    [Plugin] HouseBuilder metric 1.2
    79 Posts 42 Posters 115.6k Views 42 Watching
    • AnssiA Offline
      Anssi
      Giovanni,
      I think it is a matter of both local convention and structural strength. When I was taught about framing (half a zillion years ago) I was told to put the beam vertically. So from my point of view this should be correct.
      Anssi
      • Didier BurD Offline
        Didier Bur
        I agree with Anssi.
        But I want also say that it is NOT my script. The original was coded by S. Hurlbutt, I only tweaked it to metric units and parametric sections...
        DB
          dayakar78mac.com
          @didier bur said:
          if you have correctly unzipped the package in your Plugins folder, there should'nt be any problem.
          Check that you have:
          • HouseBuilder_extension.rb in your Plugins folder
          • a sub-folder named "HouseBuilder" with 2 other .rb files in it and a lot of png's and gif's as well. A .txt file is also there, with the wood sections listed in it.
          Read the readme.txt file for further details.
          Hi Didier,
          I have unzipped HouseBuilder_metric_12.zip in the Plugins folder. The HouseBuilder_extension.rb and sub-folder "HouseBuilder" are there as described by you. When I launch SketchUp, I still get the following error.
          "Error Loading File HouseBuilder_extension.rb private method split called for nil:NilClass"
          Could you please advice me to resolve this issue.
          I am using SketchUp Pro v6.0 on iMac, Mac os x 10.5.4.
          Thanks,
          Dayakar
          Error Loading file
            Didier Bur
            I'm puzzled because the "split" method is called several dozens of times in the code so I can't localize exactly where there's something wrong at startup. Maybe it's a Mac issue. Do you have a file "housebuilder_sections.txt in the HouseBuilder folder ? I guess yes...
            Give me some time to search...But take a look at the top of this thread, other people on Mac have the same issue as yours.
            DB
              pav_3j
              wow, thank you very much! this is awesome
              pav
              Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
                dayakar78mac.com
                @didier bur said:
                Hi Didier,
                Thank you for the response. Yes, I do have have housebuilder_sections.txt in the HouseBuilder subfolder. This script is very useful, I saw the demo of this script at http://sites.google.com/site/3dbasecamp2008/all-sessions-2008/maxing-out-your-productivity-with-ruby-scripts.
                Regards,
                Dayakar
                  thinkbuild
                  Greetings to all.
                  Didier, just a quick note - I just wanted you to know that I am also having the same issues with my mac.
                  private method `split' called for nil:NilClass"
                  Any ideas?
                  I tried to look for the "offending line" in the script but I quickly became confused. Is it "HouseBuilder_extension.rb", (which is not scrambled)
                  or "HouseBuilder.rb", or "HouseBuilderTool.rb" (both of which are scrambled)?
                  Please advise. I'm sure many of us in the Mac community would be very appreciative if we could get this to work!
                  cheers from Berlin,
                  Jason
                    Didier Bur
                    It is probably in "HouseBuilder_extension.rb" there.
                    I suspect this line is the offending one:
                    su_path = Sketchup.find_support_file("Sketchup.exe").split("Sketchup.exe")[0]
                    because there's no exe files on Mac, and they are located elsewhere. So su_path variable is nil, and when the script tries to locate the txt sections files, the su_path is splitted starting from a nil value, which raises error. (hope i'm clear ๐Ÿ˜ณ )
                    I'll take a look at this asap, but I'm very busy these days... Here is my todo list, apart from corporate devs:
                    Terrain reshaper
                    Housebuilder for Mac
                    Transformer keys positions
                    Align tool -> copy option
                    Extrudelinesalongpath (follow me for lines)
                    SU2STL & Heightfield_gen : binary tests
                    Instancing brush for compo spray
                    SU2POV mat editor sliders
                    ๐Ÿ˜„
                    DB
                      thinkbuild
                      bonjour didier ...
                      ok, i will see what i can do to make it work. note i am a total non-programmer, but maybe i'll have some luck and you can strike it off your list! i'll report back when i know if i have any success or not ๐Ÿ˜‰
                      a bientรดt!
                      jason
                        thinkbuild
                        Cher Didier,
                        Bonjour! Alors, here's the report: I can't find the line you are talking about in the script. Pas trouve! It must be in one of the two scrambled files. Je regrete! Please advise if there is another way I can help!
