    [Plugin] HouseBuilder metric 1.2
    79 Posts 42 Posters 117.9k Views 42 Watching
      thinkbuild
      Cher Didier,
      Bonjour! Alors, here's the report: I can't find the line you are talking about in the script. Pas trouve! It must be in one of the two scrambled files. Je regrete! Please advise if there is another way I can help!
      best wishes from Berlin,
      Jason
      • H Offline
        Hazza
        Is it possible to change this so that the wall (or whatever) you just created is undone in one go?
        See all of my SketchUp models here.
          MrPlanet
          Hi! i want to delete housebuilder from my computer but it says it is being used by another person when sketchup is closed,can someone tell me what's happening?,thanks
          I reject your reality and substitute my own.
          • F Offline
            flo
            I got here when I was looking for the answer to the post How do I print ti scale in SketchUp? I didn't find the answer but I found u guys talking about housebuilder. What is that?
              linea
              Thanks for the new script!
                rodericx
                its possible to translate ? i mean i dont know much about ruby (nothing actually), then this interesting plugin i wanted to use in spanish... then i see in the file : HouseBuilder_extention.rb some calls... like
                # Floor tool
                  cmd3 = UI;;Command.new(("Floor tool")) { Sketchup.active_model.select_tool HouseBuilder;;FloorTool.new }
                  cmd3.small_icon = "HouseBuilder/hb_floortool_S.png"
                  cmd3.large_icon = "HouseBuilder/hb_floortool_L.png"
                  cmd3.tooltip = "Creates a floor."
                  hb_tb.add_item(cmd3)
                then i want to know if i can replace the texts between "" without affect the plugin?. ๐Ÿ˜Ž
                  # Floor tool
                  Text within "" or even '' can be replaced with anything else you want - i.e. a translation... UNLESS it's a path to a file xxx/xxx/xxx.png etc DON'T change anything else - the worse that can happen is it won't work ! ๐Ÿ˜ฎ
                  Keep a copy of the original ! ๐Ÿ˜’
                    pedromarmol
                    @tig said:
                    # Floor tool
                    Hello!!
                    I'm a spanish user of Sketchup, i'm translating a lot of plugins for SU to spanish language.
                    I have finished the translation of House Builder ver. 1.0, and it works fine in Mac, only one problem, some units in the options of the tools are in inches, and i work in metres but it's a minor problem, the rest is OK.
                    I can't translate The House Builder ver. 1.2 because the files HouseBuilder.rb and HouseBuilderTool.rb are encoded, i have translated the HouseBuilder_extension.rb only, the icons appear and the tooltip too in spanish, but don't works in Mac, it appears the same problem:
                    Error al cargar archivo HouseBuilder_extension.rb
                    private method `split' called for nil:NilClass
                    I would like upload the Spanish version of House Builder v. 1.0 for all users and the others plugins. Please, tell me how.
                    • Didier BurD Offline
                      Didier Bur
                      Open the file in a text editor and go to line 34. It reads like this:
                      su_path = Sketchup.find_support_file("Sketchup.exe").split("Sketchup.exe")[0]
                      The problem is that there's no ".exe" files on Mac. Try to remove ".exe":
                      su_path = Sketchup.find_support_file("Sketchup").split("Sketchup")[0]
                      and see if it works.
                      Regards,
                      DB
                        tim
                        Not specifically to do with Didiers metric version, but I recently posted a few bug fixes relating to door opening size/position and that infuriating beep every time you context menu on http://forums.sketchucation.com/viewtopic.php?f=15&t=26858
                        I'm thinking of breaking out the different functions and rewriting some of the less pretty code but to be honest I find Ruby such an unpleasant system to work in that it rather puts me off. Maybe I should just build an interface to Smalltalk.
                        • Q Offline
                          quick
                          Bump
                          Any word on fixes for Metric 1.2 Mac version?
                          the files are scrambled, and i can't find any reference to sketchup.exe in the unscrambled file. could really do with a metric wall builder...
                            krokodandi
                            Real sweet, thx Didier! ๐Ÿ˜‰
                            thx Didier real work ๐Ÿ˜Ž
                            • GwyattG Offline
                              Gwyatt
                              Bump
                              any news on the mac fix i tried to edit on my mac to no joy scrambled code love this pack please point in right place if i'm looking wrong place
                                Didier Bur
                                Here is an 'unscrambled' version of the main script, with no reference to Sketchup.exe.
                                Hope it will work on Mac.
                                Regards,
                                Overwrite House_builder_extension.rb in your Plugins folder with this one.
                                DB
                                • X Offline
                                  Xelcho
                                  Being in the US I would love to have the functionality of the new toolbar based package in US units. I have already modified the txt file to make it work as though it were US units. Is there a all foot-inch version on the horizon?
                                    I guess the "original" was made to work with imperial untis. Try this:
                                    http://rhin.crai.archi.fr/rld/plugin_details.php?id=188
                                    or this one maybe:
                                    http://rhin.crai.archi.fr/rld/plugin_details.php?id=185
                                    • X Offline
                                      Xelcho
                                      Gaieus,
                                      Thanks for the info it is perfect. I would like to add to the list and expand it. I will let you know how it goes.
                                      Thank you,
                                      X
                                      • X Offline
                                        Xelcho
                                        Didier & Gaieus,
                                        I have worked with the version you recommended for a little while now and love the potential. However, there are a few things that it is lacking:
                                        It does not read from the txt file like the new version.
                                        It does not have the stock list function like the new version.
                                        Is it possible to add this functionality of the imperial version?
                                          Well, I have never used either version (and I am as good at programming in ruby as you seem to be). I only knew about that plugin but that's all where my potential help ends I am afraid...
                                            Didier Bur made this metric version from the original imperial one, and added some new things like the section-list.
                                            As you probably found he has 'encrypted' the code by packing it; so, unlike many scripts, it is not easily adjusted using a Notepad editor, a brain and a little effort...
                                            Whilst some of us know how to undo this encryption it would be unethical to mess with the code without his permission.
                                            Can I suggest you PM Didier direct and ask [nicely] that he looks at converting his metric version into an updated imperial '/" version - I'm sure that many US users would appreciate it too... It might be as simple as changing the section-list and a few lines of code in the scripts to '/" defaults rather than metric... ๐Ÿค“
                                            • 2 / 4
