    • Log Masuk
    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    Scheduled Pinned Kunci Moved Plugins
    1.1k Kiriman 345 Posters 2.4m Lihat 342 Watching
    Memuatkan lagi kiriman
    • Lama ke Baru
    • Baru ke Lama
    Balas
    Log masuk untuk balas
    Topik ini telah dipadam. Hanya pengguna dengan kuasa pengurusan boleh melihatnya.
    • P Luar talian
      palphd
      @palphd said:
      for some reason, i keep getting a bug splat when i try to use radial bending and change the number of slices... everything else seems to work fine though. any ideas? it used to work fine 😞
      Could you post the model or send it to me via PM so that I have a look
      thanks for the response, freedo! sure thing... it's actually not any particular model. i attached a tall box form that i just tried to no avail (changed the slice setting to 6). the pic show as far as i can get with the process, but once i designate a rotation angle, it shuts down every time, no matter what shape, model, etc.
      by the way, i just installed updated sketchup 6 pro to version 6.4.265 recently if that makes a difference.
      model
      1 Reply Last reply Balas Petikan 0
      • GaieusG Luar talian
        Hi Chris,
        Just drag and drop. There will be "bare" rb files directly under the main plugins folder and there will be some subfolders, too. Just do NOT let Windows create a main, containing subfolder under plugins (as it generally tends to do from the archive name).
        • S Luar talian
          SnowTiger
          Thanks kindly Gaieus ... again.
          You are truly one handy fellow. I have learned much from you, both directly and indirectly.
          Keep up the great work .. both helping others and with your future modeling endeavors.
          Keep on keeping on.
          • P Luar talian
            palphd
            i think i figured out my problem. i noticed that every time the curves were being computed in radially bending, the outliner box would tweak out just before su crashed... the next time, i closed the outliner box, tried it again and voila - everything worked fine. must not be able to handle the rapid, real time changing of groups, etc.
              @palphd said:
              ...must not be able to handle the rapid, real time changing of groups, etc.
              That may wellhave been the case - as many plugins that create a great deal of geometry in a short time tend to crash or at least hang SU when the Outliner is active.
              • P Luar talian
                palphd
                thanks gaieus... it's probably a topic that's been discussed at length in various threads, but i had been previously unaware. good to know. shut that outliner down and all is well!
                • fredo6F Luar talian
                  In SU6, there are reported crash with the outliner box.
                  This has been fixed in SU7, where the outliner box refresh is suspended.
                  I think I indicated this somewhere in the documentation, but it's good to refresh all minds.
                  • S Luar talian
                    SnowTiger
                    I keep getting a loading error when I open SU.
                    Can someone please tell me how to attach an image (screen shot of error) that is presently on my desktop ?
                      Hi Chris,
                      IF you have saved that screenshot into an image file and answering to my post here, just scroll down a little bit until you find the "Upload attachment" tab.
                      • S Luar talian
                        SnowTiger
                        Duh ... never saw that "Upload Attachment" Tab before. Thanks
                        Hopefully I did this right so the image is attached.
                        FredoScale 2 Error Screenshot
                          Did you install LibFredo6?
                          fredo
                          • S Luar talian
                            SnowTiger
                            Sorry for the slow reply.
                            Yes, I did install LibFredo 6 immediately after installing FredoScale 2.
                            In fact, there is now a LibFredo 6 Dir 34 Folder now in my Plugins Folder
                              Please make sure that in your Skecthup Plugin Directory you have:
                              • ZLoader_FredoScale.rb
                              • LibFredo6.rb
                              • FREDOSCALE_Dir_20 folder (containing several other rb files and IMAGES_STANDARD subfolder)
                              • LIBFREDO6_Dir_34 folder (containing several other rb files and IMAGES_STANDARD subfolder)
                                That's all you need. Never rename or move files manually.
                              • S Luar talian
                                SnowTiger
                                I have checked and can confirm I have all the files, folders and sub-folders with files that you have indicated.
                                I haven't had opportunity to try any of the associated tools yet, but there is a toolbar and everything else appears to still be functioning properly.
                                I might have to revert back to the other day (somehow) and try re-installing from scratch again.
                                I wonder if anything got overwritten during the installation.
                                As mentioned, I installed the LibFredo 6 "After" installing FredoScale 2".... Should it have been installed prior to FredoScale 2 ?
                                  Well, as they are "simple" text files and no registry or similar is written in the system, the installation order doesn't really matter.
                                  • L Luar talian
                                    larrylarry
                                    Fredo grand sorcier ! bravo, merci !!!
                                    • M Luar talian
                                      mac1
                                      In attempting to create a model of a stack of business cards 0.5m thk,0.2 mm spaced the distortion across the thickness was not acceptable. Instead a rectangular face was created with zero thickness, cards stacked by the linear array approach and then rotated using the box twist option in FredoScale. However when an attempt to replace the card face unique components created by twist operation with a card coponent ( with thickness) from the component browser the cards showed no twist. See the attached test model( Note it is drawn at a larger scale). The reason for this is the component axis are not rotated per the normal SU componet rotation and in addition the component browser card face definition is also modified with the twist operation.
                                      Is this normal or am I doing something wrong? Can or should this be corrected? Changes to the model are discussed in the manual but I question if changes of the components in the browser should be done??
                                      A work around using the projection plugin is possible but should it be necessary??
                                      Card stack tes.skp
                                      • TIGT Dalam talian
                                        Perhaps look at Grow.rb or ComponentStringer.rb ?
                                        • F Luar talian
                                          fishdiva
                                          Sheer Genius, Fredo! Love the Radial Bending feature - Google should definitely make this INDISPENSABLE feature official.
                                          For some reasons FredoScale toolbar does not appear but since right click does the same job this is a minor issue...
                                          Thank you again for a great piece of work!!
                                          • TIGT Dalam talian
                                            fishdiva
                                            The FredoScale plugin is registered as an 'extension' so you need to activate it from Window > Preferences > Extensions + tick FredoScale & OK; and then [probably] open it from View > Toolbars > FredoScale ...
                                            • 39
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 56
                                            • 57
                                            • 41 / 57
