    [Plugin] Extrude Edges by Rails to Lattice
    73 Posts 25 Posters 102.5k Views 25 Watching
      I will examine that πŸ˜„
      I hope that can be input in the ruby console 😳
      For the French line does it possible to have the original
      because seems the translator gives a very exotic result πŸ˜†
      something like that! 🀣
      http://www.fotosearch.fr/bthumb/LIF/LIF139/NU106007.jpg
      • olisheaO Offline
        olishea
        lost in translation
        oli
          It's actually the same is English !
          Even the same word, but without the 'e'.
          Means much the same thing, 'faire pipi'...
          We say "taking the " = making an unwelcome joke.
          A convoluted way of saying someone is making a bad joke at your expense is to say, "You are extracting the urine, aren't you?".
          C'est comme 'chier' ?
          Noteworthy: to be "ed" is to be drunk [intoxicated] in the UK, but it means very fed-up or in a bad mood in the USA.
          In the UK we would used "ed off" to be very fed-up or in a bad mood...
          Which confusing is a vulgar way of saying that someone has left unexpectedly [probably in a bad mood] - e.g. "He's ed off !" = He has [just] left here.
          Then to be on the '
          ' is to be out on the town drinking.
          To be a drunk is a to be a '
          -head' [pejorative].
          To waste something valuable is to '
          it up the wall'.
          Whilst something of unacceptably low quality is said to be '
          -poor' !
          In construction '****ed' means to be out of plumb - not vertical: e.g. "That door-frame is ****ed".
          All very confusing πŸ˜•
            Ok I see what do you mean πŸ˜„
            But that is absolutly not the same in French πŸ˜‰
            That don't exist with this liquid for these meanings! πŸ’š
            A very familiar slang can be "vous vous foutez de moi" = you exagerate, you overpass the limits, you take me for a fool...
            (or "tu te fous de moi" between best friends )
            More elegant : "Vous vous moquez du monde", "Vous ne manquez pas d'air", "vous me prenez pour un pigeon, une andouille" etc... πŸ˜†
            "Vous me faites chier" is the ultimate, insurmontable, for something who is absolutly obstrusive disturbing in the univers of the person! πŸ˜‰
            But very slanguy language indeed! πŸ˜’
              So, we both learn how to cuss better in our respective languages !
              πŸ˜‰
              So, don't mess with me dude ! πŸ‘Š
              • majidM Online
                majid
                it is greeeeaaaaattttt TIG. you are killing me slowly πŸ‘ πŸ‘ πŸ‘ grrreaaat. thanx πŸ‘
                • simon le bonS Offline
                  simon le bon
                  I don't see how I could do the same with else tools
                  Maybe 2 faces + path + FFD(or fredoscale) πŸ˜‰
                  Hi Pilou πŸ˜‰
                  First, using "Extrude Edges by Rails to Lattice"
                  1. I had kept the perfect control on the general shape ( I think it's not possible at such degree with FFD or even with Fredoscale )
                    2)I had presently used a simple grid of rails, so I could do it by hand (erasing unwanted in the skinned shape). I can't imagine to achieve the same on a real large number of curves without the help of EEbRtL ..
                  Secondly, you are right for Kirill "2 faces + path" which plays in the same playground with "ExtrudeEdgesByFaces"
                  *simon
                    simon le bon
                    @tig said:
                    Here's an update http://forums.sketchucation.com/viewtopic.php?p=242239#p242239
                    It now has 'Diagonals' as an option.
                    This new tool is already but still growing an absolute "must have". Thank you so much Tig!
                    Reversing the order of picking the Rails swaps the direction of the diagonals.
                    very elegant solution indeed πŸ˜‰
                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_017_th.jpg
                    +++simon
                      IF I well understand "diagonals" is only for wire πŸ˜‰
                        robert111
                        simn le bon , very nice job , how did you do to have this form plz
                        can you make tutto ?
                          There's a new version of EEbyRailsToLattice in the zipped set.
                          The change is to the way the Line only versions are Grouped...
                          • N Offline
                            numerobis
                            AWESOME!!! Thank You very much for ANOTHER very helpful tool!!!
                              simon le bon
                              Thank you Robert,
                              very simple.
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_018_th.jpg
                              RE: take care to carefully place the component axis (the blue axis is going to follow the curves)
                              Then You will need Component Stringer from (our wellknown very nice fellow) Chris Fullmer
                              It is recommended to apply a shortcut to this plugin :_ Window/ Preferences/ Shortcuts: for example Alt+c
                              Because we have now to apply it one by one to each diagonal curve.
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EEbRtL_019_th.jpg
                              that's it!
                              πŸ˜‰ simon
                                Have you some easy trick for make faces with the 2 diagonals lattices?
                                  If the profiles and rails are parallel [copied etc] the diagonal lines are not needed for face forming - hence the prompt to remove them.
                                  BUT if you make a lattice of the two sets of diagonals [regrouped and exploded], then they do not make coplanar quads and so they can't take faces - of course by adding a diagonal to a quad it will face, but then you have then gone 'full circle' and might as well have used plain EEbyRails in the first place !
                                  So diagonal 'diamond' lattices won't take faces.
                                  This is about as near as you can get - make a quarter using EEbyRails, copy the mesh to one side, Scale -1 to mirror the diagonals and overlay the two so the 'diamonds' form, then manually erase the unneeded orthogonal lines to get the diagonal lattice - note it must have some horizontals to let it 'bend' over. Rotate-Copy x3 to form the whole. Now use Windowizer to add the frames/panes ?Capture.PNG
                                  • E Offline
                                    eddy
                                    cool plugin
                                    thanks, thanks,thanks. πŸ‘ πŸ‘
                                    @ ++ Eddy
                                      @TIG : THX for the precision! 😎
                                      But for this sort of thing prefer this maybe more easy πŸ˜‰
                                      I have used Windowiser by Rick Wilson and this little useful plug of Multiple face Offset by Remus, Selection Toy by Thomthom and of course your Inverse Selection! πŸ‘
                                      http://forums.polyloop.net/picture.php?albumid=23&pictureid=655
                                        There's an updated zipped set available http://forums.sketchucation.com/viewtopic.php?p=242239#p242239
                                        All lingvo files have been updated.
                                          maximas
                                          please i would like to cretae an effect like this on my facade how can i do this.??
                                          http://img.archiexpo.fr/images_ae/photo-g/mur-rideau-en-panneaux-aluminium-et-verre-129841.jpg
                                          can u do an small tutorial of the use of the plugin??? thanks
                                            goldenma
                                            Thanks TIG, truly marvelous tool!!
                                            one question, though - is there a function to generate 3d geometries on the diagonals? the same effect of "extrude edges by rail by face" but for diagonals.
                                            right now i can get the diagonal lines using "extrude---to lattice", but i'll have to "follow me" each line with a profile.
                                            thanks a lot!
                                            • 3 / 4
