    [Plugin] CleanUp
    974 Posts 217 Posters 1.1m Views 217 Watching
      Version 2.0.0
      • Supports ThomThom's Menu
      • Persistent preferences.
      • Settings for global and local cleanup synced.
      • Repairs split edges. (Based on Carlo Roosen's Repair Broken Edges)
      • Removes duplicate faces.
      • Fixes duplicate component definition names.
      • Runs Validity Check at the end.
      "Duplicate faces" are faces where multiple faces share the same set of vertices. The plugins should also be able to detect smaller faces overlapping larger faces.
        Downloading... πŸ˜‰
          Hi Thom,
          thanks for the update πŸ‘
          Incredible tool! Should be mentioned in the Visual Index thread
          Rich
            Jim
            Yep, this is the best cleanup script available.
            I know the choice of user interface is limited, but I'm not a fan of nested menus. I was wondering if a webdialog interface would work. So then I could have a single shortcut that would bring up the "cleanup" dialog showing the options available, and then "run" from there. Maybe? Someday?
            Edit: "best" is an under-statement - it's important and essential.
              Yes - that is exactly what I have in mind. The options are growing so a better UI is required. However, I'm trying to prioritise Vertex Edit. This has been a necessary distraction because I need it at work.
              So my plans for v2 that did not make it will be postponed to v3:
              • Merge Identical and similar materials
              • Axis adjustments
              • Find identical groups/components (If I can find a good algorithm for this.)
                For this webdialog UI is a must in order to be friendly to use.
              Thanks for letting me know how to activate the Fix Model function - in some cases it appears that erasing big bulk of edges messes up SUæs Loops. Even though everything looks fine in SU. So it was good to force that test after a cleanup.
              • soloS Offline
                This is one of my most cherished ruby's, thank you for improving it and making it an invaluable tool.
                  @thomthom said:
                  ...So my plans for v2 that did not make it will be postponed to v3:
                  • Axis adjustments
                  Now these definitely sound incredible! Can hardly wait to see them in here!
                    gilad75
                    Thanks a lot, you created magic!
                    πŸ‘
                    • H Offline
                      Harbor
                      THanks a lot man, It should be one of the best plugin of SU
                        davery
                        Thanks. Greatly appreciated.
                        • Z Offline
                          Zacchia
                          Can someone please explain what i do when i purge? Do i loose something in model? Please explain with easy words 😎 thanks!
                            When you add components, materials, styles, layers it remains stored in your model file, even after you are not using that resource any more.
                            Purge cleans out any unused component, material, layer or style in your model. That keeps the file size down and you don't have to browse through long lists of needless unused items.
                            • Z Offline
                              Zacchia
                              Ah... i understand now, thanks a lot!
                                superian111
                                that plug in changed my life you are my freaking hero well done thanks
                                  dedmin
                                    risoto
                                    sorry about this stupid question but where can i download this cleanup plugin. i am unable to find the download link!
                                    Risoto
                                      Here you go, click this!
                                      It's the very first post of this thread. In fact all plugins will be found on the first post of their respective threads
                                        gagabe9
                                        very usful tools, wait for longtime, thanks
                                          Crevard
                                          now i can finally work my things out thanks to you , merging from archicad is not a problem anymore , u rock !!!!!!! πŸ‘ πŸ‘ πŸ‘
                                          • Chris FullmerC Offline
                                            @thomthom said:
                                            Armed with more info from Simone Nicolo I now have a better method for detecting coplanar faces - the same method Sketchup use. I think it's 100% reliable. No more messing about with tolerances.
                                            Highly recommended update!
                                            Hey Thom, I am having some tolerance problems on a script I'm working on. Comparing Point3d objects. Do you have some insight that might help me make my comparisons more stable?
                                            • 48
                                            • 49
                                            • 7 / 49
