    Problem with 1.05.03
    renderpluginsextensions
    30 Posts 3 Posters 5.3k Views 3 Watching
      Has the location of your textures changed?
        sepo
        In what sense?
          Are the textures visible in SU?
          Are they only grey when rendering? if so: have you moved the original textures you've used?
            sepo
            The textures are visible in SU. The textures are greyscale in Vray mat editor and renders are greyscale with sky in colour. I have not moved any textures. The models render with Podium and Twilight without any problems.
              What does it say in the Render Progress window? For each texture it should say if it fails or loads successfully.
                sepo
                Here is screenshot
                  sepo
                  MtlMulti (noname) "mtls" parameter is deprecated; use "mtls_list" and "ids_list" instead.
                    That always appears at the beginning. That's normal. But after that - there should be references to the textures used - and after the file paths it should say if they loaded correctly or not.
                      sepo
                      here is copy of the render progress.
                      render progress.txt
                        Bitmap file "C:\ProgramData\ASGvis\VRayForSketchUp\Textures\CEDARWOOD2.jpg" failed to load: cannot open file
                        Bitmap file "C:\ProgramData\ASGvis\VRayForSketchUp\Textures\Grass0066_1x_L.jpg" failed to load: cannot open file
                        Bitmap file "C:\ProgramData\ASGvis\VRayForSketchUp\Textures\Concrete9.jpg" failed to load: cannot open file
                        Bitmap file "C:\Users\s porobic\Desktop\Water Textures\untitled.bmp" failed to load: cannot open file
                        Bitmap file "C:\ProgramData\ASGvis\VRayForSketchUp\Textures\IMGP3728.JPG" failed to load: cannot open file
                        Bitmap file "C:\ProgramData\ASGvis\VRayForSketchUp\Textures\sedum 2made.jpg" failed to load: cannot open file
                        Bitmap file "C:\Documents and Settings\All Users\Application Data\ASGvis\VRayForSketchUp\Textures\Fencing_Wood_Old.jpg" loaded.
                          sepo
                          So why is that? Any ideas what is the solution?
                            Are you able to open them in other applications?
                            Have you tried to clear you temp folder?
                              sepo
                              As I said before no problem rendering in Podium and Twilight.
                                They might be loading the textures embedded into SU. V-Ray tried to open the original files.
                                Try to open the files in an image editor.
                                  sepo
                                  I opened texture files in CS3 from SU (context click)...dumped tmp files and no change.
                                    No - try to open the files from the location VfSU reports it tried to load them from.
                                      sepo
                                      hmm program data is hidden ...how do you reveal it? 😳
                                      • dkendigD
                                        dkendig
                                        The problem is that the materials have their textures set to external files. If you look at the path for the bitmap texture used in those materials in the V-Ray material editor, you should see for example: "C:\Users\s porobic\Desktop\Water Textures\untitled.bmp" is set for one of your textures. If you have an external file set like that, the file needs to exist at the location specified in the file path. It isn't going to look in the SU scene for the texture, and automatically extract it before a render, because you are telling V-Ray that you don't want to use that image for the texture, you want to use an external file. Your render progress window is telling you that those files are not accessible, so either those files don't exist at the specified path, or V-Ray does not have permission to access those files.
                                        Devin Kendig
                                        Developer
                                          Try the one not in program data first:
                                            sepo
                                            right..the file is not there....what do you suggest that I do?
