SCF slow?
Wired T1 here with regularly over 1000 kb/s download speeds.
No problems with any other sites (and even YouTube works for us).
anyone who's having trouble try this. click whatever link (reply, new posts...) then hit your browsers stop loading then click the link again. seems to work for me. ??!!!
very strange. -
hm... what browsers are you using?
firefox 3.6.3, but its the same in IE.
firefox 3.6.3 as well
very strange.i was wrong, i don't think this actually works.
I does work -- but only sometimes. If it takes more than 5 seconds, ESC and F5...
hm... maybe a traceroute might give some hints?
http://network-tools.com/default.asp?prog=trace&host=www.sketchucation.com
Note that a traceroute takes much longer than a normal request, but maybe there are some big spikes that can give a hint.
C;\Users\Thomas>ping www.sketchucation.com Pinging www.sketchucation.com [93.186.178.42] with 32 bytes of data; Reply from 93.186.178.42; bytes=32 time=58ms TTL=52 Reply from 93.186.178.42; bytes=32 time=56ms TTL=52 Reply from 93.186.178.42; bytes=32 time=57ms TTL=52 Reply from 93.186.178.42; bytes=32 time=57ms TTL=52 Ping statistics for 93.186.178.42; Packets; Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds; Minimum = 56ms, Maximum = 58ms, Average = 57ms C;\Users\Thomas>
I got logged off while I was preparing a comment.
I have been having a similar problem to xrok1.
IE and Firefox both.
Contacted Gaieus by email and discussed it.
Reported broken website with Firefox under Help menu.
I am in North America, but well over 1000miles from xrok1.
Many of you are much closer and are not having these issues.
Having to click more than once on navigation buttons.
Getting logged out in middle of posting.
Difficulty getting logged on. -
I don't understand this, but maybe it will help...I did it twice because sometimes I don't have any trouble.
and regular pings?
two tries...
Tavi, is having a look at things. I will direct him to this thread in case he has not noticed it. BTW, I am up to date with hosting charges
The whole thing seems erratic
Mike
thats the same thing. esc is stop and f5 is reload.
RIGHT -- If it takes more than 5 seconds, do that.
If that takes more than 5 seconds, do it again.
And again.
And again if necessary...
well, i can't stand this anymore!
i'll check back every couple days to see if you guys have it worked out.
How long does a normal ping take?
8 tries later:
(EDIT -- To clarify, the pings occur right away -- the posting of the image took the 8 tries...)
Mine is an average of 56ms. Seeing how this affects some, I wonder if it could be something about the particular route for each user... Is it solely SCF being slow? Absolutely no other site?
With your input, this post could be even better ๐
