    OMG! fur plugin is AMAZING!
    168 Posts 44 Posters 59.7k Views 44 Watching
    • X Offline
      xrok1
      sang in a gilly. 😆
      • olisheaO Offline
        olishea
        how about a grassy hill, something on a large scale
        you read my mind pete. my current scene is 320,000 polygons of grass. lets see how it turns out!
        i like how the grass takes on the colour of the surface underneath.
        imagine an organic form painted with 'color by z' or 'color by slope' plugin with grass applied oooooooohhhhhh 😄
        sang in a gilly
        guess he'd be shot straight away then!
        oli
        • X Offline
          xrok1
          have you tried it with ghostcomp? http://forums.sketchucation.com/viewtopic.php?f=323&t=21469
          • F Offline
            fymoro
            Ho yes, This plugin is really amazing, awesome, thank to tak2hata and Oli.
            It is the best Fur displacement that I have done with Vray for SU, and It is not displacement... 😄
            Oli How can I make it less heavy ? I don't understand the trick Thanks
            http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
            • X Offline
              xrok1
              yes, please explain in detail. also i can't get ghostcomp to render the real component, have you been able to. it would be a perfect companion for fur. 😄
              • olisheaO Offline
                olishea
                look at the twilight teapots tutorial....the one with 2000 teapots (i think). it explains it better than me 😳
                1. when the fur plugin gives you the option of "make by" select yes. this will turn each grass blade into a component instead of a large group.
                2. edit a grass component. double click or right click>edit component
                3. draw a line next to the blade
                4. open up the sketchup layers manager (window>layers)
                5. create a new layer called 'grass' and make it hidden (just check the hidden box)
                6. select the grass blade (by double or triple click)...right click....entity info.....change the layer to 'grass'.
                7. the blades of grass should all disappear.....leaving you with the line that you drew in step 3
                8. close the component (press escape)
                9. right click the component....twilight....render all hidden layers in all components
                10. render
                you could also just put all the grass on a hidden layer without the little lines. I just replaced the component with lines so i could see where the grass would be.
                mate dont credit me! i'm just playing!
                oli
                • X Offline
                  xrok1
                  thanks! what about ghostcomp. have you tried that?
                  • olisheaO Offline
                    olishea
                    yes i have but not on this model. you have to unhide the ghosts before rendering which i didnt want to do. great plugin though!
                    oli
                    • X Offline
                      xrok1
                      makes me wish SU had display states. we could display comps as wireframe. i guess this is what ghostcomp gives us (display states) but isn't quite the same as they are in other progs. 😢
                      • boofredlayB Offline
                        boofredlay
                        I seem to have dropped my bread.
                        • olisheaO Offline
                          olishea
                          haha sweet. i think there will be some tasty fur images today!
                          oli
                            A new hit 😎 👍
                              Funny indeed! ☀
                              • massimoM Offline
                                massimo Moderator
                                What about a vintage-looking lamp? 😉
                                • olisheaO Offline
                                  olishea
                                  wow!!!!!!
                                  so many possibilities for this plugin!
                                  keep posting more furry pictures!! we really needed this for sketchup!
                                  i cant play cos im working but will post more grassy scenes soon!
                                  oli
                                  • F Offline
                                    fymoro
                                    Wow, Very nice lamp... 👍 I agree with Oli, "keep posting more furry pictures!!"
                                    Here is a fake ivy...From far in a exterior scene It should work not ? And setup in 2 minutes... 👍
                                    • massimoM Offline
                                      massimo Moderator
                                      Looks good Fred. 😄
                                        Some Furry Grass 😄
                                        • FrederikF Offline
                                          Frederik
                                          You just gave me an idea, Fred... 😄
                                          (which I find to be an excellent idea, actually...)
                                          Since you can use Components from the scene together with this plug-in, you can take the texture of an Ivy leaf, create a component and "spray" that on the surface...
                                          I have a model, where I need to make a pavilion (or whatever it's called in English) made of metal tubes and where Ivy covers it...
                                          I've been struggling with Ivy Creator, but this can actually do the job... 😍
                                          Cheers
                                          Kim Frederik
                                          • F Offline
                                            fymoro
                                            Yes Kim, It's great idea. This Plugin is awesome... 👍
                                            • 2 / 9
