    Edge Roundover on Cylinder
    8 Posts 6 Posters 3.4k Views 6 Watching
      Dekade
      I drew a 2" diameter circle. I Push/Pulled it to 1" tall. I want to add a 1/4" radius rounded edge around the top and bottom 2" diameter circumferences. ❓ I can't figure out how and where on the cylinder to draw the 1/4" radius profile in order to use the Follow Me tool.
      Sure would appreciate some help!!
      Thank You,
      Dekade
      Knowing JESUS CHRIST, and living daily for Him, is a good thing; not an embarrassment.
      • jeff hammondJ Offline
        there's quite a few methods to accomplish this.. the simplest non-ruby method for me would be....
        click on pic for larger.
        • david_hD Offline
          david_h
          There's lots of ways to do this but the fastest is just with the ROUNDED EDGES PLUGIN to do it manually with FollowMe and all ofthat just takes to long. Life's too short. Download this little sweetie from that The Great Wizard Fredo and you're on easy street!
          πŸ˜„
          • david_hD Offline
            david_h
            sorry . . .I didn't want to sound like I was dissing Jeff's Response. We were working simultaneously on this it seems. Sorry Jeff.
            Dekade>>>Jeff's way is good too! 😳
              Beaten to it... but I'll publish and be damned... πŸ˜‰
              Note the advice about small shapes - they won't face with FollowMe... scale up and back down afterwards to fix that...
              There ARE many great Plugins available - rounding edges, making fillets and the like - but it's best to know how to do it manually - even if you ignore it later... πŸ€“
                Dekade
                Thanks everybody. I'm gonna give the Plug-in option a run at it first. I have used some really good plug-ins from Fredo and others.
                Thanks Again, Have a nice day.
                Thank You,
                Dekade
                  joshuakahn
                  Yes, I've been using the manual method with follow me to create a 3d rectangle with fillets on all edges, but am left with holes on the rounded corners. Scale was the reason and you're the first reference I've seen to the scale issue. Thank you.
                    suncoaster45
                    The advice re scaling up small objects before attempting to chamfer them then back down again after is golden. This nearly drove me nuts before I read it. πŸ˜†
