Way to Kick Out Ugly Purple/White Default Material
Hi everyone
I'm using Sketchup 7.1. I'm really annoyed with the default purple/white material. Following are the reasons- On rendering with vray.. this damn default white comes out to be the colour of mozarella cheese. That creamy off white colour..
- Many times on editing geometry, if we delete some lines, then the planes automatically reverse themeseleves, revealing this ugly colour. I'm using thomthom selection toys for replacing the default material to white in my projects but deleting this ugly colour from my system appears to be a better choice.
So is there any trick to just eliminate this default material and make pure white as the default material?? I tried deleting the skm file but it doesn't help. Sketchup automatically creates the default skm on loading.
You can edit your style's default materials (front and back face) in your Window > Styles > In model > Edit > Face settings panel. Then save it as your custom template under the File menu and set it as your default template under Preferences > Templates.
Note that when rendering Default Material in VfSU - only the recent version will take into account the Style setting in SU. Previous versions had it hard wired.
hard wired?? I don't understand.. I have 1.05.30 will it work or is it exclusively for 1.48.66?? But isn't there any way to delete the ugly purple material from sketchup once and for all??
i'm not sure if you know this but the purple is to indicate back faces. if you see any you should right click the face and select reverse faces to avoid problems anyways.
never leave back faces (purple) showing (its bad practice), they will cause problems when rendering. -
It means that only 1.48 and later will use the custom default colour in your SU style. All others will render default as creamy off white for front faces and blue for backfaces.
never leave back faces (purple) showing (its bad practice), they will cause problems when rendering.i already know this man..can anyone tell me to please...please delete this ugly material forever from the sketchup interface??
Change your Style so that the two sides of a face are colored as you like [along with everything else!].
It IS a good idea to have them different colors, so in monochrome mode you can see which faces are the 'wrong way round'...
I have a trouble-shooting Style with distinctive face-colors, edge-styles, end-points, hidden/smoothed 'on', color-lines by axis, monochrome-mode etc - this lets me see which lines AND faces aren't 'right'...
Having a face reversed so its back is textured looks OK in SUp, BUT will produce unexpected rendering when exported etc..........
You can not delete the default material. Only change its colours.
personally i use orange. its sometimes hard to see the purple when its in the shade.
Whenever I can I use a style with bacfaces set to solid black and front faces to white. I try never to paint back faces. This style setting eliminates for most of the time the need to use the Section Cut Face ruby, as correctly modeled sections are rendered black "inside".
Anssi
Anssi
That's a neat method!
Yes, I also do this although not while modelling as the black edges are hard to spot on the black background. However with section cut animation, this is the only way to do without those ugly "hollows" (and of course, TIG1s plugin cannot be used for animations).
But it's easy to set up several styles in a model so there's no problem with it.
Anssi
Very clever method Anssi Sir!!!
When I first saw this topic come up I thought It said. .. "Way to Kick out the Ugly People/ White DeFault Material"
I like it here at the SCF forum. . .so yeah. . .
I took a little Umbrage at that.
