    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.9m Views 202 Watching
    • N
      nilblo
      Rightclick menues issue..
      After having installed Fredo6 Tools on surface + FredoScale I´m having the darnest stupid problem:
      Most contextual menues are greyed out, like Intersect with model, Flip along Groups Red, and so on..
      I can create shortcuts to these commands and they work as expected, but I rely heavily on shortcuts in my work and list of shortcuts is getting more and more crowded. Have I done something wrong here and this is normal behavior? I have been searching the forum but so far havent found a description af this "problem".
      I have most definetely missed out on something here and the fault is obviously mine (as it usually is) but I really would appreciate an input to help me solve this matter.
      Vista 64- Sketchup Pro 7.1.6860
      Plugins: Fredo6 ToolsOnSurface v1.5f LIBFREDO6_Dir_34 (109 mS seems OK?
      Total time to load plugin = 187 mS) FredoScale v2.0g (Total time to load plugin =124 mS)
      SketchyPhysics verson3 Kerkythea SU2KT version 3.0 model exporter
        sus4
        too Dont Work Ver7.1.6087
        error massage ZLoader__OnSurface.rb File loading error
        No such file to load -- LibFredo6.rb
        • fredo6F
          I have heard that this problem is related to SU itself, though it may be 'helped' by some plugins.
          I got it occasionally, even not using any plugins.
            sketchyup2010
            Great tool bro. Nice work!!!!
              dylan
              A minor issue and not sure if this is Mac related.
              I can only get the default icons to show.
              If I go into Default Parameters and choose IMAGES_DanielS then save changes, it does nothing. I can open the default parameters again and the box is un-ticked.
              I have the latest version installed.
              http://dmdarchitecture.co.uk/
              • T
                theark
                Thanks a lot.Good plug-in
                • COSEDIMARCOC
                  COSEDIMARCO
                  Thanks loads for this tool, your work is great!
                  after I use this tool I sometimes loose right click options such as; smooth, make group/component, reverse faces, etc.
                  [attachment=0:2zrlzv0n]<!-- ia0 -->Image.jpg<!-- ia0 -->[/attachment:2zrlzv0n]
                  I have this issue too.
                  [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
                  • Roguer1R
                    Roguer1
                    @ Dylan
                    Just replace the default icons with the ones you wish (in the plugins directory). Thats actually the way I did it.
                    I’m also having another issue. IDK if this has been discussed before or not, but after I use this tool I sometimes loose right click options such as; smooth, make group/component, reverse faces, etc.
                    Find all my models on the 3D Warehouse
                      The issue of loosing some right-click context-menu items [i.e. they get "greyed-out"] is a known bug with more recent versions of SketchUp - Google are being pressed to fix it...
                      Its cause is not wholly established, although having lots of plugins that make context-menu items and repeated clicking on objects seem to both trigger it - separately or together !
                      All of a context-menu's items still appear correctly under the last item in the main Edit Menu - so you can access them this way if the worst happens...
                      The only 'fix' is to save and restart SUp - then you should get back the context-menu, albeit momentarily.
                      Don't load plugins you aren't ever going to use - they increase the load and might just be the 'last-straw...' - move them out of the Plugins folder or rename them from .rb to .txt - that way you can always load them during a session by typing in the Ruby Console load"the_script_name.txt" ...
                      • COSEDIMARCOC
                        COSEDIMARCO
                        Thanks 😄
                        • T
                          tanjoodo
                          awesome plugin!!! ty for it 😄
                          • X
                            xrok1
                            i have a feature suggestion for this already awsome plugin. to be able to make copies on surface of the shape you've drawn would put this thing over the edge! 😍 i thought of this while useing your tool to try and figure out how to do this:
                            http://forums.sketchucation.com/download/file.php?id=47188&t=1
                            it would be awsome if you could draw the oval shape then just copy (drag) it around on the surface! what do you think Fredo? 😄
                            • fredo6F
                              I am not sure this covers all your cases, but you can drwa an ellipse on the surface, and then just double clickelsewhere on the surface (or on another one) to create the same ellipse. Double click works as a repeater for any shape, as well as offset and line.
                              • X
                                xrok1
                                thats awsome thanks! 😄
                                now if you could select more than 1 point with the interactive edit tool i'd be amazed!
                                • fredo6F
                                  Do you have some usage in mind?
                                  • X
                                    xrok1
                                    that way you could drag freehand shapes around. 😉
                                      But what happen if you have one point on the front and one point on the back? 😉
                                      • X
                                        xrok1
                                          And it's good to know that ToolsOnSurface also works without a surface. There is a trick explained in the doc to select the plane (mouse over a face and just press SHIFT, without clicking)[/list]
                                          I tried this: hover over face and draw using the rectangle tool. Got an error in the console:
                                          Error: #<NoMethodError: undefined methodlast' for nil:NilClass>
                                          C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/TOS_Dir_16/ShapeOnSurface.rb:1012:in mark_for_chain_origin' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/TOS_Dir_16/ShapeOnSurface.rb:1022:in chain_origin'
                                          C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/TOS_Dir_16/ShapeOnSurface.rb:420:in chain_origin' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/TOS_Dir_16/ShapeOnSurface.rb:385:in set_state'
                                          C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/TOS_Dir_16/ShapeOnSurface.rb:435:in onLButtonDown' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/TOS_Dir_16/LibOnSurface.rb:2270
                                            And the rectangle tool doesn't wrap around this shape for some reason.
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 31
                                            • 32
                                            • 14 / 32
