    [Plugin] Camera Stats
    36 Posts 20 Posters 43.0k Views 20 Watching
      Jim
      Windows users can try this for feedback:
      Sketchup.send_action(10624)
      It will accept input, although it doesn't export/import.
        ... it accepts input?? facepalm!
        • Chris FullmerC
          ๐Ÿ˜†
            MartinRinehart
            @jclements said:
            Martin, so does this just report the camera parameters or can it be used to controll the camera as well?
            Both.
              MartinRinehart
              Wish I'd known that!
              Frustum? Adjusted or not?
              Edit: I looked it up. Make a pyramid. Make a horizontal slice and discard the top. What's left is a frustum. What this has to do with a camera is a mystery.
              • FletchF
                Fletch
                Sorry Martin, haven't tried it yet, but can you, in your initial post, please explain the "send data" "get data" buttons?
                Fletch
                  MartinRinehart
                  Try it. If these are not immediately meaningful, tell me and I'll add some words.
                    A frustum is explained here... http://en.wikipedia.org/wiki/Viewing_frustum
                    It's the truncated pyramid, the camera's "view-box", in which there are objects that you will see...
                    • StinkieS
                      Stinkie
                      Oooh, a most useful plugin. Thank you, Martin.
                        MartinRinehart
                        Edit: 58 downloads and zero bugs? Hard to believe.
                        Mac folks: any problems?
                        • cmeedC
                          cmeed
                          This looks really great!
                          Works fine on my Mac so far.
                          Can you tell me about imputing the aspect ratio? i use sketchup to design tv sets so 16:9.
                          Also does the statistics window always disappear behind the main skp window? so we have to re-size our windows when its opened?
                          Is it possible with this plugin to show a true camera zoom from a certain location? so i place my camera i can show what it looks like from this position and and THEN from that position what a zoom looks like?
                            MartinRinehart
                            @cmeed said:
                            Can you tell me about imputing the aspect ratio? i use sketchup to design tv sets so 16:9. Also does the statistics window always disappear behind the main skp window? so we have to re-size our windows when its opened?
                            Sorry to be so long. Somehow I missed your post.
                            On my PC, my stats window pops up in front of SketchUp. Stays in front until I click the SketchUp window.
                            For zoom, use two scenes. Use the Cam Stats plugin to set both scenes' cameras to identical eye, target and up values, but different field of view values. The SketchUp animation should give you a proper zoom.
                              August
                              @tig said:
                              A frustum is ... the camera's "view-box", in which there are objects that you will see...
                              What most newbies don't know about are the near and far Clipping Planes. Anything closer than the Near Clipping Plane or farther than the Far Clipping Plane will not be displayed. If you could show things that were arbitrarily near or arbitrarily far, the math would require too many decimal places (or bits in the CPU).
                              โ€œAn idea, like a ghost, must be spoken to a little before it will explain itself.โ€
                              [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
                                Jim
                                Need to open it modal on the Mac to make it stay on top. There is not a true modal WebDialog on a Mac as there is on Windows.
                                  MartinRinehart
                                  Thanks, Jim.
                                  I changed it to "show_modal" but it turned the friendly little guy into a huge pain. Almost useless. Certainly no fun.
                                  Mac users: edit the code. It's ...Plugins/camera_stats/camera_stats.rb. Change the line at the bottom that now reads "wd.show()" to "wd.show_modal()". Is that better?
                                    What happened?
                                    • cmeedC
                                      cmeed
                                      very good idea about the camera 'zoom'. I'll test your code for the mac users when i have the chance.... Work!!!
                                      • RunnerPackR
                                        RunnerPack
                                        Thanks, Martin. Another in a long line of very handy plugins! ๐Ÿ˜„
                                        Just a couple of bugs to report, and one feature request:
                                        First, I'm running XP SP3, SU 7.1.6860 (free version), and my IE is version 8.0.6001.18702. It seems to have problems when I use it, (which is rarely ๐Ÿ˜› ) so it could be IE's fault, not yours... Anyway, I get the JavaScript error dialog shown in the attached image when I start the plugin (that is, when I open the window, not when SU starts).
                                        Also, the "close" button on the Camera Stats window doesn't do anything (possibly related to the JavaScript error?).
                                        Finally, the feature request:
                                        It would be very handy if I could "pan" the camera left and right, relative to the viewport, by a specified value. For example, if I panned it right by about 2.5", it would be like I closed my left eye and opened my right (do you see where I'm going with this? ๐Ÿ˜‰ ). I know (for me, anyway) the math would be pretty rough, but if you have the time, (you obviously have the grey-matter ๐Ÿ˜‰ ) I would use this feature ALL OF THE TIME! ๐Ÿ˜„
                                        Anyway, thanks again for the cool plugin!
                                        EDIT: I just had another look at the Camera object API, and I think I know how to do this... Take the cross product of Camera#up and Camera#direction, use the resulting vector (or its negative) to transform Camera#target and Camera#eye, and use Camera#set to put it all back together. Am I close?
                                        EDIT 2: โ˜€ Success! After just a bit of tinkering, I got it working! ๐Ÿ˜ฎ ๐Ÿ˜ฒ ๐Ÿ˜„
                                        It's pretty much as I said above, but I had to experiment to find out how the API wants things done (plus I was a bit rusty at Ruby ๐Ÿ˜ณ)
                                        I'm going to clean this up and make a new thread for it, just in case someone can use it, but here it is if you, Martin, want to incorporate it (not that you need my amateurish code ๐Ÿ˜‰ ) or if someone wants to see what I'm blathering about ๐Ÿ˜‰.
                                        IE JavaScript error dialog
                                        Stereo Panning Plugin (WIP)
                                        You might have noticed... I'm a bit of a ferpectionist.
                                        • W
                                          wwwyoose
                                          I try this nice plugin but I dont get i work to export the camera position ...
                                          or I do some wrong
                                          some help who to...๐Ÿ˜„
                                          Best Achim
                                          • romboutR
                                            rombout
                                            Thanks, Jim.
                                            ii got this error
                                            Error: #<SyntaxError: /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/camera_stats/camera_stats.rb:104: parse error, unexpected tIDENTIFIER, expecting kEND
                                            target = make_arr( val )wd.show
                                            /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/camera_stats_menu.rb:10:in load' /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/camera_stats_menu.rb:10 /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/camera_stats_menu.rb:10:in call'
                                            im working on mac su 6
                                            before that line change it dint do any thing either
