178.42; bytes=32 time=56ms TTL=52
            Reply from 93.186.178.42; bytes=32 time=57ms TTL=52
            Ping statistics for 93.186.178.42;
                Packets; Sent = 4, Received = 4, Lost = 0 (0% loss),
            Approximate round trip times in milli-seconds;
                Minimum = 56ms, Maximum = 58ms, Average = 57ms
            C;\Users\Thomas>
            • mitcorbM Offline
              mitcorb
              I got logged off while I was preparing a comment.
              I have been having a similar problem to xrok1.
              IE and Firefox both.
              Contacted Gaieus by email and discussed it.
              Reported broken website with Firefox under Help menu.
              I am in North America, but well over 1000miles from xrok1.
              Many of you are much closer and are not having these issues.
              Having to click more than once on navigation buttons.
              Getting logged out in middle of posting.
              Difficulty getting logged on.
                d12dozr
                I don't understand this, but maybe it will help...I did it twice because sometimes I don't have any trouble.
                  and regular pings?
                    bonzai3d support
                    two tries...
                    • Mike LuceyM Offline
                      Mike Lucey
                      Tavi, is having a look at things. I will direct him to this thread in case he has not noticed it. BTW, I am up to date with hosting charges ๐Ÿ˜„
                      The whole thing seems erratic ๐Ÿ˜’
                      Mike
                      • X Offline
                        xrok1
                        ๐Ÿ˜ข i used "www.forums.sketchucation.com"
                        • X Offline
                          xrok1
                          thats the same thing. esc is stop and f5 is reload. ๐Ÿ˜‰
                            bonzai3d support
                            RIGHT -- If it takes more than 5 seconds, do that.
                            If that takes more than 5 seconds, do it again.
                            And again.
                            And again if necessary...
                            • X Offline
                              xrok1
                              well, i can't stand this anymore! ๐Ÿ˜ก i'll check back every couple days to see if you guys have it worked out. ๐Ÿ˜ข
                                How long does a normal ping take?
                                  bonzai3d support
                                  8 tries later:
                                  (EDIT -- To clarify, the pings occur right away -- the posting of the image took the 8 tries...)
                                    Mine is an average of 56ms. Seeing how this affects some, I wonder if it could be something about the particular route for each user... Is it solely SCF being slow? Absolutely no other site?
                                      d12dozr
                                      That is correct.
                                      A Ping.
                                        bonzai3d support
                                        Absolutely no other sites.
                                        If the page will load, it basically loads fine (in the first few seconds). But if the page will not load, then it hangs for a few minutes before timing out.
                                        Which is why we suggested canceling the action if it does not work in the first few seconds, and trying again. Normally after retrying a few times like this, the page will then load...
                                        If you are having this problem, also remember to copy your posting before clicking Submit -- or else you will lose it if you wait for the page to time out...
                                          johnsenior1973
                                          Yes.
                                            As Mike said, Tavi's looking into this but he said he had no problems at all either so it is hard for him to troubleshoot something he cannot see/experience. Nevertheless I hope there is a real reason for this, we can find it and that it can be fixed.
                                            • 3 / 4
