    Issues with vray 1.05.30 and elev 45 shadows plugin
    renderpluginsextensions
    4 Posts 3 Posters 887 Views 3 Watching
      arjunmax09
      I'm having a problem using Elev45shadows and vray for sketchup 1.5.30 combined....I need to change the location of my model to any city but not boulder to get 45 shadows io.....but vray doesn't accept this..It only remembers the default location settings that is of boulder colorado...what should i do to fix this......I'm using Sketchup Pro 7.1
      when you fail at something....you haven't really failed...you've found one way the thing will not work out
        If you import the model into a new empty skp and manually change the location to somewhere else then run elev45shadows will it set then...
        With v7 you can only have one location per model so you might have to use several inserts for all of the elevations...
          arjunmax09
          the vray render engine doesn't go well with elev 45 shadows... it remembers the default shadow setting only... for example if i changed the location from boulder to manchester... it will remember the location as boulder only..and my file doesn't have scenes...
            Can you share a test scene?
