    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.8m Views 202 Watching
    • bagateloB
      bagatelo
      It would be interesting we could draw our own shapes and to save at an own library. Thanks for the great plugins. You are de best. (not the beast 😆 )
      • kenK
        ken
        New version v1.6b, 8 May 10available.
        It allows to use the replication feature (by double-click) for shapes which are drawn perpendicular to edges.
        See small video in main post http://forums.sketchucation.com/viewtopic.php?f=323&t=11212#p76625
        I have loaded v1.6b. My make group or component in the contents or edit menu is grayed out. When I change the name of ZLoader__OnSurface.rb to ZLoader__OnSurface.ken, not allowing this plugin to load on start up, the contents and edit menu to make group or components is back.
        Nothing the in the ZLoader__OnSurface.rb indicates it has been upgrade to May 8.
        And I have update all the other files as required.
        Ken
        • fredo6F
          Ken
          Can you check the About menu of ToolsOnSurface. It should indicate the version and date.
          • kenK
            ken
            Ken
            Here is the about menu for TOS
            Thanks for the quick response
            Ken
            • fredo6F
              Ken,
              On which type of selected geometry do you observe the menu grayout?
              If it is on San or on a single group or component, this may be a normal behavior in SU, which assumes you do not need to make a component or group from a single component or group.
              • kenK
                ken
                Ken,
                I was using a simple rectangle. Selected face and lines, not able to make group or component. Tried again with two rectangles, selected all, not able to group or make component. With ZLoader__OnSurface.rb not loaded, able to group rectangle or rectangles.
                Note, the difference in the two screen shots, is ZLoader__OnSurface.rb being allowed to load or not allowed to load.
                Ken
                  Ken can you enter this into the console:
                  l=[];ObjectSpace.each_object {|x| l.push x if x.class==UI::Command } ; l.length
                  Try with it unloaded before right click
                  Try with it unloaded after right click
                  Loaded before right click
                  Loaded after right click
                  • kenK
                    ken
                    Tom
                    Attached is the required screen shots.
                    Top is always before right click, bottom is after right click.
                    Thanks to Fredo and Tom for their help.
                    Ken
                      hm... this appear to be caused by something else then. As the number has not reached 1000.
                      • fredo6F
                        Ken,
                        This bug is very strange.
                        Would you mind to make the same test with another of my scripts (say FredoScale or Roundcorner). This will help me to determine whether this is specific to ToolsOnSurface or this comes from the shared library LibFredo6. I can't reproduce the bug myself.
                        Also, on the pictures you posted, I noticed that the cursor is a large white arrow. Are you popping up the context menu from with the SU Selection tool or from within another tool?
                        Thanks again
                        • dermotcollD
                          dermotcoll
                          Fredo / TIG
                          I was extracting to a different folder - just copied the files to the folder indicated by TIG and it works no problem. Thanks for a great plugin and super help for getting me going with it.
                          When you burn your arse - you gotta sit on the blisters!!
                          • fredo6F
                            @dermotcoll said:
                            Fredo / TIG
                            By the way, do you experience the same problems as Ken does (see his above message) about the menu gray out syndrom?
                            • dermotcollD
                              dermotcoll
                              Not as yet but then again I am not as accomplished a modeller as these other guys and probably am not asking the plug in to do any thing too difficult. I use your Fredoscale plugin on a daily basis but rarely use the TOS one. I have tried to replicate the grey menu but have not been able to do so as yet. Sorry for the late reply.
                              • fredo6F
                                [Important Upgrade version 1.6c, 15 May 10]
                                I just realized that in v1.6b, I have introduced a ennoying bug in the inferencing of the tool LineOnSurface.
                                This is fixed in this new release 1.6c.
                                See main post for download: http://forums.sketchucation.com/viewtopic.php?p=76625#p76625
                                • C
                                  chouaibcl65
                                  thank youuuuuu
                                  • keea1111K
                                    keea1111
                                    HI,
                                    I am trying to get this to install on my new computer and it isn't coming up for me. I have dropped both rb file as well as the tools file into the plugins folder, open sketchup and am not finding it. Is there a companion plug in needed for this, or am I missing something else. thanks so much for the help..Keea
                                    KEEA
                                    • massimoM
                                      massimo Moderator
                                      Hi Keea, have you installed LibFredo as well? Btw have you read the PDF quickcard (2. installation and configuration)?
                                        mavie
                                        After reading his installation notes and carefully loading all the components for Fredo's great Tools on Surface plugin (about 4 times), I got my error messages down to just this one upon opening SketchUp after install:
                                        Error Loading File Zloader_OnSurface.rb unititialized constant Traductor:Plugin
                                        I reinstalled Zloader (the freshest version, I believe) and have the latest version of his plugin, but I would love to find out what I'm doing wrong. MacBookPro, Snow Leopard, and I cleaned out all the bits of Fredo's older versions, etc.
                                        Thanks in advance for any advice,
                                        Mave
                                          mavie
                                          Okay, yes. Woke up fresh, tried another 2 installs and I'm good to go! Such a cool plugin. Merci bien Fredo!
                                          • H
                                            hgdn
                                            Is anyone please pointing it out for me of what is not right as I have tried a lot of times to install but still not get it? I got files LIBFREDO6_Dir_34, FREDOSCALE_Dir_20, TOS_Dir_16 and 3 rb(s) LibFredo6.rb, ZLoader__FredoScale.rb, ZLoader__OnSurface.rb located in Program Files\Google\Google SketchUp 7-pro\Plugins.. . The Fredoscale is fine and working icons shown but Tools on Surface icon(s) is not and in Preferences I saw it there and I checked that box and restart computer but still not shown. Oh one more thing that I never had installed any of those files before (3 files) so is there any relation of old and new files installed that makes it does not work or any missing things I don't know??? please tell me as I am tired of trying so many times...Thanks!
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 31
                                            • 32
                                            • 15 / 32
