    [Plugin] Extrude Edges by Rails
    381 Posts 71 Posters 348.7k Views 71 Watching
      A new version is now available here http://forums.sketchucation.com/viewtopic.php?p=217663#p217663 which fixes the helical rail glitch that was reported...
      • DareDevilD Offline
        DareDevil
        😍 It's working ! Thanks you TIG !
          Tool has been updated
          2.9 20100220 Color coding of picked curves added.
          Profile=Cyan
          Rail1=Magenta
          Rail2=DarkVioletRed
          MeldingProfile=DarkCyan
          See here for download link http://forums.sketchucation.com/viewtopic.php?p=201286#p201286
            stefx
            I have missed the website for a bit and I see this wonderful plugin!
            I was waiting for that since long time....for many shapes i was still using rhino's tool:sweep2rails.
            I am going to play with that but I want to ask:
            I create due rails e my curve profile and it works well, but if I would like just a line rather than a curve....it looks like an error.
            Sorry probably i have to read better, anyone has a simple answer?
            thank you.
              stefx
              I am still trying...but not results... 😞
              When i try to select a simple line rather than a curve (just the first step before the selection of the 2 rails), it is impossible to select anything, but if i draw a curve it wors immediately.
              It looks like strange!
              I know....it is a stupid error by me!
                I calll the plug then click a "line" first: no problem β˜€
                Sure! you have not divided it!!! πŸ˜‰ 'see my previous post! πŸ€“
                A simple line not divided can't be selected !
                • X Offline
                  xrok1
                  i've even downloaded the example file and the latest .zip and i still can't get this to work. the lines change colors, i get all the dialog boxes reverse...etc, but no result. 😒
                    stefx
                    Thank you very much Pilou!
                    Job Done!
                    I needed so much that script working well because i need to create something like that:
                    http://img403.imageshack.us/img403/1400/catturaspirale.jpg
                    I have seen something similar in this topic.
                    I need 2 different spiral curve and then a surface that run through the 2 spirals.
                    Any tips?
                      No problem
                      Draw your 2 helix curves and just one "divided line"
                      Call the plug, CLick the line, CLick curve rail 1, click curve rail 2, click again the line!
                      I suggest you to draw just one module then make a group or a component then copy past it!
                        stefx
                        Job done!
                        Thank you!
                        Quick and without problems!
                        I have tried to download the plugin "curvemaker" from the website http://www.drawmetal.com but the website doesn't work. Any info about that?
                        I think that could be a good plugin.
                        thanks a lot!
                          Seems their addresses are changed! (expire in april)
                          so you must use another plug or draw your module curves by hand πŸ˜‰
                            Right click : divide your line ? πŸ˜‰
                            And weld them in any case or if you have several in connection! β˜€
                            • X Offline
                              xrok1
                              does everyone have me on ignore? πŸ˜† this is the second time i've reported this. once a version or 2 back and it has never worked. 😒
                                Can you post your own file who don't work?
                                  stefx
                                  Thank you Pilou!
                                  πŸ˜„
                                    it's a pleasure πŸ˜„
                                    • X Offline
                                      xrok1
                                      even tried tig's example file from the second page of this post so i don't think its the files. maybe i'm missing some other file that's needed. like progress bar or something although i know its not that.
                                        Hi Rocky,
                                        Works perfect for me? Here's a snapshot of my plugin folder if you wanna see how it compares to yours?
                                        Maybe something will standout?
                                        • X Offline
                                          xrok1
                                          mines bigger πŸ˜† thanks for the post. i don't see anything unusual.
                                          • X Offline
                                            xrok1
                                            hmmm! i just tried it on an old install of su6 and su7 worked fine in both. must be another plugin in my current su install screwing with it! any ideas tig?
                                            • 11
                                            • 12
                                            • 13
                                            • 19
                                            • 20
                                            • 11 / 20
