    Problem with 1.05.03
    renderpluginsextensions
    30 Posts 3 Posters 5.3k Views 3 Watching
      sepo
      Don't have it here as it is on the other computer. But imagine Black and white render with normal sky.
        sepo
        Did try with just coloured box in fresh file and Vray rendered no problem so I deduced the problem is not with Vray itself.
        Did try exploding absolutely everything but that did not do.
        The files render with Podium and Twilight no problem.
          You haven't turned on the Global Material override have you?
            sepo
            No I have not turned on global material override. None of the materials are showing in the Material editor as well.
              Really? That's just plain odd. You don't have the same list of materials in V-Ray editors as in SU?
              Never seen that.
                sepo
                Oh... I have list all right but no textures just shades of grey.
                  Has the location of your textures changed?
                    sepo
                    In what sense?
                      Are the textures visible in SU?
                      Are they only grey when rendering? if so: have you moved the original textures you've used?
                        sepo
                        The textures are visible in SU. The textures are greyscale in Vray mat editor and renders are greyscale with sky in colour. I have not moved any textures. The models render with Podium and Twilight without any problems.
                          What does it say in the Render Progress window? For each texture it should say if it fails or loads successfully.
                            sepo
                            Here is screenshot
                              sepo
                              MtlMulti (noname) "mtls" parameter is deprecated; use "mtls_list" and "ids_list" instead.
                                That always appears at the beginning. That's normal. But after that - there should be references to the textures used - and after the file paths it should say if they loaded correctly or not.
                                  sepo
                                  here is copy of the render progress.
                                  render progress.txt
                                    Bitmap file "C:\ProgramData\ASGvis\VRayForSketchUp\Textures\CEDARWOOD2.jpg" failed to load: cannot open file
                                    Bitmap file "C:\ProgramData\ASGvis\VRayForSketchUp\Textures\Grass0066_1x_L.jpg" failed to load: cannot open file
                                    Bitmap file "C:\ProgramData\ASGvis\VRayForSketchUp\Textures\Concrete9.jpg" failed to load: cannot open file
                                    Bitmap file "C:\Users\s porobic\Desktop\Water Textures\untitled.bmp" failed to load: cannot open file
                                    Bitmap file "C:\ProgramData\ASGvis\VRayForSketchUp\Textures\IMGP3728.JPG" failed to load: cannot open file
                                    Bitmap file "C:\ProgramData\ASGvis\VRayForSketchUp\Textures\sedum 2made.jpg" failed to load: cannot open file
                                    Bitmap file "C:\Documents and Settings\All Users\Application Data\ASGvis\VRayForSketchUp\Textures\Fencing_Wood_Old.jpg" loaded.
                                      sepo
                                      So why is that? Any ideas what is the solution?
                                        Are you able to open them in other applications?
                                        Have you tried to clear you temp folder?
                                          sepo
                                          As I said before no problem rendering in Podium and Twilight.
                                            They might be loading the textures embedded into SU. V-Ray tried to open the original files.
                                            Try to open the files in an image editor.
