    [Plugin] Extrude Edges by Rails to Lattice
    73 Posts 25 Posters 103.4k Views 25 Watching
      Ok I see what do you mean πŸ˜„
      But that is absolutly not the same in French πŸ˜‰
      That don't exist with this liquid for these meanings! πŸ’š
      A very familiar slang can be "vous vous foutez de moi" = you exagerate, you overpass the limits, you take me for a fool...
      (or "tu te fous de moi" between best friends )
      A convoluted way of saying someone is making a bad joke at your expense is to say
      More elegant : "Vous vous moquez du monde", "Vous ne manquez pas d'air", "vous me prenez pour un pigeon, une andouille" etc... πŸ˜†
      "Vous me faites chier" is the ultimate, insurmontable, for something who is absolutly obstrusive disturbing in the univers of the person! πŸ˜‰
      But very slanguy language indeed! πŸ˜’
        So, we both learn how to cuss better in our respective languages !
        πŸ˜‰
        So, don't mess with me dude ! πŸ‘Š
        • majidM
          majid
          it is greeeeaaaaattttt TIG. you are killing me slowly πŸ‘ πŸ‘ πŸ‘ grrreaaat. thanx πŸ‘
          • simon le bonS
            simon le bon
            I don't see how I could do the same with else tools
            Maybe 2 faces + path + FFD(or fredoscale) πŸ˜‰
            Hi Pilou πŸ˜‰
            First, using "Extrude Edges by Rails to Lattice"
            1. I had kept the perfect control on the general shape ( I think it's not possible at such degree with FFD or even with Fredoscale )
              2)I had presently used a simple grid of rails, so I could do it by hand (erasing unwanted in the skinned shape). I can't imagine to achieve the same on a real large number of curves without the help of EEbRtL ..
            Secondly, you are right for Kirill "2 faces + path" which plays in the same playground with "ExtrudeEdgesByFaces"
            *simon
            • simon le bonS
              simon le bon
              @tig said:
              Here's an update http://forums.sketchucation.com/viewtopic.php?p=242239#p242239
              It now has 'Diagonals' as an option.
              This new tool is already but still growing an absolute "must have". Thank you so much Tig!
              Reversing the order of picking the Rails swaps the direction of the diagonals.
              very elegant solution indeed πŸ˜‰
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_017_th.jpg
              +++simon
                IF I well understand "diagonals" is only for wire πŸ˜‰
                  robert111
                  simn le bon , very nice job , how did you do to have this form plz
                  can you make tutto ?
                    There's a new version of EEbyRailsToLattice in the zipped set.
                    The change is to the way the Line only versions are Grouped...
                    • N
                      numerobis
                      AWESOME!!! Thank You very much for ANOTHER very helpful tool!!!
                      • simon le bonS
                        simon le bon
                        Thank you Robert,
                        very simple.
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_018_th.jpg
                        RE: take care to carefully place the component axis (the blue axis is going to follow the curves)
                        Then You will need Component Stringer from (our wellknown very nice fellow) Chris Fullmer
                        It is recommended to apply a shortcut to this plugin :_ Window/ Preferences/ Shortcuts: for example Alt+c
                        Because we have now to apply it one by one to each diagonal curve.
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_019_th.jpg
                        that's it!
                        πŸ˜‰ simon
                          Have you some easy trick for make faces with the 2 diagonals lattices?
                            If the profiles and rails are parallel [copied etc] the diagonal lines are not needed for face forming - hence the prompt to remove them.
                            BUT if you make a lattice of the two sets of diagonals [regrouped and exploded], then they do not make coplanar quads and so they can't take faces - of course by adding a diagonal to a quad it will face, but then you have then gone 'full circle' and might as well have used plain EEbyRails in the first place !
                            So diagonal 'diamond' lattices won't take faces.
                            This is about as near as you can get - make a quarter using EEbyRails, copy the mesh to one side, Scale -1 to mirror the diagonals and overlay the two so the 'diamonds' form, then manually erase the unneeded orthogonal lines to get the diagonal lattice - note it must have some horizontals to let it 'bend' over. Rotate-Copy x3 to form the whole. Now use Windowizer to add the frames/panes ?Capture.PNG
                            • E
                              eddy
                              cool plugin
                              thanks, thanks,thanks. πŸ‘ πŸ‘
                              @ ++ Eddy
                                @TIG : THX for the precision! 😎
                                But for this sort of thing prefer this maybe more easy πŸ˜‰
                                I have used Windowiser by Rick Wilson and this little useful plug of Multiple face Offset by Remus, Selection Toy by Thomthom and of course your Inverse Selection! πŸ‘
                                http://forums.polyloop.net/picture.php?albumid=23&pictureid=655
                                  There's an updated zipped set available http://forums.sketchucation.com/viewtopic.php?p=242239#p242239
                                  All lingvo files have been updated.
                                    maximas
                                    please i would like to cretae an effect like this on my facade how can i do this.??
                                    http://img.archiexpo.fr/images_ae/photo-g/mur-rideau-en-panneaux-aluminium-et-verre-129841.jpg
                                    can u do an small tutorial of the use of the plugin??? thanks
                                    • G
                                      goldenma
                                      Thanks TIG, truly marvelous tool!!
                                      one question, though - is there a function to generate 3d geometries on the diagonals? the same effect of "extrude edges by rail by face" but for diagonals.
                                      right now i can get the diagonal lines using "extrude---to lattice", but i'll have to "follow me" each line with a profile.
                                      thanks a lot!
                                        Use the EEby lattice tool to make a mesh of only the diagonals as lines - one of the options [no 3D yet].
                                        Now you have a set of grouped curves == the diagonals.
                                        You might want to do a bit of un-grouping/regrouping now...
                                        We'll now use EEbyFace...
                                        Draw a face as a profile on the 'flat', in the same entities set as these curves [remember the face's Y=up when extruded].
                                        Use the preselected face and curves with EEbyFace - you should get the face used to form an extrusion with each of the diagonal curve's as a path, in turn...
                                        • G
                                          goldenma
                                          Thanks TIG! that's a great tool that i overlooked. it's a lot better than doing follow me on every curve. 😍
                                          • C
                                            Crevard
                                            i was just wondering how i could make a lattice dome with this plugin πŸ˜’ and btw thx for these awesome plugins !!!!!!
                                            • 3 / 4
