    SCF slow?
    64 Posts 12 Posters 7.8k Views 12 Watching
    • B
      bonzai3d support
      two tries...
      Explore * Design * Deliver
      http://www.bonzai3d.com
      Version 2.5 Now Available!
      • Mike LuceyM
        Mike Lucey
        Tavi, is having a look at things. I will direct him to this thread in case he has not noticed it. BTW, I am up to date with hosting charges 😄
        The whole thing seems erratic 😒
        Mike
        • X
          xrok1
          😢 i used "www.forums.sketchucation.com"
          • X
            xrok1
            @bonzai3d support said:
            @xrok1 said:
            @xrok1 said:
            anyone who's having trouble try this. click whatever link (reply, new posts...) then hit your browsers stop loading then click the link again. seems to work for me. ??!!! 😕 very strange.
            i was wrong, i don't think this actually works. 😢
            I does work -- but only sometimes. If it takes more than 5 seconds, ESC and F5...
            thats the same thing. esc is stop and f5 is reload. 😉
            • B
              bonzai3d support
              RIGHT -- If it takes more than 5 seconds, do that.
              If that takes more than 5 seconds, do it again.
              And again.
              And again if necessary...
              • X
                xrok1
                well, i can't stand this anymore! 😡 i'll check back every couple days to see if you guys have it worked out. 😢
                  How long does a normal ping take?
                  • B
                    bonzai3d support
                    8 tries later:
                    (EDIT -- To clarify, the pings occur right away -- the posting of the image took the 8 tries...)
                      Mine is an average of 56ms. Seeing how this affects some, I wonder if it could be something about the particular route for each user... Is it solely SCF being slow? Absolutely no other site?
                        d12dozr
                        That is correct.
                        A Ping.
                        http://goo.gl/f7ooYh
                        • B
                          bonzai3d support
                          Absolutely no other sites.
                          If the page will load, it basically loads fine (in the first few seconds). But if the page will not load, then it hangs for a few minutes before timing out.
                          Which is why we suggested canceling the action if it does not work in the first few seconds, and trying again. Normally after retrying a few times like this, the page will then load...
                          If you are having this problem, also remember to copy your posting before clicking Submit -- or else you will lose it if you wait for the page to time out...
                            johnsenior1973
                            Yes.
                            • GaieusG
                              As Mike said, Tavi's looking into this but he said he had no problems at all either so it is hard for him to troubleshoot something he cannot see/experience. Nevertheless I hope there is a real reason for this, we can find it and that it can be fixed.
                              • mitcorbM
                                mitcorb
                                I recall the other day, that Java updates were available for my machine. Did anyone else download any of these updates?
                                I have no idea whether Sketchucation utilizes Java, but could this be an issue?
                                Like Jean Lemire says: Just ideas.
                                • GaieusG
                                  No, there's no Java here at all.
                                  • mitcorbM
                                    mitcorb
                                    Gaieus:
                                    Thanks.
                                    Like Forrest Gump says: "One less thang".
                                    • X
                                      xrok1
                                      did you guys find something? its running better than ever today!!!!!!
                                      • mitcorbM
                                        mitcorb
                                        I can confirm improved performance on this session. No more click, wait, click again, wait.
                                        I would be interested to know what got tweaked.
                                        -and in a moment, we will see if I timed out.- submit
                                        EDIT smooth as silk
                                          d12dozr
                                          Yup, speedier than I ever remember it! 👍 👍
                                            johnsenior1973
                                            I wouldn't say I've noticed the speed increases others are reporting, but I certainly haven't had any problems with pages loading recently.
                                            • 3 / 4
