    OMG! fur plugin is AMAZING!
    168 Posts 44 Posters 54.0k Views 44 Watching
    • olisheaO Offline
      olishea
      just download it. we have needed this for a long time.
      I will post all my grassy renders here. i got a feeling this plugin is very addictive! Please feel free to share your fur creations here as well! 👍
      http://forums.sketchucation.com/viewtopic.php?f=323&t=28092
      rendered with twilights "render all hidden layers". great idea.
      sang looks a little ill....quick podium render this time.
      http://i654.photobucket.com/albums/uu269/olishea/sang.jpg
      each line represents a grass component. twilight can now render the hidden components without slowing down sketchup!! 😄
      http://i654.photobucket.com/albums/uu269/olishea/FUR2.jpg
      http://i654.photobucket.com/albums/uu269/olishea/FUR.jpg
      oli
      • soloS Offline
        Oli that looks great, how about a grassy hill, something on a large scale. 😉
        • X Offline
          xrok1
          sang in a gilly. 😆
          • olisheaO Offline
            olishea
            you read my mind pete. my current scene is 320,000 polygons of grass. lets see how it turns out!
            i like how the grass takes on the colour of the surface underneath.
            imagine an organic form painted with 'color by z' or 'color by slope' plugin with grass applied oooooooohhhhhh 😄
            sang in a gilly
            guess he'd be shot straight away then!
            oli
            • X Offline
              xrok1
              have you tried it with ghostcomp? http://forums.sketchucation.com/viewtopic.php?f=323&t=21469
              • F Offline
                fymoro
                Ho yes, This plugin is really amazing, awesome, thank to tak2hata and Oli.
                It is the best Fur displacement that I have done with Vray for SU, and It is not displacement... 😄
                Oli How can I make it less heavy ? I don't understand the trick Thanks
                http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
                • X Offline
                  xrok1
                  yes, please explain in detail. also i can't get ghostcomp to render the real component, have you been able to. it would be a perfect companion for fur. 😄
                  • olisheaO Offline
                    olishea
                    look at the twilight teapots tutorial....the one with 2000 teapots (i think). it explains it better than me 😳
                    1. when the fur plugin gives you the option of "make by" select yes. this will turn each grass blade into a component instead of a large group.
                    2. edit a grass component. double click or right click>edit component
                    3. draw a line next to the blade
                    4. open up the sketchup layers manager (window>layers)
                    5. create a new layer called 'grass' and make it hidden (just check the hidden box)
                    6. select the grass blade (by double or triple click)...right click....entity info.....change the layer to 'grass'.
                    7. the blades of grass should all disappear.....leaving you with the line that you drew in step 3
                    8. close the component (press escape)
                    9. right click the component....twilight....render all hidden layers in all components
                    10. render
                    you could also just put all the grass on a hidden layer without the little lines. I just replaced the component with lines so i could see where the grass would be.
                    mate dont credit me! i'm just playing!
                    oli
                    • X Offline
                      xrok1
                      thanks! what about ghostcomp. have you tried that?
                      • olisheaO Offline
                        olishea
                        yes i have but not on this model. you have to unhide the ghosts before rendering which i didnt want to do. great plugin though!
                        oli
                        • X Offline
                          xrok1
                          makes me wish SU had display states. we could display comps as wireframe. i guess this is what ghostcomp gives us (display states) but isn't quite the same as they are in other progs. 😢
                          • boofredlayB Offline
                            boofredlay
                            I seem to have dropped my bread.
                            • olisheaO Offline
                              olishea
                              haha sweet. i think there will be some tasty fur images today!
                              oli
                                A new hit 😎 👍
                                  Funny indeed! ☀
                                  • massimoM Offline
                                    massimo Moderator
                                    What about a vintage-looking lamp? 😉
                                    • olisheaO Offline
                                      olishea
                                      wow!!!!!!
                                      so many possibilities for this plugin!
                                      keep posting more furry pictures!! we really needed this for sketchup!
                                      i cant play cos im working but will post more grassy scenes soon!
                                      oli
                                      • F Offline
                                        fymoro
                                        Wow, Very nice lamp... 👍 I agree with Oli, "keep posting more furry pictures!!"
                                        Here is a fake ivy...From far in a exterior scene It should work not ? And setup in 2 minutes... 👍
                                        • massimoM Offline
                                          massimo Moderator
                                          Looks good Fred. 😄
                                            Some Furry Grass 😄
                                            • 1 / 9
