    30 60 Degrees Perspektif
    24 Posts 8 Posters 12.0k Views 8 Watching
      Come on, Wodan! You know I cannot script!
      πŸ˜„
      But indeed, if this is only like a snap as you say, good idea for a plugin. πŸ‘
      (Any takers?)
      • Wo3DanW Offline
        Wo3Dan
        @tig said:
        This will do it......
        Thanks TIG. And you didn't even take a break for coffee? Amazing how you guys put these things together!!! All my attempts to grasp ruby have been without success so far. Gaieus, we are in the same corner.
        Now let's see if I can get it to work to see what it does to my PC.
        Wo3Dan
          Remember that after setting the axo or iso view you can only zoom in/out and pan, orbiting will mess up the view.
          So it's a good idea to set the axo or iso then pan/zoom to the required view and save it as a Scene tab. Then you can mess around orbiting etc to make the model, but return to the axo or iso view by clicking its Scene tab...
          β˜€
            This will do it
            ### 2010 (c) TIG
            ### paste code into a file in Plugins folder as 'axo+iso.rb'
            ### sets camera to 30/60 axonometric view and zooms extents
            require 'sketchup.rb'
            def axo3060
              model=Sketchup.active_model
              view=model.active_view
              camera=view.camera
              eye=Geom;;Point3d.new(-25.3259,-5.00502,463.851)
              target=Geom;;Point3d.new(10.9614,15.9032,41.225)
              up=Geom;;Vector3d.new(0.862238,0.496811,0.0986113)
              perspective=false
              newcamera=Sketchup;;Camera.new(eye,target,up,perspective)
              view.camera=newcamera
              Sketchup.send_action("viewZoomExtents;")
            ### sets camera to 30/30 isometric view and zooms extents
            def iso3030
              camera=view.camera
              eye=Geom;;Point3d.new(-219.18,-239.658,258.471)
              target=Geom;;Point3d.new(72.869,52.1777,-23.5562)
              up=Geom;;Vector3d.new(0.398992, 0.398701, 0.825738)
              perspective=false
            To use it type axo3060 in the Ruby Console - it sets the camera and zooms extents...
            The axes are set at 30/60 degrees [G/R], perspective is 'off' and the verticals [B] are vertical...
            OR type iso3030 in the Ruby Console and the axes are set at 30/30 degrees [G/R] etc...
            πŸ€“
              πŸ‘
              Tanks TIG - and of course, Wodan, too.
              • david_hD Offline
                david_h
                I didn't realize he was asking for Axonometric. I thought it was just a standard 30 /60 perspective. My bad.
                  IF he did then your method is dead easy... just draw guide or line parallel to a side and rotate it 60 degrees... stand you camera on the line and everything is as you showed... πŸ€“
                    d_r_i_x
                    i've been looking for something like this for quite some time now. Works a treat.
                    Would it also be possible to have it show a 45 45 axonometric view?
                    http://www.proceduralstrategies.net
                      It would be axo4545 and also axo6030 - however they are the end of a list right now... 😞
                      • E Offline
                        elaohu
                        in addition to what i mentioned, the ruby file by Tif, the red and green lines are right, but the vertical blue line is wrong (the view is wrong), but i dont know how to fix that???? anybody??
                        just need to change the vertical view in axo like the one in iso in the code, but i dont know how
                        • E Offline
                          elaohu
                          i download TIF's ruby code, it works perfect for the green and red axis, but
                          • honoluludesktopH Offline
                            honoluludesktop
                            Latecomers wild guess. Do you need SU to be in "parallel projection view"?
                              Please explain how it is 'wrong' - a screen-shot could help... πŸ˜•
                                smhbrv
                                I did it. Thank you πŸ˜„
                                But Only, axo3060 and iso3030 view ?
                                Can we make more choice ?
                                Axo4545 etc... ?
