    [Plugin] Volume Calculator2...
    64 Posts 23 Posters 89.0k Views 23 Watching
    • AdamBA Offline
      AdamB
      First off, "Volume Calculator" is TIG's baby not mine!
      The analytic method for Volume calc (the fast one) will not give the right answer if you have "open geometry". You can find all open edges by running a script like this (doesn't recurse into groups/components):
      def findleaks(ents = Sketchup.active_model.entities)
      	for ent in ents
      		next unless ent.kind_of? Sketchup;;Edge
      		if ent.faces.length == 1
      			Sketchup.active_model.selection.add ent
      The problem is there isn't a real simple way of automatically closing those "leaks".
      Adam
      • free agentF Offline
        free agent
        woohoo it worked thanx adamB
          I'd better jump in here...
          I made the early versions of Volume calculate by slicing the selected component or group into pieces and totting up the face-cut areas - like crude 'calculus'... It had levels of accuracy as it takes a while to slice and calculate a lot of faces. Often simple shapes return reasonably accurate volumes with few slices...
          Adam suggested a 'clever' way of calculating the volume - it has the advantage of being very fast and accurate but is prone to falling over it the faces aren't complete etc...
          That's why there are two versions out there.
          I would like to fix the fast version much as you ask. It could also include density and CofG etc: however, I am very busy on other things - I will publish something as soon as I can... but no promises...
          If anyone else would like to adopt my 'Volume' code and re-do it please feel free [I did something similar with Mirror.rb a while back - completely rewriting the method, but still gave Frank Wiesner the initial credit for having the original ideas up to 2.5 - now on 3.1 ?]...
          • W Offline
            watkins
            Dear TIG and Adam,
            Thank you for taking my request/suggestions seriously.
            Regards to you both.
            Bob
            • W Offline
              watkins
              Dear TIG,
              Do you think you might find a moment to take a look at your volume calculator. As I wrote before, the 'faster' version falls over when applied to a shape with cavities. A faster, working version would be good as then one could use the higher precision without the time overhead.
              Other improvements might include:
              1. Mass calculation (volume x density), with a editable drop down menu of typical densities (glass, concrete, soil, sand, water, steel, plastic etc)
              2. Centre of Gravity
              3. Moments of inertia
              Kind regards,
              Bob
                piyono
                Sorry to go OT, but I can't seem to get Sketchup 7.1.4871 to recognize the volume plugins. I've dropped them into the /Plugins folder with the rest of my plugins, all the rest of which work fine.
                Any ideas?
                Piyono
                  Any ideas?
                  Piyono
                  It's a right-click context-menu item only - available if you have a group or component-instance selected... There's no menu item - if that's your point ? ❓
                    piyono
                    Ahh... I see.
                    I was selecting primitive volumes, not groups or components.
                    • kenK Offline
                      ken
                      Well I haven’t used the plugin “Volume” for sometime and not sure when this problem started to occur. Right now, VolumeCalucator2.1, 2 or 1.7 or 1.8, all the versions I have, the context menu stays grayed out. Not sure what I have added to make this plugin’s context menu not functional.
                      Just passing this on to you, don’t expect you to go back and figure out what is wrong. I have added and removed the required “#” symbols to add the “Volume” selection to the plugin menu and removed the grayed out selection from the context menu.
                      Most of my work involves working with designs that are located underwater. So if you ever do look at this program again, besides all the choices in volumes, it would be nice to have two more choices, buoyancy in saltwater or fresh water.
                      Again thanks so much for the original plugin.
                      Ken
                      • kenK Offline
                        ken
                        Thanks for your quick reply.
                        Ken
                          Recent updates of SUp seem to have led to graying-out of context-menu items that only a restart and early try to use them fixes... The context-menu items can usually still be accessed via the end of the main Edit menu...
                          Something to do with how many clicks you do before it breaks - hopefully a future SUp update will fix this...
                            pedromarmol
                            Hello!
                            The first, Thanks!, the plugin is fantastic. I'm translating a lot of plugins for SU to spanish language, i have translated Volumen Caculator 2.1 to Spanish, i want to share with all SU's users.
                            Chao!
                            Here is the Spanish version:
                            EDIT: Script Removed. SketchUcation forum policy does not permit people to post scripts they did not write. Please obtain permission from the author first, thanks!
                              Pedro
                              If you PM me your translated version I'll check it over and publish it here, if it's OK...
                                Thanks to Oxer who has translated my Volume_v2.1 tool into Spanish - so if you would like it to run in Spanish then remove the old version and put this new one*** into the Plugins folder [if you prefer it to be in ENglish then don't do anything !].
                                Unfortunately this tool is not [yet] 'debBelizered' so if there are any updates to the EN version then the ES translation might get out of step - however, the next update will probably be to get it 'deBabelizered' anyway, so not to worry... 🤓
                                ***VolumeCalculator21-ES.rb
                                • W Offline
                                  watkins
                                  Dear TIG,
                                  I am having problems with the attached model. The volume calculator works fine on the blank casting (2 %), but falls over with the casting with the holes. I am using version 1.8 of VolumeCalculator.rb because (in the past), I found it worked best with internal voids.
                                  Would it be possible to include a drop-down and editable list of densities, with the option to calculate total mass as well as volume. By editable I mean the possibility to add to the list of materials and densities.
                                  Would it be possible to include an escape function (ESC key?) so that the calculation could be terminated if found to be taking too long?
                                  Kind regards,
                                  Bob
                                  Model for TIG.skp
                                    To do stuff with density/volume/weight use my very recent 'Center of Gravity Tool'...
                                    I have got you 'holey form' to make a Volume... BUT I rotated it in 3D so it didn't take forever to work at 0.5%!
                                    Having all of those holes in every 'slice' r_e_a_l_l_y slows things...Capture.PNG
                                    • W Offline
                                      watkins
                                      Dear TIG,
                                      Many thanks for answering my query. I hadn't thought to change the Z direction before running the script. A very, very useful plugin. Thanks
                                      Regards,
                                      Bob
                                        Pout
                                        Hey TIG,
                                        Thx for this script.
                                        I have a little question:
                                        Let's say a group only contains one or multiple faces not forming a volume (so volume can not be calculated)
                                        How do I build in a test that determines if the script should continue with the volume calculation (or just give the combined area of the faces)?
                                        Maybe the test is already in the code, but i can't seem to figure it out completely.
                                        regards
                                          There are two versions of Volume - [v1] is slow but 'reliable' and the other [v2] is fast but 'sensitive' !
                                          v1 will find the volume of a shape even it it has no 'lid' or holes in it - just as if it were filled up with a fluid till it spilled out - but it takes it's time on very high accuracy settings...
                                          v2 needs a 'manifold' shape - make sure that the form is fully faced - there's my recent manifold.rb to check this. Used on a suitable form v2 will quickly return the volume with as much accuracy as it can muster... if it has 'holes' or complex faces [internal etc] it can't return a volume.
                                          To find the area of faces there's a new thread started recently that explains how best to do this...
                                            SUCCESS01
                                            hello......... it seems to be intressting, please how to get it?
                                            • 2 / 4
