    OMG! fur plugin is AMAZING!
    168 Posts 44 Posters 54.0k Views 44 Watching
    • X Offline
      xrok1
      have you tried it with ghostcomp? http://forums.sketchucation.com/viewtopic.php?f=323&t=21469
      • F Offline
        fymoro
        Ho yes, This plugin is really amazing, awesome, thank to tak2hata and Oli.
        It is the best Fur displacement that I have done with Vray for SU, and It is not displacement... 😄
        Oli How can I make it less heavy ? I don't understand the trick Thanks
        http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
        • X Offline
          xrok1
          yes, please explain in detail. also i can't get ghostcomp to render the real component, have you been able to. it would be a perfect companion for fur. 😄
          • olisheaO Offline
            olishea
            look at the twilight teapots tutorial....the one with 2000 teapots (i think). it explains it better than me 😳
            1. when the fur plugin gives you the option of "make by" select yes. this will turn each grass blade into a component instead of a large group.
            2. edit a grass component. double click or right click>edit component
            3. draw a line next to the blade
            4. open up the sketchup layers manager (window>layers)
            5. create a new layer called 'grass' and make it hidden (just check the hidden box)
            6. select the grass blade (by double or triple click)...right click....entity info.....change the layer to 'grass'.
            7. the blades of grass should all disappear.....leaving you with the line that you drew in step 3
            8. close the component (press escape)
            9. right click the component....twilight....render all hidden layers in all components
            10. render
            you could also just put all the grass on a hidden layer without the little lines. I just replaced the component with lines so i could see where the grass would be.
            mate dont credit me! i'm just playing!
            oli
            • X Offline
              xrok1
              thanks! what about ghostcomp. have you tried that?
              • olisheaO Offline
                olishea
                yes i have but not on this model. you have to unhide the ghosts before rendering which i didnt want to do. great plugin though!
                oli
                • X Offline
                  xrok1
                  makes me wish SU had display states. we could display comps as wireframe. i guess this is what ghostcomp gives us (display states) but isn't quite the same as they are in other progs. 😢
                  • boofredlayB Offline
                    boofredlay
                    I seem to have dropped my bread.
                    • olisheaO Offline
                      olishea
                      haha sweet. i think there will be some tasty fur images today!
                      oli
                        A new hit 😎 👍
                          Funny indeed! ☀
                          • massimoM Offline
                            massimo Moderator
                            What about a vintage-looking lamp? 😉
                            • olisheaO Offline
                              olishea
                              wow!!!!!!
                              so many possibilities for this plugin!
                              keep posting more furry pictures!! we really needed this for sketchup!
                              i cant play cos im working but will post more grassy scenes soon!
                              oli
                              • F Offline
                                fymoro
                                Wow, Very nice lamp... 👍 I agree with Oli, "keep posting more furry pictures!!"
                                Here is a fake ivy...From far in a exterior scene It should work not ? And setup in 2 minutes... 👍
                                • massimoM Offline
                                  massimo Moderator
                                  Looks good Fred. 😄
                                    Some Furry Grass 😄
                                    • FrederikF Offline
                                      Frederik
                                      You just gave me an idea, Fred... 😄
                                      (which I find to be an excellent idea, actually...)
                                      Since you can use Components from the scene together with this plug-in, you can take the texture of an Ivy leaf, create a component and "spray" that on the surface...
                                      I have a model, where I need to make a pavilion (or whatever it's called in English) made of metal tubes and where Ivy covers it...
                                      I've been struggling with Ivy Creator, but this can actually do the job... 😍
                                      Cheers
                                      Kim Frederik
                                      • F Offline
                                        fymoro
                                        Yes Kim, It's great idea. This Plugin is awesome... 👍
                                        • RichardR Offline
                                          Richard
                                          Yep that will do the job and very well!!!
                                          [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                                          • FrederikF Offline
                                            Frederik
                                            With this plug-in, I finally succeeded making my ivy pergola...
                                            I had never dreamed that I would be able to do it inside SU...
                                            I used two ivy leaves from the "English Ivy" in Solo's Garden pack 1, made it a component and used the fur plug-in to "distribute" it onto a frame... 😄
                                            Cheers
                                            Kim Frederik
                                            • 5 / 9