                        best wishes from Berlin,
                        Jason
                        • H Offline
                          Hazza
                          Is it possible to change this so that the wall (or whatever) you just created is undone in one go?
                          See all of my SketchUp models here.
                            MrPlanet
                            Hi! i want to delete housebuilder from my computer but it says it is being used by another person when sketchup is closed,can someone tell me what's happening?,thanks
                            I reject your reality and substitute my own.
                            • F Offline
                              flo
                              I got here when I was looking for the answer to the post How do I print ti scale in SketchUp? I didn't find the answer but I found u guys talking about housebuilder. What is that?
                                linea
                                Thanks for the new script!
                                  rodericx
                                  its possible to translate ? i mean i dont know much about ruby (nothing actually), then this interesting plugin i wanted to use in spanish... then i see in the file : HouseBuilder_extention.rb some calls... like
                                  # Floor tool
                                    cmd3 = UI;;Command.new(("Floor tool")) { Sketchup.active_model.select_tool HouseBuilder;;FloorTool.new }
                                    cmd3.small_icon = "HouseBuilder/hb_floortool_S.png"
                                    cmd3.large_icon = "HouseBuilder/hb_floortool_L.png"
                                    cmd3.tooltip = "Creates a floor."
                                    hb_tb.add_item(cmd3)
                                  then i want to know if i can replace the texts between "" without affect the plugin?. ๐Ÿ˜Ž
                                    # Floor tool
                                    Text within "" or even '' can be replaced with anything else you want - i.e. a translation... UNLESS it's a path to a file xxx/xxx/xxx.png etc DON'T change anything else - the worse that can happen is it won't work ! ๐Ÿ˜ฎ
                                    Keep a copy of the original ! ๐Ÿ˜’
                                      pedromarmol
                                      @tig said:
                                      # Floor tool
                                      Hello!!
                                      I'm a spanish user of Sketchup, i'm translating a lot of plugins for SU to spanish language.
                                      I have finished the translation of House Builder ver. 1.0, and it works fine in Mac, only one problem, some units in the options of the tools are in inches, and i work in metres but it's a minor problem, the rest is OK.
                                      I can't translate The House Builder ver. 1.2 because the files HouseBuilder.rb and HouseBuilderTool.rb are encoded, i have translated the HouseBuilder_extension.rb only, the icons appear and the tooltip too in spanish, but don't works in Mac, it appears the same problem:
                                      Error al cargar archivo HouseBuilder_extension.rb
                                      I would like upload the Spanish version of House Builder v. 1.0 for all users and the others plugins. Please, tell me how.
                                        Didier Bur
                                        Open the file in a text editor and go to line 34. It reads like this:
                                        The problem is that there's no ".exe" files on Mac. Try to remove ".exe":
                                        su_path = Sketchup.find_support_file("Sketchup").split("Sketchup")[0]
                                        and see if it works.
                                        Regards,
                                        DB
                                          tim
                                          Not specifically to do with Didiers metric version, but I recently posted a few bug fixes relating to door opening size/position and that infuriating beep every time you context menu on http://forums.sketchucation.com/viewtopic.php?f=15&t=26858
                                          I'm thinking of breaking out the different functions and rewriting some of the less pretty code but to be honest I find Ruby such an unpleasant system to work in that it rather puts me off. Maybe I should just build an interface to Smalltalk.
                                          • Q Offline
                                            quick
                                            Bump
                                            Any word on fixes for Metric 1.2 Mac version?
                                            the files are scrambled, and i can't find any reference to sketchup.exe in the unscrambled file. could really do with a metric wall builder...
                                            • 2 / 4
