    OMG! fur plugin is AMAZING!
    168 Posts 44 Posters 71.6k Views 44 Watching
    • X Offline
      xrok1
      @fymoro said:
      I don't understand the trick Thanks
      yes, please explain in detail. also i can't get ghostcomp to render the real component, have you been able to. it would be a perfect companion for fur. 😄
      • olisheaO Offline
        olishea
        look at the twilight teapots tutorial....the one with 2000 teapots (i think). it explains it better than me 😳
        1. when the fur plugin gives you the option of "make by" select yes. this will turn each grass blade into a component instead of a large group.
        2. edit a grass component. double click or right click>edit component
        3. draw a line next to the blade
        4. open up the sketchup layers manager (window>layers)
        5. create a new layer called 'grass' and make it hidden (just check the hidden box)
        6. select the grass blade (by double or triple click)...right click....entity info.....change the layer to 'grass'.
        7. the blades of grass should all disappear.....leaving you with the line that you drew in step 3
        8. close the component (press escape)
        9. right click the component....twilight....render all hidden layers in all components
        10. render
        you could also just put all the grass on a hidden layer without the little lines. I just replaced the component with lines so i could see where the grass would be.
        thank to tak2hata and Oli.
        mate dont credit me! i'm just playing!
        oli
        • X Offline
          xrok1
          thanks! what about ghostcomp. have you tried that?
          • olisheaO Offline
            olishea
            yes i have but not on this model. you have to unhide the ghosts before rendering which i didnt want to do. great plugin though!
            oli
            • X Offline
              xrok1
              makes me wish SU had display states. we could display comps as wireframe. i guess this is what ghostcomp gives us (display states) but isn't quite the same as they are in other progs. 😢
              • boofredlayB Offline
                boofredlay
                I seem to have dropped my bread.
                • olisheaO Offline
                  olishea
                  haha sweet. i think there will be some tasty fur images today!
                  oli
                    A new hit 😎 👍
                      Funny indeed! ☀
                      • massimoM Offline
                        massimo Moderator
                        What about a vintage-looking lamp? 😉
                        • olisheaO Offline
                          olishea
                          wow!!!!!!
                          so many possibilities for this plugin!
                          keep posting more furry pictures!! we really needed this for sketchup!
                          i cant play cos im working but will post more grassy scenes soon!
                          oli
                          • F Offline
                            fymoro
                            Wow, Very nice lamp... 👍 I agree with Oli, "keep posting more furry pictures!!"
                            Here is a fake ivy...From far in a exterior scene It should work not ? And setup in 2 minutes... 👍
                            http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
                            • massimoM Offline
                              massimo Moderator
                              Looks good Fred. 😄
                                Some Furry Grass 😄
                                • FrederikF Offline
                                  Frederik
                                  You just gave me an idea, Fred... 😄
                                  (which I find to be an excellent idea, actually...)
                                  Since you can use Components from the scene together with this plug-in, you can take the texture of an Ivy leaf, create a component and "spray" that on the surface...
                                  I have a model, where I need to make a pavilion (or whatever it's called in English) made of metal tubes and where Ivy covers it...
                                  I've been struggling with Ivy Creator, but this can actually do the job... 😍
                                  Cheers
                                  Kim Frederik
                                  • F Offline
                                    fymoro
                                    Yes Kim, It's great idea. This Plugin is awesome... 👍
                                    • RichardR Offline
                                      Richard
                                      Yep that will do the job and very well!!!
                                      [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                                      • FrederikF Offline
                                        Frederik
                                        With this plug-in, I finally succeeded making my ivy pergola...
                                        I had never dreamed that I would be able to do it inside SU...
                                        I used two ivy leaves from the "English Ivy" in Solo's Garden pack 1, made it a component and used the fur plug-in to "distribute" it onto a frame... 😄
                                        Cheers
                                        Kim Frederik
                                        • F Offline
                                          fymoro
                                          Well done, thanks for the tips Kim... 👍
                                          Please can you make a small tuto ? 😒
                                          • massimoM Offline
                                            massimo Moderator
                                            5 min of work...and raw SU output. Really an amazing plugin 😄
                                            • 1 / 9
