    [Plugin] Edge Tools
    211 Posts 74 Posters 327.9k Views 74 Watching
      @simon le bon said:
      Hi Thomas,
      You are incredibly productive and innovative.
      One more time, this one promise to be strongly useful (I'm reminding the number of times this tools was missing to me)..
      my thanks and my respect,
      simon.
      Thanks for your kind words.
      Co-linear Edges, or Curve Simplification?
      • P
        Panga
        Thanks for this new tool !! I'm sure i'll find cases in which it'll be usefull.
        • simon le bonS
          simon le bon
          Co-linear ๐Ÿ‘ ๐Ÿ˜‰
          • PixeroP
            Pixero
            Wow, I've totally missed this. Great plugin.
            • mknorrM
              mknorr
              I am sure this is a stupid question but where does one get this plugin? None of the links here take me anywhere.
                At the end of the first post in the thread. Look for the cookie. ๐Ÿ˜‰
                • mknorrM
                  mknorr
                  See, it was a stupid question ๐Ÿ˜ณ
                  Thank you Sir
                    Update v1.1.0
                    New:
                    • Divide Face (See video in main post.)
                      That is very good! ๐Ÿ‘ ๐Ÿ˜Ž
                        autarchos
                        ThomThom - the divide face plugin is amazing. i'm redrawing thousands of parcels from the 1960s in a city and this has really just made tedious work about 10 times faster. you're a god!
                          ๐Ÿ˜„ Glad you liked it. It came about because I realised I was repeatedly drawing guidelines offset from and edge, draw an edge, erase guideline. Wanted to merge this into one operation. I often do this while working on faรงades.
                            Very practical for have your own grid! ๐Ÿ˜Ž
                            Here with Protrude by Jim Foltz and Random Painter by Chris Fullmer
                            @ Thomthom : have you in your Selection Toys or other plugs something that select only oriented faces external? (with any orientation ("White faces")
                            for this object for example โ“
                            external.skp
                              hm... no...
                              this one is a thinker...
                              • G
                                gavvy
                                ๐Ÿ˜ž oh no .....
                                what a XX tool ๐Ÿ‘
                                • G
                                  gavvy
                                  ๐Ÿ˜ฒ
                                  Tomtom ,can i have your msn-account-name??
                                    hm... no...
                                    Because after this will easy to have a uniform object well oriented! โ˜€
                                      hm... no...
                                      If the purpose is to orient all faces, then right click a face and choose Orient Faces.
                                        No, it's not so simple ๐Ÿ˜‰
                                        Try with the object linked above!
                                        You must select by hand all different aeras and make different Reverse before Orient ๐Ÿ˜ฎ
                                        Easy with this object but for a more complex, it's a mess! ๐Ÿ˜’
                                          Ah, yea, I see now that there are a couple of problem areas. The problem here is knowing programmatically what is "outside".
                                            "Outside" is not given by face's sign of a normal?
                                            • 11
                                            • 2 / 11
