    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.7m Views 202 Watching
      The issue of loosing some right-click context-menu items [i.e. they get "greyed-out"] is a known bug with more recent versions of SketchUp - Google are being pressed to fix it...
      Its cause is not wholly established, although having lots of plugins that make context-menu items and repeated clicking on objects seem to both trigger it - separately or together !
      All of a context-menu's items still appear correctly under the last item in the main Edit Menu - so you can access them this way if the worst happens...
      The only 'fix' is to save and restart SUp - then you should get back the context-menu, albeit momentarily.
      Don't load plugins you aren't ever going to use - they increase the load and might just be the 'last-straw...' - move them out of the Plugins folder or rename them from .rb to .txt - that way you can always load them during a session by typing in the Ruby Console load"the_script_name.txt" ...
      πŸ˜’
      • COSEDIMARCOC Offline
        COSEDIMARCO
        Thanks πŸ˜„
        [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
          tanjoodo
          awesome plugin!!! ty for it πŸ˜„
          • X Offline
            xrok1
            i have a feature suggestion for this already awsome plugin. to be able to make copies on surface of the shape you've drawn would put this thing over the edge! 😍 i thought of this while useing your tool to try and figure out how to do this:
            http://forums.sketchucation.com/download/file.php?id=47188&t=1
            it would be awsome if you could draw the oval shape then just copy (drag) it around on the surface! what do you think Fredo? πŸ˜„
            • fredo6F Offline
              I am not sure this covers all your cases, but you can drwa an ellipse on the surface, and then just double clickelsewhere on the surface (or on another one) to create the same ellipse. Double click works as a repeater for any shape, as well as offset and line.
              • X Offline
                xrok1
                thats awsome thanks! πŸ˜„
                now if you could select more than 1 point with the interactive edit tool i'd be amazed!
                • fredo6F Offline
                  Do you have some usage in mind?
                  • X Offline
                    xrok1
                    that way you could drag freehand shapes around. πŸ˜‰
                      But what happen if you have one point on the front and one point on the back? πŸ˜‰
                      • X Offline
                        xrok1
                        πŸ˜• ❓ ❓ ❓
                          And it's good to know that ToolsOnSurface also works without a surface. There is a trick explained in the doc to select the plane (mouse over a face and just press SHIFT, without clicking)[/list]
                          I tried this: hover over face and draw using the rectangle tool. Got an error in the console:
                          Error: #<NoMethodError: undefined methodlast' for nil:NilClass>
                          C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/TOS_Dir_16/ShapeOnSurface.rb:1012:in mark_for_chain_origin' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/TOS_Dir_16/ShapeOnSurface.rb:1022:in chain_origin'
                          C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/TOS_Dir_16/ShapeOnSurface.rb:420:in chain_origin' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/TOS_Dir_16/ShapeOnSurface.rb:385:in set_state'
                          C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/TOS_Dir_16/ShapeOnSurface.rb:435:in onLButtonDown' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/TOS_Dir_16/LibOnSurface.rb:2270
                            And the rectangle tool doesn't wrap around this shape for some reason.
                            • fredo6F Offline
                              Tom,
                              Did you press Shift when hovering over the surface?
                              Fred
                                Not in the second issue I reported.
                                • fredo6F Offline
                                  Tom,
                                  TOS has always had lot of problems on 'close' surface (i.e. 2 paths from any two points). When I have time, I'll need to seriously revisit the heuristics.
                                  For the functions without a surface, either in the empty space or on Edges, I will soon publish a patch, as this is easier to fix.
                                    But that is the thing, it's not a closed surface. It was a box, but I erased one edge.
                                    • dermotcollD Offline
                                      dermotcoll
                                      I have tried to get the TOS plug in to work and have unzippled and extracted it several times but I keep getting an error ,message (Error Loading File ZLoader_On Surface.rb uninitialized constant LibFredo6:: Traductor) I have already unzipped the latest version of Libfredo6 into the plugins directory too - anyone know what am I doing wrong?
                                      When you burn your arse - you gotta sit on the blisters!!
                                        • fredo6F Offline
                                          New version v1.6b, 8 May 10available.
                                          It allows to use the replication feature (by double-click) for shapes which are drawn perpendicular to edges.
                                          See small video in main post http://forums.sketchucation.com/viewtopic.php?f=323&t=11212#p76625
                                          • bagateloB Offline
                                            bagatelo
                                            It would be interesting we could draw our own shapes and to save at an own library. Thanks for the great plugins. You are de best. (not the beast πŸ˜† )
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 31
                                            • 32
                                            • 14 / 32
