    [Plugin] Volume Calculator2...
    64 Posts 23 Posters 91.0k Views 23 Watching
      Sorry to go OT, but I can't seem to get Sketchup 7.1.4871 to recognize the volume plugins. I've dropped them into the /Plugins folder with the rest of my plugins, all the rest of which work fine.
      Any ideas?
      Piyono
      It's a right-click context-menu item only - available if you have a group or component-instance selected... There's no menu item - if that's your point ? ❓
      • P
        piyono
        Ahh... I see.
        I was selecting primitive volumes, not groups or components.
        • kenK
          ken
          Well I haven’t used the plugin “Volume” for sometime and not sure when this problem started to occur. Right now, VolumeCalucator2.1, 2 or 1.7 or 1.8, all the versions I have, the context menu stays grayed out. Not sure what I have added to make this plugin’s context menu not functional.
          Just passing this on to you, don’t expect you to go back and figure out what is wrong. I have added and removed the required “#” symbols to add the “Volume” selection to the plugin menu and removed the grayed out selection from the context menu.
          Most of my work involves working with designs that are located underwater. So if you ever do look at this program again, besides all the choices in volumes, it would be nice to have two more choices, buoyancy in saltwater or fresh water.
          Again thanks so much for the original plugin.
          Ken
          • kenK
            ken
            Thanks for your quick reply.
            Ken
              Recent updates of SUp seem to have led to graying-out of context-menu items that only a restart and early try to use them fixes... The context-menu items can usually still be accessed via the end of the main Edit menu...
              Something to do with how many clicks you do before it breaks - hopefully a future SUp update will fix this...
              • P
                pedromarmol
                Hello!
                The first, Thanks!, the plugin is fantastic. I'm translating a lot of plugins for SU to spanish language, i have translated Volumen Caculator 2.1 to Spanish, i want to share with all SU's users.
                Chao!
                Here is the Spanish version:
                EDIT: Script Removed. SketchUcation forum policy does not permit people to post scripts they did not write. Please obtain permission from the author first, thanks!
                  Pedro
                  If you PM me your translated version I'll check it over and publish it here, if it's OK...
                    Thanks to Oxer who has translated my Volume_v2.1 tool into Spanish - so if you would like it to run in Spanish then remove the old version and put this new one*** into the Plugins folder [if you prefer it to be in ENglish then don't do anything !].
                    Unfortunately this tool is not [yet] 'debBelizered' so if there are any updates to the EN version then the ES translation might get out of step - however, the next update will probably be to get it 'deBabelizered' anyway, so not to worry... 🤓
                    ***VolumeCalculator21-ES.rb
                    • W
                      watkins
                      Dear TIG,
                      I am having problems with the attached model. The volume calculator works fine on the blank casting (2 %), but falls over with the casting with the holes. I am using version 1.8 of VolumeCalculator.rb because (in the past), I found it worked best with internal voids.
                      Would it be possible to include a drop-down and editable list of densities, with the option to calculate total mass as well as volume. By editable I mean the possibility to add to the list of materials and densities.
                      Would it be possible to include an escape function (ESC key?) so that the calculation could be terminated if found to be taking too long?
                      Kind regards,
                      Bob
                      Model for TIG.skp
                        To do stuff with density/volume/weight use my very recent 'Center of Gravity Tool'...
                        I have got you 'holey form' to make a Volume... BUT I rotated it in 3D so it didn't take forever to work at 0.5%!
                        Having all of those holes in every 'slice' r_e_a_l_l_y slows things...Capture.PNG
                        • W
                          watkins
                          Dear TIG,
                          Many thanks for answering my query. I hadn't thought to change the Z direction before running the script. A very, very useful plugin. Thanks
                          Regards,
                          Bob
                          • P
                            Pout
                            Hey TIG,
                            Thx for this script.
                            I have a little question:
                            Let's say a group only contains one or multiple faces not forming a volume (so volume can not be calculated)
                            How do I build in a test that determines if the script should continue with the volume calculation (or just give the combined area of the faces)?
                            Maybe the test is already in the code, but i can't seem to figure it out completely.
                            regards
                              There are two versions of Volume - [v1] is slow but 'reliable' and the other [v2] is fast but 'sensitive' !
                              v1 will find the volume of a shape even it it has no 'lid' or holes in it - just as if it were filled up with a fluid till it spilled out - but it takes it's time on very high accuracy settings...
                              v2 needs a 'manifold' shape - make sure that the form is fully faced - there's my recent manifold.rb to check this. Used on a suitable form v2 will quickly return the volume with as much accuracy as it can muster... if it has 'holes' or complex faces [internal etc] it can't return a volume.
                              To find the area of faces there's a new thread started recently that explains how best to do this...
                                SUCCESS01
                                hello......... it seems to be intressting, please how to get it?
                                  SUCCESS01
                                  thanks man... you're so great 👍
                                  • B
                                    BillB1
                                    Hi, just wanted to let the community know, I tried running Volume2.1, having had it run successfully in the past, and found that whilst the dialog loaded and the "clone volume" object was created, no volume text label was added to the drawing. Guessing that the problem might be a plug-in conflict, i disabled some of my more recent plugin additions (change filename from .rb to .rbXX) and re-ran Sketchup and Volume. The problem was Sketchy Physics plugin (V3 I think). Disable it and Volume 2.1 works as expected.
                                    Don't know if anyone can shed any light on this or can suggest a solution for them both to co-exist?
                                    Best wishes to all.
                                      Thanks Bill
                                      There is a know issue with some clashes with scripts and SketchyPhysics - see this http://forums.sketchucation.com/viewtopic.php?p=300105#p300105 BUT it's never been reported with Volume before ?
                                      Perhaps it's a clash with the
                                      class Geom;;Point3d
                                         def dot(v)
                                            self.x * v.x + self.y * v.y + self.z * v.z
                                      code ?
                                      I'll look into it...........
                                      • B
                                        BillB1
                                        No idea TIG, I'm not best-placed to comment on coding 😕
                                        It would be interesting to know whether anybody else has the same issue or whether it is a peculiarity of my system...
                                          Mvmcneil
                                          I am cleaning up all my plugins and testing as I install each one to make sure there are no conflicts and I keep getting an error when I do a validity check on simple cubes and spheres. Is this normal?
                                          Using Sketchup 7.1 on OSX 10.6.5.
                                          Thanks.
                                            How do you know this is related to Volume?
                                            Change your active layer to Layer0 beforehand and see what happens ??
                                            • 2 / 4
