    OMG! fur plugin is AMAZING!
    168 Posts 44 Posters 76.5k Views 44 Watching
    • olisheaO Offline
      olishea
      yes i have but not on this model. you have to unhide the ghosts before rendering which i didnt want to do. great plugin though!
      oli
      • X Offline
        xrok1
        makes me wish SU had display states. we could display comps as wireframe. i guess this is what ghostcomp gives us (display states) but isn't quite the same as they are in other progs. ๐Ÿ˜ข
        โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
        • boofredlayB Offline
          boofredlay
          I seem to have dropped my bread.
          • olisheaO Offline
            olishea
            haha sweet. i think there will be some tasty fur images today!
            oli
              A new hit ๐Ÿ˜Ž ๐Ÿ‘
                Funny indeed! โ˜€
                • massimoM Offline
                  massimo Moderator
                  What about a vintage-looking lamp? ๐Ÿ˜‰
                  • olisheaO Offline
                    olishea
                    wow!!!!!!
                    so many possibilities for this plugin!
                    keep posting more furry pictures!! we really needed this for sketchup!
                    i cant play cos im working but will post more grassy scenes soon!
                    oli
                    • F Offline
                      fymoro
                      Wow, Very nice lamp... ๐Ÿ‘ I agree with Oli, "keep posting more furry pictures!!"
                      Here is a fake ivy...From far in a exterior scene It should work not ? And setup in 2 minutes... ๐Ÿ‘
                      http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
                      • massimoM Offline
                        massimo Moderator
                        Looks good Fred. ๐Ÿ˜„
                          Some Furry Grass ๐Ÿ˜„
                          • FrederikF Offline
                            Frederik
                            You just gave me an idea, Fred... ๐Ÿ˜„
                            (which I find to be an excellent idea, actually...)
                            Since you can use Components from the scene together with this plug-in, you can take the texture of an Ivy leaf, create a component and "spray" that on the surface...
                            I have a model, where I need to make a pavilion (or whatever it's called in English) made of metal tubes and where Ivy covers it...
                            I've been struggling with Ivy Creator, but this can actually do the job... ๐Ÿ˜
                            Cheers
                            Kim Frederik
                            • F Offline
                              fymoro
                              Yes Kim, It's great idea. This Plugin is awesome... ๐Ÿ‘
                              • RichardR Offline
                                Richard
                                Yep that will do the job and very well!!!
                                BUILTBRAND.COM.AU
                                • FrederikF Offline
                                  Frederik
                                  With this plug-in, I finally succeeded making my ivy pergola...
                                  I had never dreamed that I would be able to do it inside SU...
                                  I used two ivy leaves from the "English Ivy" in Solo's Garden pack 1, made it a component and used the fur plug-in to "distribute" it onto a frame... ๐Ÿ˜„
                                  Cheers
                                  Kim Frederik
                                  • F Offline
                                    fymoro
                                    Well done, thanks for the tips Kim... ๐Ÿ‘
                                    Please can you make a small tuto ? ๐Ÿ˜’
                                    • massimoM Offline
                                      massimo Moderator
                                      5 min of work...and raw SU output. Really an amazing plugin ๐Ÿ˜„
                                      • FrederikF Offline
                                        Frederik
                                        It's really easy, Fred... ๐Ÿ˜„
                                        Like I wrote earlier... In my example, I used the English Ivy from Solo's Garden pack...
                                        1.) I exploded the model and deleted everything except 2 ivy leaves.
                                        2.) Make these two leaves into a component.
                                        3.) Open the Fur setting dialog
                                        4.) You'll need to play around with the settings. My input in the "Density" box was 1000
                                        5.) In the "Make by ComponentInstance" you select the Ivy leaves from the list
                                        6.) Select the surface where you want the leaves to be
                                        7.) Click "Make Fur" button.
                                        Voila...! ๐Ÿ˜„
                                        Cheers
                                        Kim Frederik
                                        • F Offline
                                          fymoro
                                          Wow!! Massimo, very cool !!!
                                          Thanks for the totu Fredy... ๐Ÿ‘
                                          • RichardR Offline
                                            Richard
                                            Mate when you look at images like that you wonder why SU cant have a better lighting environment, that would do us! Begone all renders!
                                            BUILTBRAND.COM.AU
                                            • 1 / 9
