    [Plugin] CleanUp
    974 Posts 217 Posters 1.3m Views 217 Watching
      Gaieus: This update is for you. Made it investigate the UV's before merging.
      Not that it is very strict, the UV values for either vertex of the edge has to be identical for each face connected to it before it merges. This means there might be cases where it visually looks like they should merge, but doesn't. They should merge is you position a material on one face and use the dropper to paint other adjacent faces.
      To turn of this feature just enable the Ignore UV's.
      Note that this is pretty fresh code that hasn't been tested well. (Only very quickly.) So please investigate the model after using the tool and report any unexpected behaviour. (Please most sample model as that will make debugging much easier.)
      • E
        Ern
        Very handy,
        Now all the cookies are yours!
        • GaieusG
          @thomthom said:
          Gaieus: This update is for you. Made it investigate the UV's before merging...
          Thanks a bunch, Thom, πŸ‘
          I will definitely check it out. Lately I have needed this function really badly.
            j40
            Thanks a lot Thom !! πŸ‘ This is one of the greatest plugins.
            Top3D Studio
              Version 2.0.0
              • Supports ThomThom's Menu
              • Persistent preferences.
              • Settings for global and local cleanup synced.
              • Repairs split edges. (Based on Carlo Roosen's Repair Broken Edges)
              • Removes duplicate faces.
              • Fixes duplicate component definition names.
              • Runs Validity Check at the end.
              "Duplicate faces" are faces where multiple faces share the same set of vertices. The plugins should also be able to detect smaller faces overlapping larger faces.
              • GaieusG
                Downloading... πŸ˜‰
                  Hi Thom,
                  thanks for the update πŸ‘
                  Incredible tool! Should be mentioned in the Visual Index thread
                  Rich
                    Jim
                    Yep, this is the best cleanup script available.
                    I know the choice of user interface is limited, but I'm not a fan of nested menus. I was wondering if a webdialog interface would work. So then I could have a single shortcut that would bring up the "cleanup" dialog showing the options available, and then "run" from there. Maybe? Someday?
                    Edit: "best" is an under-statement - it's important and essential.
                      Yes - that is exactly what I have in mind. The options are growing so a better UI is required. However, I'm trying to prioritise Vertex Edit. This has been a necessary distraction because I need it at work.
                      So my plans for v2 that did not make it will be postponed to v3:
                      • Merge Identical and similar materials
                      • Axis adjustments
                      • Find identical groups/components (If I can find a good algorithm for this.)
                        For this webdialog UI is a must in order to be friendly to use.
                      Thanks for letting me know how to activate the Fix Model function - in some cases it appears that erasing big bulk of edges messes up SUæs Loops. Even though everything looks fine in SU. So it was good to force that test after a cleanup.
                      • soloS
                        This is one of my most cherished ruby's, thank you for improving it and making it an invaluable tool.
                        • GaieusG
                          @thomthom said:
                          ...So my plans for v2 that did not make it will be postponed to v3:
                          • Axis adjustments
                          Now these definitely sound incredible! Can hardly wait to see them in here!
                          • G
                            gilad75
                            Thanks a lot, you created magic!
                            πŸ‘
                            • H
                              Harbor
                              THanks a lot man, It should be one of the best plugin of SU
                                davery
                                Thanks. Greatly appreciated.
                                • Z
                                  Zacchia
                                  Can someone please explain what i do when i purge? Do i loose something in model? Please explain with easy words 😎 thanks!
                                    When you add components, materials, styles, layers it remains stored in your model file, even after you are not using that resource any more.
                                    Purge cleans out any unused component, material, layer or style in your model. That keeps the file size down and you don't have to browse through long lists of needless unused items.
                                    • Z
                                      Zacchia
                                      Ah... i understand now, thanks a lot!
                                        superian111
                                        that plug in changed my life you are my freaking hero well done thanks
                                          dedmin
                                            risoto
                                            sorry about this stupid question but where can i download this cleanup plugin. i am unable to find the download link!
                                            Risoto
                                            • 48
                                            • 49
                                            • 7 / 49
