    [Plugin] Extrude Edges by Rails
    381 Posts 71 Posters 424.8k Views 71 Watching
      stefx
      Thank you very much Pilou!
      Job Done!
      I needed so much that script working well because i need to create something like that:
      http://img403.imageshack.us/img403/1400/catturaspirale.jpg
      I have seen something similar in this topic.
      I need 2 different spiral curve and then a surface that run through the 2 spirals.
      Any tips?
        No problem
        Draw your 2 helix curves and just one "divided line"
        Call the plug, CLick the line, CLick curve rail 1, click curve rail 2, click again the line!
        I suggest you to draw just one module then make a group or a component then copy past it!
          stefx
          Job done!
          Thank you!
          Quick and without problems!
          I have tried to download the plugin "curvemaker" from the website http://www.drawmetal.com but the website doesn't work. Any info about that?
          I think that could be a good plugin.
          thanks a lot!
            Seems their addresses are changed! (expire in april)
            so you must use another plug or draw your module curves by hand πŸ˜‰
              Right click : divide your line ? πŸ˜‰
              And weld them in any case or if you have several in connection! β˜€
              • X
                xrok1
                @xrok1 said:
                i've even downloaded the example file and the latest .zip and i still can't get this to work. the lines change colors, i get all the dialog boxes reverse...etc, but no result. 😒
                does everyone have me on ignore? πŸ˜† this is the second time i've reported this. once a version or 2 back and it has never worked. 😒
                  Can you post your own file who don't work?
                    stefx
                    Thank you Pilou!
                    πŸ˜„
                      it's a pleasure πŸ˜„
                      • X
                        xrok1
                        even tried tig's example file from the second page of this post so i don't think its the files. maybe i'm missing some other file that's needed. like progress bar or something although i know its not that.
                          Hi Rocky,
                          Works perfect for me? Here's a snapshot of my plugin folder if you wanna see how it compares to yours?
                          Maybe something will standout?
                          • X
                            xrok1
                            mines bigger πŸ˜† thanks for the post. i don't see anything unusual.
                            • X
                              xrok1
                              hmmm! i just tried it on an old install of su6 and su7 worked fine in both. must be another plugin in my current su install screwing with it! any ideas tig?
                                There shouldn't be any clashes - everything should be 'self-contained'...
                                I have every plugin known to man, and then some more, so if anyone were to get a clash it'd be me πŸ˜•
                                Have you tried Model Info > Statistics > Fix Problems...
                                Or try selecting the rail/profile curve and the using edit > cut and paste-in-place - this sometimes reforms the curve if there's glitch in the model's database - do all four in turn.
                                Another possible fix is to explode and immediately re-weld the curves in turn, and another fix is to group the curve, edit > copy, erase the original group, then paste-in-place and explode the replacement group back into its curve.
                                Sometimes curves vertices get muddled and the algorithms in the scripts fail to order them no matter how hard they try, etc...
                                Perhaps post the problem skp and let us all have ago too ?
                                πŸ˜•
                                • X
                                  xrok1
                                  i could post the file but this is how simple it is. draw three arcs, pick profile rail rail same profile again, then i get all the message boxes but no result!
                                    have you try with a previus version of the plug?
                                    I have not yet the last version (no color of curves picked) 😳
                                    and that works fine β˜€
                                    • X
                                      xrok1
                                      yes its never worked for me 😞 and like i said it does work with other installs of SU i have in oldProgramFiles folder left over from when i upgraded to win7.
                                        As a matter of interest, did you try it in XP compatability mode? Doubt it'll make any difference as it runs on my Win7 perfectly ok!
                                        But worth a shot to see if its Windows related?
                                        I had similar issue with 'Screw' ruby and Pilou's 'Fragmentation' plugin. Constant Bugsplat anytime i ran them. Ended up backing up 'Plugins' folder and reinstalling SU7.1. Worked fine after that? Don't know why and don't care.
                                        Really strange that it lets you complete the whole process but doesn't give any resulting geometry.
                                        • X
                                          xrok1
                                          can't see it being a windows issue because
                                          but i tried the compatibility thing anyway... no luck!
                                          • X
                                            xrok1
                                            grasping at straws here but i wonder if its not debabilizer? are there any other plugs that use this so i could check if they work?
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 15 / 20
