    [Plugin] Flattery papercraft tools
    91 Posts 41 Posters 130.5k Views 41 Watching
      magna2
      I copyed the file into the extension folder, but it doesn't show up on the menu bar on SU2014. Anyone could help me out?
      kind regards,
      Magnar Totland
        What do you mean you "copyed [sic] the file into the extension folder"?
        Did you just download the .rbz file and copy it? And what extension folder? Did you place the .rbz file into the Plugins folder? If so, that's not the correct way to install plugins/extensions. Find the .rbz file and remove it back to Downloads or the desktop. Open SketchUp and go to Window>Preferences>Extensions. click on Install Extension, navigate to where you put the file, select it and choose Open. Continue with the installation. You should then see the toolbar for it under View>Toolbars.
          magna2
          Thank you! 😄
            Please complete your SCF User Profile, we don't know your OS or SUp version.
            We can offer more targeted advice if you had...
            Most Plugins are available in the PluginStore:
            http://sketchucation.com/pluginstore?pln=Flattery
            The RBZ archive can be automatically installed with any SketchUp >= v8 using Preferences > Extensions > Install.... button...
            If you installed the RBZ version of the SketchUcation PluginStore toolset, then you'll be able to AutoInstall from the PluginStore without even worrying about the RBZ download - every step is doe automatically...
            Don't forget that most Plugins are 'free', so carping on about inadequacies is not constructive...
            Perhaps the author is a code whizz who can't explain himself well?... but you as an erudite chap could help by sharing knowledge and make the work a better place - rather that making people feel bad.
            Post a useful tip, like, "Flattery Tip: After selecting and indexing, you'll need to deselect and reselect before 'unfolding'..."
              sgisler
              I need some help;I've tried installing this plugin and cant seem to get it to work. (Sketchup (Make) 2014, Win8). following the procedure: Window>Preferences>Extensions. click on Install Extension, navigate to where you put the file, select it and choose Open. the toolbar doesn't show up and upon closing/reopening Sketchup I get the error dialog:
              Error Loading File C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery/toolbar.rb
              Error: #<SyntaxError: C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery/tabtool.rb:238: syntax error, unexpected ':', expecting keyword_then or ';' or '\n'
              C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery/tabtool.rb:276: syntax error, unexpected ':', expecting keyword_then or ';' or '\n'
              C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery/tabtool.rb:287: syntax error, unexpected ':', expecting keyword_then or ';' or '\n'
              C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery/tabtool.rb:291: syntax error, unexpected keyword_end, expecting end-of-input>
              C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
              C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery/toolbar.rb:24:in <top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
              C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery.rb:28:in register_extension'
              C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery.rb:28:in `<top (required)>'
                Where did you get the version of Flattery that you downloaded? It shouldn't be installed in the Tools folder but from the error messages, it appears it has been installed there. It would appear you have an outdated version. You should first navigate to the tools folder and delete any all files related to Flattery and start from scratch with a fresh copy. The correct version is in the Plugin Store. Use it to auto-install the plugin correctly.
                  sgisler
                  Thanks Dave R,
                  just tried that. deleted all instances of Flattery and auto-installed from inside Sketchup. The toolbar still does not appear. Window>Preferances>Extensions shows it in the active list. but no joy. The Plugins Manager shows it as loaded, however the Extensions Manager show it as Disabled.
                    What does the following mean exactly?
                    ...and auto-installed from inside Sketchup
                    How did you install it? Did you download a fresh copy? Or did you use the Sketchucation Plugin Store to install it?
                    What happens when you attempt to enable it in the Extensions Manager? Is there an entry for Flattery in the toolbars list? If you close SketchUp and reopen it, are there any messages? What are they?
                      sgisler
                      I've deleted every instance I could find ad will try again.
                      I installed with the Sketchucation plugin store; searched the plugin store within Sketchup, click autoinstall,
                      well, I was doing it as I was typing a blow-by-blow and lo and behold it worked. Don't know what I did differently this time. I've tried at least a dozen times to install it both manually and thru the plugin store. Hmm, dunno. At least its working now.
                      thanks for your help!
                      Stan
                        madebyme
                        Can you specify material thickness with this plugin? Thanks
                        • F Offline
                          frankenpaper
                          I tried following the instructions provided by http://www.pumpkinpirate.info/flattery/
                          which did not result in a toolbar. The email address provided does not work either.
                          My wife found the answer that works. I could not get along without her!
                          Go to the Menu
                          Window> Preferences> Extensions>
                          Click the Install Extensions... button
                          Browse to your downloads folder
                          Select the file
                          Flattery_v1.0.2.rbz
                          Click the Open Button
                          Follow the usual "Yes, OK, I Agree" type options.
                          Now Flattery is correctly installed and you will have the menu bar you expected.
                          I Hope this helps you too!
                            Or you could just use the Sketchucation Plugin Store to install it automatically and not have to go through all those steps.
                              Porkobosso
                              Its almost 2016. Please make it work with SU2015
                                It already works with SU2015.
                                  As DaveR says, it was fixed sometime ago to work with the newer SketchUp versions [ i.e. >= v2014 ].
                                  The original download on the author's website is old, and therefore incompatible with anything > v2013.
                                  I do not believe the author is supporting this tool any longer...
                                  However, under the terms of the tool's (c) license I updated it in April this year, and so that version of it is available from the PluginStore [but not elsewhere!]...
                                  • chriC Offline
                                    chri
                                    hi
                                    please find after a small animated explanation.
                                    ( done with GifCam : http://blog.bahraniapps.com/gifcam/ )
                                    Chri
                                      BRG
                                      I have installed your Flattery plugin and it is doing a great job unfolding designs. However, when I click on the SVG button, I get the pop up menu to select where to save the file but the svg file type does not appear in the lower box. In fact, no file type appears. Any idea how I can fix this?
                                        @BRG
                                        I assume you have the latest version from the PluginStore, which has some compatibility issues fixed: http://sketchucation.com/pluginstore?pln=Flattery
                                        The SVG export works fine for me.
                                        Have you got a 'Flattery' group?
                                        It must be the only thing selected when you activate the Flattery-SVG exporter ?
                                        Then you get the export-dialog with a named.svg etc...
                                          Mic2012
                                          I've translated the Flattery plugin Doc in French look at the Download link for PDF
                                          J'ai traduit le plugin Flattery en Français voir le lien Download pour le PDF
                                          Download: https://1drv.ms/f/s!AFl38Tl2pzx-g-gv
                                            JSA_SJ
                                            What I downloaded was only a .php file, not .rbz as normal plug-ins are.
                                            Please help.I got 'pluginserv_joomla.php', did I do anything wrong??
                                            • 4 / 5
