[Plugin] Flattery papercraft tools
91 Posts 41 Posters 85.7k Views
    jiminy-billy-bob
    Oh? Sorry, I must have mixed up the files...
      jiminy-billy-bob
      As there seem to be no way to contact the author and the copyright allows it, I modified the plugin to make it work in SU2014. It should still work fine in older versions. Here it is:
      ****Working version for SketchUp 2014:
      EDIT : Download in the pluginstore: http://sketchucation.com/pluginstore?pln=Flattery
      Maybe an admin can replace it in the pluginstore?
      Modifications:
      tabtool.rb line 238: if @active_edge: > if @active_edge
      tabtool.rb line 276: if @active_edge && @dragging: > if @active_edge && @dragging
      tabtool.rb line 287: if @active_edge: > if @active_edge
      reunitetool.rb line 76: vertecies = Set.new > RUBY_VERSION.to_i < 2 ? vertecies = Set.new : vertecies = Sketchup::Set.new
        I've just added v1.0.2 files to the PluginStore [previously it had linked to the author's site where the incompatible file still resides].
        If the original author [who still has full credit] wants to remove it let us know.
        He is also free to take the corrected version and use it on his own site if he wishes...
        Under the clear terms of the (c) notice at the top of each of his files, he allows changes and reissue, provided his (c) is kept intact - which it is...
          shafir_am
          Thank you jiminy...
          It's working now (-:
            mcgully
            Can anyone please help me? On my old laptop flattery worked just fine. Now WIN8 , SU2013 version and installed flattery, all worked correctly but I just can't export the drawing. I click save but it wont appear in the folder. Also tried SU8 but didn't work neither.
              Jim
              A working version for 2014 is in the Plugin Store:
              SketchUp Plugins | PluginStore | SketchUcation
              SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
              (sketchucation.com)
                mcgully
                Thank you very much, in 2014 all works alright
                  magna2
                  I copyed the file into the extension folder, but it doesn't show up on the menu bar on SU2014. Anyone could help me out?
                  kind regards,
                  Magnar Totland
                    What do you mean you "copyed [sic] the file into the extension folder"?
                    Did you just download the .rbz file and copy it? And what extension folder? Did you place the .rbz file into the Plugins folder? If so, that's not the correct way to install plugins/extensions. Find the .rbz file and remove it back to Downloads or the desktop. Open SketchUp and go to Window>Preferences>Extensions. click on Install Extension, navigate to where you put the file, select it and choose Open. Continue with the installation. You should then see the toolbar for it under View>Toolbars.
                      magna2
                      Thank you! 😄
                        Please complete your SCF User Profile, we don't know your OS or SUp version.
                        We can offer more targeted advice if you had...
                        Most Plugins are available in the PluginStore:
                        The RBZ archive can be automatically installed with any SketchUp >= v8 using Preferences > Extensions > Install.... button...
                        If you installed the RBZ version of the SketchUcation PluginStore toolset, then you'll be able to AutoInstall from the PluginStore without even worrying about the RBZ download - every step is doe automatically...
                        Don't forget that most Plugins are 'free', so carping on about inadequacies is not constructive...
                        Perhaps the author is a code whizz who can't explain himself well?... but you as an erudite chap could help by sharing knowledge and make the work a better place - rather that making people feel bad.
                        Post a useful tip, like, "Flattery Tip: After selecting and indexing, you'll need to deselect and reselect before 'unfolding'..."
                          sgisler
                          I need some help;I've tried installing this plugin and cant seem to get it to work. (Sketchup (Make) 2014, Win8). following the procedure: Window>Preferences>Extensions. click on Install Extension, navigate to where you put the file, select it and choose Open. the toolbar doesn't show up and upon closing/reopening Sketchup I get the error dialog:
                          Error Loading File C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery/toolbar.rb
                          Error: #<SyntaxError: C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery/tabtool.rb:238: syntax error, unexpected ':', expecting keyword_then or ';' or '\n'
                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery/tabtool.rb:276: syntax error, unexpected ':', expecting keyword_then or ';' or '\n'
                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery/tabtool.rb:287: syntax error, unexpected ':', expecting keyword_then or ';' or '\n'
                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery/tabtool.rb:291: syntax error, unexpected keyword_end, expecting end-of-input>
                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery/toolbar.rb:24:in <top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery.rb:28:in register_extension'
                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery.rb:28:in `<top (required)>'
                            Where did you get the version of Flattery that you downloaded? It shouldn't be installed in the Tools folder but from the error messages, it appears it has been installed there. It would appear you have an outdated version. You should first navigate to the tools folder and delete any all files related to Flattery and start from scratch with a fresh copy. The correct version is in the Plugin Store. Use it to auto-install the plugin correctly.
                              sgisler
                              Thanks Dave R,
                              just tried that. deleted all instances of Flattery and auto-installed from inside Sketchup. The toolbar still does not appear. Window>Preferances>Extensions shows it in the active list. but no joy. The Plugins Manager shows it as loaded, however the Extensions Manager show it as Disabled.
                                What does the following mean exactly?
                                ...and auto-installed from inside Sketchup
                                How did you install it? Did you download a fresh copy? Or did you use the Sketchucation Plugin Store to install it?
                                What happens when you attempt to enable it in the Extensions Manager? Is there an entry for Flattery in the toolbars list? If you close SketchUp and reopen it, are there any messages? What are they?
                                  sgisler
                                  I've deleted every instance I could find ad will try again.
                                  I installed with the Sketchucation plugin store; searched the plugin store within Sketchup, click autoinstall,
                                  well, I was doing it as I was typing a blow-by-blow and lo and behold it worked. Don't know what I did differently this time. I've tried at least a dozen times to install it both manually and thru the plugin store. Hmm, dunno. At least its working now.
                                  thanks for your help!
                                  Stan
                                    madebyme
                                    Can you specify material thickness with this plugin? Thanks
                                    • F Offline
                                      frankenpaper
                                      I tried following the instructions provided by http://www.pumpkinpirate.info/flattery/
                                      which did not result in a toolbar. The email address provided does not work either.
                                      My wife found the answer that works. I could not get along without her!
                                      Go to the Menu
                                      Window> Preferences> Extensions>
                                      Click the Install Extensions... button
                                      Browse to your downloads folder
                                      Select the file
                                      Flattery_v1.0.2.rbz
                                      Click the Open Button
                                      Follow the usual "Yes, OK, I Agree" type options.
                                      Now Flattery is correctly installed and you will have the menu bar you expected.
                                      I Hope this helps you too!
                                        Or you could just use the Sketchucation Plugin Store to install it automatically and not have to go through all those steps.
                                          Porkobosso
                                          Its almost 2016. Please make it work with SU2015
                                          • 4 / 5
