    OMG! fur plugin is AMAZING!
    168 Posts 44 Posters 59.7k Views 44 Watching
    • F Offline
      fymoro
      Ho yes, This plugin is really amazing, awesome, thank to tak2hata and Oli.
      It is the best Fur displacement that I have done with Vray for SU, and It is not displacement... 😄
      Oli How can I make it less heavy ? I don't understand the trick Thanks
      http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
      • X Offline
        xrok1
        yes, please explain in detail. also i can't get ghostcomp to render the real component, have you been able to. it would be a perfect companion for fur. 😄
        • olisheaO Offline
          olishea
          look at the twilight teapots tutorial....the one with 2000 teapots (i think). it explains it better than me 😳
          1. when the fur plugin gives you the option of "make by" select yes. this will turn each grass blade into a component instead of a large group.
          2. edit a grass component. double click or right click>edit component
          3. draw a line next to the blade
          4. open up the sketchup layers manager (window>layers)
          5. create a new layer called 'grass' and make it hidden (just check the hidden box)
          6. select the grass blade (by double or triple click)...right click....entity info.....change the layer to 'grass'.
          7. the blades of grass should all disappear.....leaving you with the line that you drew in step 3
          8. close the component (press escape)
          9. right click the component....twilight....render all hidden layers in all components
          10. render
          you could also just put all the grass on a hidden layer without the little lines. I just replaced the component with lines so i could see where the grass would be.
          mate dont credit me! i'm just playing!
          oli
          • X Offline
            xrok1
            thanks! what about ghostcomp. have you tried that?
            • olisheaO Offline
              olishea
              yes i have but not on this model. you have to unhide the ghosts before rendering which i didnt want to do. great plugin though!
              oli
              • X Offline
                xrok1
                makes me wish SU had display states. we could display comps as wireframe. i guess this is what ghostcomp gives us (display states) but isn't quite the same as they are in other progs. 😢
                • boofredlayB Offline
                  boofredlay
                  I seem to have dropped my bread.
                  • olisheaO Offline
                    olishea
                    haha sweet. i think there will be some tasty fur images today!
                    oli
                      A new hit 😎 👍
                        Funny indeed! ☀
                        • massimoM Offline
                          massimo Moderator
                          What about a vintage-looking lamp? 😉
                          • olisheaO Offline
                            olishea
                            wow!!!!!!
                            so many possibilities for this plugin!
                            keep posting more furry pictures!! we really needed this for sketchup!
                            i cant play cos im working but will post more grassy scenes soon!
                            oli
                            • F Offline
                              fymoro
                              Wow, Very nice lamp... 👍 I agree with Oli, "keep posting more furry pictures!!"
                              Here is a fake ivy...From far in a exterior scene It should work not ? And setup in 2 minutes... 👍
                              • massimoM Offline
                                massimo Moderator
                                Looks good Fred. 😄
                                  Some Furry Grass 😄
                                  • FrederikF Offline
                                    Frederik
                                    You just gave me an idea, Fred... 😄
                                    (which I find to be an excellent idea, actually...)
                                    Since you can use Components from the scene together with this plug-in, you can take the texture of an Ivy leaf, create a component and "spray" that on the surface...
                                    I have a model, where I need to make a pavilion (or whatever it's called in English) made of metal tubes and where Ivy covers it...
                                    I've been struggling with Ivy Creator, but this can actually do the job... 😍
                                    Cheers
                                    Kim Frederik
                                    • F Offline
                                      fymoro
                                      Yes Kim, It's great idea. This Plugin is awesome... 👍
                                      • RichardR Offline
                                        Richard
                                        Yep that will do the job and very well!!!
                                        [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                                        • FrederikF Offline
                                          Frederik
                                          With this plug-in, I finally succeeded making my ivy pergola...
                                          I had never dreamed that I would be able to do it inside SU...
                                          I used two ivy leaves from the "English Ivy" in Solo's Garden pack 1, made it a component and used the fur plug-in to "distribute" it onto a frame... 😄
                                          Cheers
                                          Kim Frederik
                                          • F Offline
                                            fymoro
                                            Well done, thanks for the tips Kim... 👍
                                            Please can you make a small tuto ? 😒
                                            • 3 / 9
