    Problem with 1.05.03
    renderpluginsextensions
    30 Posts 3 Posters 4.4k Views 3 Watching
      sepo
      No I have not turned on global material override. None of the materials are showing in the Material editor as well.
        Really? That's just plain odd. You don't have the same list of materials in V-Ray editors as in SU?
        Never seen that.
          sepo
          Oh... I have list all right but no textures just shades of grey.
            Has the location of your textures changed?
              sepo
              In what sense?
                Are the textures visible in SU?
                Are they only grey when rendering? if so: have you moved the original textures you've used?
                  sepo
                  The textures are visible in SU. The textures are greyscale in Vray mat editor and renders are greyscale with sky in colour. I have not moved any textures. The models render with Podium and Twilight without any problems.
                    What does it say in the Render Progress window? For each texture it should say if it fails or loads successfully.
                      sepo
                      Here is screenshot
                        sepo
                        MtlMulti (noname) "mtls" parameter is deprecated; use "mtls_list" and "ids_list" instead.
                          That always appears at the beginning. That's normal. But after that - there should be references to the textures used - and after the file paths it should say if they loaded correctly or not.
                            sepo
                            here is copy of the render progress.
                            render progress.txt
                              Bitmap file "C:\ProgramData\ASGvis\VRayForSketchUp\Textures\CEDARWOOD2.jpg" failed to load: cannot open file
                              Bitmap file "C:\ProgramData\ASGvis\VRayForSketchUp\Textures\Grass0066_1x_L.jpg" failed to load: cannot open file
                              Bitmap file "C:\ProgramData\ASGvis\VRayForSketchUp\Textures\Concrete9.jpg" failed to load: cannot open file
                              Bitmap file "C:\Users\s porobic\Desktop\Water Textures\untitled.bmp" failed to load: cannot open file
                              Bitmap file "C:\ProgramData\ASGvis\VRayForSketchUp\Textures\IMGP3728.JPG" failed to load: cannot open file
                              Bitmap file "C:\ProgramData\ASGvis\VRayForSketchUp\Textures\sedum 2made.jpg" failed to load: cannot open file
                              Bitmap file "C:\Documents and Settings\All Users\Application Data\ASGvis\VRayForSketchUp\Textures\Fencing_Wood_Old.jpg" loaded.
                                sepo
                                So why is that? Any ideas what is the solution?
                                  Are you able to open them in other applications?
                                  Have you tried to clear you temp folder?
                                    sepo
                                    As I said before no problem rendering in Podium and Twilight.
                                      They might be loading the textures embedded into SU. V-Ray tried to open the original files.
                                      Try to open the files in an image editor.
                                        sepo
                                        I opened texture files in CS3 from SU (context click)...dumped tmp files and no change.
                                          No - try to open the files from the location VfSU reports it tried to load them from.
                                            sepo
                                            hmm program data is hidden ...how do you reveal it? 😳
