    SCF slow?
    64 Posts 12 Posters 6.2k Views 12 Watching
    • X Offline
      xrok1
      anyone who's having trouble try this. click whatever link (reply, new posts...) then hit your browsers stop loading then click the link again. seems to work for me. ??!!! ๐Ÿ˜• very strange.
      โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
        hm... what browsers are you using?
        • X Offline
          xrok1
          firefox 3.6.3, but its the same in IE. ๐Ÿ˜ข
            d12dozr
            firefox 3.6.3 as well
            http://goo.gl/f7ooYh
            • X Offline
              xrok1
              i was wrong, i don't think this actually works. ๐Ÿ˜ข
                bonzai3d support
                I does work -- but only sometimes. If it takes more than 5 seconds, ESC and F5...
                Explore * Design * Deliver
                http://www.bonzai3d.com
                Version 2.5 Now Available!
                  hm... maybe a traceroute might give some hints?
                  http://network-tools.com/default.asp?prog=trace&host=www.sketchucation.com
                  Note that a traceroute takes much longer than a normal request, but maybe there are some big spikes that can give a hint.
                  C;\Users\Thomas>ping www.sketchucation.com
                  Pinging www.sketchucation.com [93.186.178.42] with 32 bytes of data;
                  Reply from 93.186.178.42; bytes=32 time=58ms TTL=52
                  Reply from 93.186.178.42; bytes=32 time=56ms TTL=52
                  Reply from 93.186.178.42; bytes=32 time=57ms TTL=52
                  Ping statistics for 93.186.178.42;
                      Packets; Sent = 4, Received = 4, Lost = 0 (0% loss),
                  Approximate round trip times in milli-seconds;
                      Minimum = 56ms, Maximum = 58ms, Average = 57ms
                  C;\Users\Thomas>
                  • mitcorbM Offline
                    mitcorb
                    I got logged off while I was preparing a comment.
                    I have been having a similar problem to xrok1.
                    IE and Firefox both.
                    Contacted Gaieus by email and discussed it.
                    Reported broken website with Firefox under Help menu.
                    I am in North America, but well over 1000miles from xrok1.
                    Many of you are much closer and are not having these issues.
                    Having to click more than once on navigation buttons.
                    Getting logged out in middle of posting.
                    Difficulty getting logged on.
                      d12dozr
                      I don't understand this, but maybe it will help...I did it twice because sometimes I don't have any trouble.
                        and regular pings?
                          bonzai3d support
                          two tries...
                          • Mike LuceyM Offline
                            Mike Lucey
                            Tavi, is having a look at things. I will direct him to this thread in case he has not noticed it. BTW, I am up to date with hosting charges ๐Ÿ˜„
                            The whole thing seems erratic ๐Ÿ˜’
                            Mike
                            • X Offline
                              xrok1
                              ๐Ÿ˜ข i used "www.forums.sketchucation.com"
                              • X Offline
                                xrok1
                                thats the same thing. esc is stop and f5 is reload. ๐Ÿ˜‰
                                  bonzai3d support
                                  RIGHT -- If it takes more than 5 seconds, do that.
                                  If that takes more than 5 seconds, do it again.
                                  And again.
                                  And again if necessary...
                                  • X Offline
                                    xrok1
                                    well, i can't stand this anymore! ๐Ÿ˜ก i'll check back every couple days to see if you guys have it worked out. ๐Ÿ˜ข
                                      How long does a normal ping take?
                                        bonzai3d support
                                        8 tries later:
                                        (EDIT -- To clarify, the pings occur right away -- the posting of the image took the 8 tries...)
                                          Mine is an average of 56ms. Seeing how this affects some, I wonder if it could be something about the particular route for each user... Is it solely SCF being slow? Absolutely no other site?
                                            d12dozr
                                            That is correct.
                                            A Ping.
                                            • 3 / 4
